Old 03-09-2011, 12:15 PM   #1
alpine325coupe
My Ride: 2004 M3 SG/IR
Car starts weak then immediately stalls? HELP!
There have been a few times over the past couple months where I start the car and it stalls out. When it starts, the RPM does not jump as high as normal. It only reaches about 1000 rpm and then drops down to zero.
Today it happened multiple times. I could not get the car started after about 10 or so tries.
Also, one time when it did start and drive, it would not go over 20mph. When I tried to accelerate my speed and rpm did not respond. Car then stalled out.
Does anyone have any ideas to why this is happening?
Thanks in advance
alpine325coupe is offline   Reply With Quote
Old 03-09-2011, 12:20 PM   #2
sladha
My Ride: '15 M4|'14 X5
could be due to a dirty MAF? clean the mass air flow sensor that may help. you can get the spray at an autozone
'01 TiAg 330Ci - Modded
'12 ActiveHybrid7
sladha is offline   Reply With Quote
Old 03-09-2011, 12:26 PM   #3
RobbSpeed
My Ride: 2001 330ci
and also check out the two air boots (upper & lower) that connect from the MAF to the throttle body. If you've never had them replaced before, I bet at least one of them has cracks.
RobbSpeed is offline   Reply With Quote
Old 03-09-2011, 02:06 PM   #4
Hukerfaker
My Ride: My wife.
Definitely sounds like faulty/dirty/loosely connected maf.
Hukerfaker is offline   Reply With Quote
Old 03-09-2011, 02:08 PM   #5
alpine325coupe
Thanks for the help guy! I was searching around and found a cleaning product available at local auto retailers (CRC Mass Air Flow Sensor Cleaner). I'm going to give it a shot this evening or tomorrow
Old 03-09-2011, 02:09 PM   #6
Eliott's-BMW
Eliott's-BMW's Avatar
My Ride: E46 3-Pedal Mafia
Do you have check engine light?
Who has the skills?
e30 project
"May GOD grant you DOUBLE the amount you wish upon me!"
Eliott's-BMW is offline   Reply With Quote
Old 03-09-2011, 02:10 PM   #7
brosive05
My Ride: 01 325 & 94 ZR1
02 sensor possibly?
Student during the day, driver at night.
brosive05 is offline   Reply With Quote
Old 03-09-2011, 02:10 PM   #8
alpine325coupe
Yes. Have had check engine light on for about 5k miles. My mechanic told me its prob just a sensor and wasn't worth the money to fix
Old 03-09-2011, 02:12 PM   #9
brosive05
I have the same problem too. Where my RPM's fluctuate, and stalls quite frequently
Old 03-09-2011, 02:13 PM   #10
alpine325coupe
sorry to hear that. how many miles do you have on your car? i just hit 150k
Old 03-09-2011, 02:15 PM   #11
Eliott's-BMW
WTF??? get another mechanic and go to autozone and get the codes from the check engine light, now!
Who has the skills?
e30 project
Old 03-09-2011, 02:22 PM   #12
Broach><330
My Ride: 330CI -E30 325 (S52)
Just a suggestion... It could be you're vanos seals ive been "told" that when they start getting bad you're cold starts will start getting way out of whack.. as in the whole car shaking, sputtering, misfiring and such.. its kind of a pain to do though, if you mess up the timing you more than likely will blow you're engine.
High-line catback
Kosei K1's
Headers
3.15 Differential
Koni FSD, eibach sports
AA software
205k (9/16/13)
E30 S52B32 100,xxx
5spd ZF, JB LW fly, Megan Coils, OBD1 conv. Mishimoto with low temp stat, TRM 15x8, Black vinyl sport seats, MOMO mod 08, 2:93 LSD, Custom single 2.5" exhaust, SS headers, M3 rack, basically new everything on driveline.
Broach><330 is offline   Reply With Quote
Old 03-09-2011, 02:24 PM   #13
alpine325coupe
The car was warm when the stalling was happening. And during this fiasco, the car was idling very rough
Old 03-09-2011, 02:24 PM   #14
Eliott's-BMW
You won't mess up the timing because you don't even have to remove the timing chain to change the VANOS seals...
Who has the skills?
e30 project
Old 03-09-2011, 02:26 PM   #15
Eliott's-BMW
I'm guessing it could be a cam position sensor but go get the codes from the ECU first, then tells us what they are...
Who has the skills?
e30 project
Old 03-09-2011, 02:27 PM   #16
Broach><330
[QUOTE=Eliott's-BMW;12902217]You won't mess up the timing because you don't even have to remove the timing chain to change the VANOS seals...[/QUOTE/]
yeah but if a noob gets in there the possibilities are endless..( NOT refering to you or the OP)
High-line catback
Kosei K1's
Headers
3.15 Differential
AA software
205k (9/16/13)
E30 S52B32 100,xxx
Old 03-10-2011, 12:13 PM   #17
alpine325coupe
So guys, I got the spray from autozone and just cleaned the MAF sensor. When I started the car, it started pretty strong, but then rpm began to wiggle between about 600-800 rmp. Sat and watched it for about 10-20 seconds and rpm began to fall, engine sounded weak, and the car stalled.......not sure what its called, but the air boot (as referred by robbspeed) connecting to the MAF had a few minor cracks and then a very generous crack right before the rear clamp. Is this causing the stalls? I'll look for the part number but if anyone can help me out it would be much appreciated
Old 03-10-2011, 05:21 PM   #18
vumuudar
My Ride: 330CI 2004
How much gas do you have in the tank? It could be two things imo. The fuel pump or the sucking jet pump.
vumuudar is offline   Reply With Quote
Old 03-10-2011, 05:22 PM   #19
alpine325coupe
i think i have more than a half a tank. im about to order a new intake boot. with the giant cracks im sure its leaking like crazy
Old 03-10-2011, 05:29 PM   #20
jdstrickland
My Ride: '94 325iC & '00 323i
It's time to shoot that mechanic, then throw his lifeless body off of an overpass.
The problem is that you report that he said, "probably." Possibly is a better word, but if the light is on, then there is a clue as to why it does not run. And since the car does not run, then you cannot fix it without knowing what the code is, and since it is not running, then it is not something that can be ignored.
I would suggest that you not spend another dime on this until you know what the codes are. Well, spend one dime, have the codes read. Buy a scan tool and read them yourself. The scan tool will pay for itself the second time you have to pull codes.
