E46 Xi Forum
Old 03-07-2011, 12:50 PM   #1
Ivanhoe
My Ride: BMW 330 xi 2005
Shark Injector on a 330 xi
I search and try to learn about the shark injector but want to hear your opinions.
Found another threat on a member with a 325 xi is asking the same think and a lot of you guys says it is not worthed, but what about the 330 ?
Two weeks ago I installed the OEM Performance Intake and was a noticeable improvement.
If some had in your car, please give me your feedback.
Thanks,
Ivanhoe is offline   Reply With Quote
Old 03-08-2011, 09:14 AM   #2
Ivanhoe
Somebody ??
Old 03-08-2011, 11:10 AM   #3
Dreamliner330
My Ride: 330xi
I got the Dinan stage II at the dealer and was happy. Improved accelerator pedal response and felt a bit snappier....
Dreamliner330 is offline   Reply With Quote
Old 03-08-2011, 11:13 AM   #4
xixixi
Banned User
My Ride: 01 330x-xi
stick or auto ivan?
Old 03-08-2011, 11:23 AM   #5
drumbum624
My Ride: 325xi
Send a message via AIM to drumbum624
there are plenty of threads about this but i'd say since your're somwhat nearby you should take your ECU to Active Autowerke. And if your not up for the drive to Miami then you can just ship it to them. But you should get a printout of your current power map at a local shop that has a dyno. Then send that to Active so they know what they're working with and explain to them that you currently have a BMW Performance intake. Viral@ActiveAutowerke I'm sure would be happy to help you out. Another good option would be to get a custom dyno tune somewhere locally. And i'm sure you'd love the shark injector too i just am more of a fan of going with a custom tune because the shark injector is pretty universal, the active tune is a little more specific to your mods and a custom tune will be the best.
drumbum624 is offline   Reply With Quote
Old 03-08-2011, 12:46 PM   #6
conv440
My Ride: 05 M3 Vert 04 330xi
I've got a shark for my 04 330xi. It made an enormous improvement in throttle response. The car jumps off the line now. Can't say whether there is any improvement in torque/hp as I've never dyno'd the car. Butt dyno says maybe a slight improvement. Removing the top end speed restriction isn't really an issue for me as the Autobann is a little too far from my house. Overall I'd say it's worth it although you have to by premium fuel and at today's prices, OUCH. There is a much less expensive product that only improves throttle response, that may be a better option depending on what you are looking for. BTW my car is an auto.
conv440 is offline   Reply With Quote
Old 03-08-2011, 01:02 PM   #7
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
^ why would you be putting anything less than 91 octane in your car to begin with?
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 03-08-2011, 01:58 PM   #8
Ivanhoe
Originally Posted by xixixi View Post
stick or auto ivan?
Thanks xixixi, its auto
Old 03-08-2011, 05:33 PM   #9
xixixi
Banned User
My Ride: 01 330x-xi
No it's not worth it imo for an auto car. The main benefit i've seen from my shark is rev limit increase and able to go all the way to 7k then shift. Add some gears to that and you can stay in the power band. IE rev limit used to be 6500. Lets say your really fast and you shift at 6400 and don't hit the limiter. It puts you in the next gear around 4k (depending on what rear diff ratio you are running this may vary) about 1k off where you wanna be. If you check the dynos power band is from 5k to 7k. I'm running 3:46's with a 5spd i shift at 6900 brings me to around 5.2 to 5.5 depending how lucky i get Keeps ya in the power!
Old 03-09-2011, 03:06 PM   #10
Ivanhoe
Thanks for your comments, my idea, correct me if I am wrong, I read that in Germany when they made those cars for US they modify some specs to accept fuel with lower octane grade, and the shark do the thinks that xixixi says plus change the car to obtain better performance using high octanes gas. ( I am actually using 93 )
My intention is to have some better performance without been a young kid ( I am 48 ) racing on the streets, and I am not complaining with the actual that I have.
Old 03-09-2011, 03:21 PM   #11
infinite012
My Ride: White '08 STI
The thing about low octane fuel (should you mistakenly put it in your car) is the car will retard the timing, lowering your HP/TQ so as not to destroy your engine.
I think that's right. Anybody care to correct me?
infinite012 is offline   Reply With Quote
Old 03-09-2011, 03:54 PM   #12
SamDoe1
My Ride: 4cyl of fury
You are correct, it will. It will also throw your fuel economy down the shitter too.
Using the shark just optimizes the settings for 91+ octane gas which you should using anyway. US law requires all cars to be able to use 87 octane gas no matter what, more often that's by retarding timing to avoid premature detonation in the cylinder.
Old 03-11-2011, 10:23 AM   #13
xixixi
Banned User
My Ride: 01 330x-xi
If you want some street performance, change your diffs to 3:46s car will be much peppier!
