Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Old 03-06-2011, 11:48 PM   #1
Sankekur
My Ride: 2004 330i
135i Brakes on a 330i
I am wondering would the brakes from the 135i fit on my 330i without adapter plates?
Thanks guys
Sankekur is offline   Reply With Quote
Old 03-06-2011, 11:53 PM   #2
Gheybe
Gheybe's Avatar
My Ride: F80 M3
REALLY doubt it.
The 135i brakes are the biggest ones that BMW makes. Ours, not so much.
Gheybe is offline   Reply With Quote
Old 03-07-2011, 10:26 AM   #3
tinkwithanr
My Ride: '00 323i + '75 2002
I remember a thread a while back about someone in England making the machined adapter plates to fit the bmw performance 6-piston calipers (135i and 335i mouting) to e46 non-m's. Which would lead me to believe that they don't just bolt up.
Tinker Engineering - 2014
Mica - 2000 BMW 323i - The one that started it all
Fiona - 1975 BMW 2002 - The Definition of Project Creep
Heidi - 1988 BMW M5 - The piece of BMW history
Silvia - 2013 Subaru WRX - Stock, for now
tinkwithanr is offline   Reply With Quote
Old 03-07-2011, 10:31 AM   #4
Sankekur
My Ride: 2004 330i
Thanks for the responses guys.
I have to say had my doubt whether they where a straight bolt on, but making adapter plates shouldn't be too much of an issue, the 135i brakes just look so epic
Old 03-07-2011, 04:13 PM   #5
Alexl08
My Ride: Evo 8
yes but the brakes on thoes things are shitty pistons crack and fall apart and dust boots fail so quick they are POS
Alexl08 is offline   Reply With Quote
Old 03-08-2011, 12:55 AM   #6
paraklas
My Ride: ESS TS2 320ci
Speed-religion; they had adaptors made to fit the bigger calipers to the E46 but they went out of business. This proves that it's doable, just need a good machine shop to do it
Old 03-08-2011, 10:46 AM   #7
Sankekur
My Ride: 2004 330i
Cool, I have some contacts at machine shops for when the time comes to try this out.
Old 01-15-2012, 06:52 AM   #8
Sankekur
My Ride: 2004 330i
Necro-bump and update
Finally manage to source a full set of 135i brakes and at a not too bad a price.
It is being shipped to me so I should have it next week sometime, then I will post pics.
Then I can also start to see what needs to be done the get them to fit.
Old 01-15-2012, 08:50 AM   #9
B33MER
My Ride: 330i SMG M-Sport
From what i've read it fits perfectly except for the pads are not mating properly with the disc resulting in an uneven wear on the disc ...
Edit:
Here ya go
http://forum.e46fanatics.com/showthr...=864522&page=5
330i SMG M-Sport Paket II Euro Spec
Mods:
CF Roundels all around, Black grillz, 7000k Angel eyes,6300k HID fog lights, Hamman Lip reps, ACS roof spoiler reps, Alutech front and rear struts, BMC CDA with DIY heatshield, Pro RS braided brake line, ///M Billet Oil Cap, OEM ///M mats, ///M aluminium pedals,
B33MER is offline   Reply With Quote
Old 01-15-2012, 11:28 AM   #10
Sankekur
My Ride: 2004 330i
Thanks for the link
Old 01-15-2012, 05:01 PM   #11
dan_1337
My Ride: 330CiC
From all accounts, this is the same as the 135i kit:
http://www.ecstuning.com/Flyer-E36_E...formance_BBK_/
dan_1337 is offline   Reply With Quote
Old 01-21-2012, 05:11 PM   #12
Sankekur
My Ride: 2004 330i
Some pics:
With the fronts fitted, not perfect yet but good enough for now:
And with a wheel on (had some interference issues with my 17's so borrowing a set of 18's from my brother until I get my own set of 18's)
Old 01-21-2012, 09:23 PM   #13
codyfunk
My Ride: 2001 BMW 330ci
what'd it take to make that work? how much money? Pm me if necessary
codyfunk is offline   Reply With Quote
Old 01-22-2012, 01:57 AM   #14
Sankekur
My Ride: 2004 330i
Well you are in the US so shipping won't absolutely murder you so you best bet would be to order the performance ones new as posted in the to links above B33MER and Dan_1337 then you get everything you need.
Unless you want the 135i ones specifically, then you will have to search around a bit, saw a couple of full sets of callipers going for around $1100 - $1600 and seeing as you have a 330i the front callipers should fit on the discs pretty well, the rears I can't say yet still have to work on them.
Old 01-22-2012, 03:45 AM   #15
codyfunk
What about adapters to make them fit? I was following a couple threads about the performance brakes but I have to have a rear setup too just so everything matches. That's by the 135 kit is so intriguing
Old 01-22-2012, 03:51 AM   #16
mkodama
mkodama's Avatar
You guys know you can buy the full front setup with brackets for $1200 shipped, right?
Old 01-22-2012, 03:56 AM   #17
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
I would much rather go with the ECS kit than spend the time and money required to do this retrofit. That said, well done OP on having something that is certainly unique
Timeless Motor Group
Old 01-22-2012, 04:02 AM   #18
codyfunk
Back brakes are my concern. I know the ecs kit would work but rears they won't.
Old 01-22-2012, 04:05 AM   #19
mkodama
mkodama's Avatar
Whoops, sorry. I missed that part.
Old 01-22-2012, 09:05 AM   #20
Sankekur
My Ride: 2004 330i
I am busy trying to work out a way of fitting the rears as well, will post up my findings and results as soon as I have any, am hoping that I can make the rears work with another OEM disc.
Even though I much more prefer the look of the 135i brakes over the performance ones I would definitely have gotten the kit from ECS if possible, but I am in south africa so shipping here will probably get the price closer to $2000 with shipping and then I when it gets here I would still need to pay import duties, which is like playing the lottery, sometimes it is cheap but you might also be unlucky and then it comes to some insane price.
Thanks 2000_328CI
