Australia
Old 03-03-2011, 06:47 AM   #1
jcjdavis1
My Ride: 323ise 1999 saloon
2000 E46 318i pipe connector
Hi. This is worth checking on the rear of the engine block, M43 engine -
Was loosing water and touched this and it just broke off. Jim
The older I get the wrong bit gets stiff!!
jcjdavis1 is offline   Reply With Quote
Old 03-03-2011, 08:27 AM   #2
Goondaddy
My Ride: 2002 325ci
I had that same part break off when I had the M43 engine back in the day when I owned my e36. Worth checking!
Goondaddy is offline   Reply With Quote
Old 03-03-2011, 02:21 PM   #3
Mitch E46
My Ride: M3 Convertible
Holy sh*tttt
Mitch E46 is offline   Reply With Quote
Old 03-03-2011, 03:18 PM   #4
shannon1
shannon1's Avatar
My Ride: 2001, 318i
Wow thanks for that, will have to check out mine.
How many km's/miles has your car done jcjdavis1?
Shannon.
shannon1 is offline   Reply With Quote
Old 03-03-2011, 04:48 PM   #5
jcjdavis1
Hi. Just over 113000mls. Jim
Old 03-03-2011, 06:29 PM   #6
anf
My Ride: e46
jeebus!
where did u buy the replacement part from?
anf is offline   Reply With Quote
Old 03-06-2011, 10:22 PM   #7
exil3
My Ride: E46 318i
Yeah, mine corroded recently too, though it wasn't as bad, thankfully.
Check the o-rings within the hose connections while you have it apart as mine were pretty much non existent.
I sourced my replacement part through ASV/Euro car parts here in Adelaide for around $35 but the dealer asked $85-90!
exil3 is offline   Reply With Quote
Old 03-07-2011, 07:10 AM   #8
vwikit
My Ride: 318i 99
they are such a pain to replace aswell, if in perth see lintrex cost me $8
vwikit is offline   Reply With Quote
Old 03-07-2011, 12:13 PM   #9
jcjdavis1
Hi. Part was 7. part No. 11 53 1 708 808. http://bmwfans.info/...attached_parts/ .Take the Pollen filter housing off after that it is down to feel. Tools required are short 10mm spanner and long screwdriver to unclip coolant hose and 1 jubilee clip on coolant hose, which you can see if you stretch over from drivers side,you do not need to take off the ccv hose.
I found it easier to lay on top of the engine and use two hands to get at the 2x10mm bolts, just take your time and don't drop anything. Take the hoses off first and put them on last.
Make sure you get the old O ring out when taking the old connector off, new connector has an O ring fitted.
You will loose coolant so make sure and bleed the system after topping up to avoid air locks. Jim
Old 02-14-2013, 01:47 PM   #10
129c
My Ride: BMW 318ci
Changed this part on my 318ci today because when i removed the small hose the plastic tube broke off. There is very limited room and if you drop the 10mm bolts you have a problem unless it falls nicely!
Heres a picture with the new part fitted.
_sl_ _sl_
129c is offline   Reply With Quote
