Ask a corrosion technician anything... - Page 5 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
General Off-Topic
Old 05-17-2012, 06:38 PM   #81
RedBarron
My Ride: Porsche
Send a message via AIM to RedBarron
I live in Florida and my jetski and trailer get a little corrosion here and there even though I spray them off after each use in the salt water. What do you recommend to spray to inhibit corrosion on it or it's going to happen and just rinse it off with fresh water?
RedBarron is offline   Reply With Quote
Old 05-17-2012, 07:12 PM   #82
mkodama
mkodama's Avatar
Surprisingly interesting thread.
I'm building a cooling system for my car which is going to use lots of 6061 and 6063. What treatments offer the best ultimate corrosion protection, most visually appealing corrosion protection, and most economical corrosion protection? The primary areas of corrosion protection were on the exterior of the original aluminum and mild tubing, where the overlapping hoses would trap what I assumed was splashed water during driving. The interior of the original tubing showed zero corrosion after 28 years.
Old 05-17-2012, 08:36 PM   #83
Jmanscotch
My Ride: makes my pants tight
When you say a little corrosion do you mean just surface rust, like your brake rotors after sitting wet for a bit or actual metal loss (pitting, perforation, etc)?
Even outside of the salt water, the moisture in the air down there is going to give you problems and rising doesn't remove all the contaminants. If you're driven to mitigate it, sand down the affected areas, clean well with paint prep then paint away, with the prep being the most important stage.
-Jake
2004 325CI - 2003 3.0 Z4 - 1994 325i - 1967 1602 - 2008 328XI - 2009 135i - 2007 Jeep Wrangler - 2014 *Loading*
Jmanscotch is offline   Reply With Quote
Old 05-17-2012, 08:58 PM   #84
Jmanscotch
To be frank, I've never dealt with corrosion protection on any aluminum structure(s) so I'm not really in a good position to offer a solid answer as I do know aluminum doesn't react like the metals I'm used to handling.
Two things:
- Check out NACE.org (NACE: National Association of Corrosion Engineers) and search for 6061 and 6063 and take a gander at some of the resulting articles. I'm a member, so if you find something you'd like to read up on, just contact me and I'll see what we can do. I ran a quick search and saw a few topics that may be worth a read for you.
- I reckon the biggest issues with the joints has to do with the issues of welding aluminum and purity in the rods/filler used along with heat stress the softer metal is exposed tol.
-Jake
Old 05-17-2012, 09:58 PM   #85
BreakfastBurrito
My Ride: ///GT3 RSR
anodize that sh*t, which (ironically, you could say) is corrosion itself.
BreakfastBurrito is offline   Reply With Quote
Old 10-06-2012, 09:24 AM   #86
Rush1249
My Ride: 2001 BMW 330i
I have a 2001 BMW 330i with a few rust spots on my quarter panels and both front doors. Is my car covered by the 12 year warranty or not?
Thanks!
Rush1249 is offline   Reply With Quote
Old 10-06-2012, 09:57 AM   #87
snowie007
My Ride: 2000 323i
What is the latest technology to combat CUI?
snowie007 is offline   Reply With Quote
Old 10-06-2012, 10:48 AM   #88
Jmanscotch
Thanks!
Have you taken the car into BMW for it's annual-or-biannual rust checkout? If not; then they won't honor the warranty. That said, we've all seen BMW NA do good-will repairs and if you push for it enough, you might just get a yes (but I wouldn't bet on it).
No clue. I did a quick search on the NACE website and found some studies on the topic but nothing stands out as a new cure-all.
-Jake
Old 10-06-2012, 04:20 PM   #89
silroc
The Man you Love to Hate
My Ride: 323Ci
Send a message via AIM to silroc
How big is the benefit to painting pressure treated wood with those special stains/ sealers from the big box stores?
Does painting one side(top side) only , make a difference to the lifespan?
Bring It
"Woke up quick, at about noon..........." - Eazy-e RIP
"Don't worry. The ghosts eventually come out" - Derek Jeter
silroc is offline   Reply With Quote
Old 10-06-2012, 09:34 PM   #90
Locutus09
My Ride: Something Slow
I miss you Jake.
Insert random question about corrosion here.
Locutus09 is offline   Reply With Quote
Old 11-13-2012, 08:03 PM   #91
Jmanscotch
It should extend the life some. Any barrier is a barrier against the elements/wear and tear.
Originally Posted by Locutus09 View Post
I miss you Jake.
Lol, sorry I'm just now getting to this thread again! You know we have better driving roads here, so load up the Auto-x setup and trek 1,220 miles out here Kyle!
To answer your corrosion question; rub poop on it, it'll stop all of your problems.
-Jake
Old 11-13-2012, 08:21 PM   #92
Miss325
My Ride: 05 325CiC Individual
Originally Posted by k2pilot View Post
Figured as much... I guess all main components would have to be galvanized, and maybe make all the "rusted" panels purely cosmetic and interchangeable.
What would you advise as the best metal for a main housing structure that would be low maintenance and long life-span, in terms of corrosion?
The rusted surface you're discussing is called Corten. It is a pre-rusted panel, and is completely non-structural, so yes they are cosmetic and interchangeable (but somewhat expensive).
Miss325 is offline   Reply With Quote
Old 02-05-2014, 03:38 PM   #93
Jmanscotch
Oh hey hi
-Jake
Old 02-05-2014, 05:10 PM   #94
SamDoe1
My Ride: 4cyl of fury
I read this whole thread, learned more about corrosion in the past 15 minutes than my entire engineering education.
Sometimes I think I should start an AMA thread but fear it would get out of hand...
Old 02-06-2014, 10:05 AM   #95
Jmanscotch
Eh, go ahead...it's good for boring snowed in days at work!
-Jake
Old 02-06-2014, 07:14 PM   #96
sakums20
My Ride: 02 330ci
u should invent a spray that will remove rust and corrosion, it will make u millions, i have buyers lined up for u
sakums20 is offline   Reply With Quote
Old 02-06-2014, 09:06 PM   #97
Jmanscotch
if only there was such a way (then again, I'd be out of a steady job)
-Jake
Old 02-07-2014, 09:17 AM   #98
SamDoe1
That doesn't happen here but I'll do it next time I'm bored at home on a weekday.
Old 02-07-2014, 10:27 AM   #99
Grande D
My Ride: E36 M3
There are chemicals that "dissolve" rust to a degree. The problem is (in my limited experience) if the rust has gone too far, you are simply dissolving the surface and creating or enlarging a hole. It seems these products work for very minor surface rust.
It will change your life!
Old 02-07-2014, 06:17 PM   #100
Jmanscotch
Correct, there are those products that can do a great job removing surface rust and light-moderate rust. There's even the whole putting the affected metal in a tank of water/baking soda, mocking up a power source and a sacrificial anode and using electrolysis to remove the rust...it often works great.
If you get into moderate and worse corrosion, then a spray that would adequately break down the 'rust' would also be entirely too aggressive for most of the metals in the situations. Even when it could handle the solution, there'd be much more cleaning to be performed than just the spray-on solution.
The level of cleaning and sanding that you'd have to do after the spray solution is practically what one would do on that level of affected metal anyways, making the spray-on solution a wasted step, or atleast a very small step/victory (and likely not worth the cost).
Come on, someone give me a challenging real life question! There's talk I might get promoted when my boss takes another job...this is a premature move in my opinion and I don't nearly know what I feel I should. Give me something I have to think hard about!
-Jake
