Old 03-04-2011, 05:26 PM   #1
lmyamen
My Ride: 00 328i
My wheel feels like its going to wobble off my car when i Brake
ok guys question for you, both my ball joints/control arms have been done with in the past 10k miles. I am trying to figure out what is causing this new issue. When I brake my front right wheel instantly starts wobbling like crazy and I can hear it like something is loose.
It was doing this only when braking but now its doing it when I hit a bump or even a small dip in the road. Like going down the interstate it will all the sudden just start doing it and the wobble/shake is horrible when it does.
Could tierod ends be causing this? what do you guys think?
Current XC90
Sold 00 328i.
lmyamen is offline   Reply With Quote
Old 03-04-2011, 05:30 PM   #2
immigrant
Banned User
My Ride: BMW
Maybe the bushings are bad.
immigrant is offline   Reply With Quote
Old 03-04-2011, 05:31 PM   #3
My Ride: Lexus
Probably your rotors. my car does this too to some extent despite seemingly good tierods and control arms (no play detected when car up in the air and using pry-bar method on control arms) I have new CABs too. So I've narrowed it down to rotors or dirty/rusty rotor to hub sufrfaces
Old 03-04-2011, 05:34 PM   #4
sea6speed
My Ride: 2010 335i Msport 6MT
Even more likely if the problem is worse when the car is heavily loaded.
sea6speed is offline   Reply With Quote
Old 03-04-2011, 05:37 PM   #5
jcns
My Ride: California
how many miles on the car?
does this happen at any particular speed? you mentioned that it happens when driving down the interstate.
does this happen only when braking?
where do you feel the vibration? on the steering wheel, on the car?
looks like you have aftermarket wheels. Did this happen right after you installed them? Is the right front wheel possibly bent?
When did you last do your rotors?
jcns is offline   Reply With Quote
Old 03-04-2011, 05:44 PM   #6
lmyamen
My Ride: 00 328i
is definitely not the rotors they are relatively new and it doesn't happen only when braking . the wobble will happen if I hit a bump or when I'm going down the interstate or even at slow speeds on side roads. I also noticed after I stop at a stop light and let of the break I have a large clunk sound that happens like something is loose
Current XC90
Sold 00 328i.
Old 03-04-2011, 05:55 PM   #7
My Ride: Lexus
The title of your post says your wheel wobbles when you brake.
Old 03-04-2011, 06:02 PM   #8
lmyamen
My Ride: 00 328i
breaking is how it started but it's not just limited to that it's not a wobble like the rotors are going bad it's a suspension feeling wobble that happens the worst when I brake
Current XC90
Sold 00 328i.
Old 03-04-2011, 06:03 PM   #9
My Ride: Lexus
Then your control arm bushings are shot.
Old 03-04-2011, 06:07 PM   #10
jcns
My Ride: California
where do you feel the vibration/shaking? on the steering wheel or generally on the car?
Old 03-04-2011, 06:09 PM   #11
BimmersGarage
My Ride: E46 330i
Check your FCABs (bushings) they could have given out on the right side (which means your left will go out pretty soon also.)
So, jack up your front - get the weight off your front wheels - and see if you can pivot your wheel. If there is any movement rear-ward then it's a sure sign of bushing failure.
BimmersGarage is offline   Reply With Quote
Old 03-04-2011, 06:10 PM   #12
lmyamen
My Ride: 00 328i
Would that be apart of the control arm and ball joint units that I have already replaced or is that separate? The shaking is felt through the whole car and not just the steering wheel.
Current XC90
Sold 00 328i.
Old 03-04-2011, 06:13 PM   #13
w0w
My Ride: '02 M3 Vert
sounds like a control arm bushing issue. its the big silver thing at the end of the control arm, bolted to the body of the car
daron
w0w is offline   Reply With Quote
Old 03-04-2011, 06:28 PM   #14
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Doublecheck the wheels tires before moving on.
Spin the wheels slowly and look for a flat spot on the rim...
Especially in the case where all of a sudden you don't feel safe at speed...wheels a good bet...as mentioned.
You're then clamping onto an unbalanced spinning mass...it'll shake worse...but still would be felt at lower speeds when not braking.
Check inside rim...much softer and easier to bend. And just coz a wheel balances, doesn't mean it's in balance. Also, if you only balance with weights in the centerline of wheel, you won't get as good a balance if you go on rims both inside and out as needed.
If flatspotted, swap to rear of car...and change pressure accordingly. Also check pressure now anyway!
Doug
See me in June!
dmax on Facebook
Mangofy your E46!
Old 03-04-2011, 07:01 PM   #15
jcns
My Ride: California
as mentioned, check wheels and tires. Wheels for bends and tires for flat spots. Maybe some of the balance weights fell off the wheel(s)
Have you checked the steering rack bushings?
Old 03-04-2011, 07:11 PM   #16
GoingNuts
Just Nuts
My Ride: 2004 330Ci
Probably the FCAB. My car tramlines on braking. I still have the factory FCABs. So they are the prime suspects.
GoingNuts is offline   Reply With Quote
Old 03-04-2011, 11:18 PM   #17
323iINt.o
My Ride: 328i
could be control arms! If you replaced them with cheap FEBI than most likely its your culprit.
I put on those cheap arms and in 5k I got a hard wobble on the highway, so bad I was getting scared. As soon as I made it home - checked to see the outter ball joint had half an inch play in it! Than I made the switch to Myhle HD and so far so good.
NEED SMOKED CORNERS AND MARKERS, PM ME IF YOU GOT SOME!
323iINt.o is offline   Reply With Quote
Old 03-05-2011, 06:09 AM   #18
Lusticles
My Ride: 325Ci
Maybe your wheel is bent.
number one Audi Fan
Lusticles is offline   Reply With Quote
Old 03-05-2011, 08:33 AM   #19
DJ Syxx
My Ride: BMW M3
sounds very much like FCAB, get those checked out.
DJ Syxx is offline   Reply With Quote
Old 03-05-2011, 08:40 AM   #20
BimmersGarage
My Ride: E46 330i
OP,
Instead of guessing. Do the simple test that I mentioned above, it will give you (or at least eliminate) the possible cause. the FCABs (Front Control Arm Bushings) It is a known cause of the symptoms you are describing. Especially when you stated it started with when braking and it's just gotten worse.
Other possibilities as other members have stated:
1. damaged wheel (but, you would know that, if you hit a curb or speed bump badly.)
2. Failed hub/bearings (likely, if you hear a funky -yes, technical term- metal "hum" when you spin your brake rotors.) Do a Youtube search for bmw hub bearing noise.
3. bad tire (look for uneven tread wear - Remove wheel and look at the treads carefully for weird banning on inner or outer tread face.)
4. warped rotors (could happen - you'll need to remove the wheel and give it a spin, seem if it rubs against your calipers unevenly.)
