Car starts weak then immediately stalls? HELP! - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-10-2011, 04:30 PM   #21
vumuudar
My Ride: 330CI 2004
My car did the same thing. It was the sucking jet pump that went out. It caused the fuel pump side to go empty at 1/4 tank left therefore burning out the fuel pump.
vumuudar is offline   Reply With Quote
Old 03-10-2011, 04:46 PM   #22
My Ride: Lexus
Puel fump.
Old 03-10-2011, 04:55 PM   #23
M3GAPL3X
My Ride: '02 330 Ci
Had the same issue about 2 weeks ago. It was my fuel pump. If you drive your gas on "almost" empty a lot, it can cause the fuel pump to fail. That is what happened to me.
M3GAPL3X is offline   Reply With Quote
Old 03-10-2011, 05:21 PM   #24
ZHPOWER
My Ride: 2003 ZHP
fuel pump
ZHPOWER is offline   Reply With Quote
Old 03-10-2011, 05:28 PM   #25
alpine325coupe
My Ride: 2004 M3 SG/IR
I never let it go under 1/4
alpine325coupe is offline   Reply With Quote
Old 03-10-2011, 05:58 PM   #26
alpine325coupe
Is it harmful to drive with a failing fuel pump? I want to take the car to autozone (about 1/4 mile from my house) to get the CEL code(s). I know when my power steering pump failed my mechanic told me not to drive it.
Old 03-10-2011, 06:00 PM   #27
TopazBlu02
My Ride: 330CI
It's not the fuel pump guys. Its the intake boot. A crack intake boot will cause all sorts of havoc b/c it's reading unmetered air and sending these incorrect readouts to the fuel pump. Fuel pump gets incorrect readouts and not pumping enough fuel thus starving the engine.
TopazBlu02 is offline   Reply With Quote
Old 03-16-2011, 10:53 PM   #28
alpine325coupe
After a painful wait my upper intake boot came today. I installed it, turned the car on, and it stalled........I'm about to go insane! I cleaned the MAF, I replaced the upper intake boot (from a pretty thorough look with a flashlight, the lower boot it seems to be in one piece). I don't know what else to do.
I started the car, it idled rough, then hovered around 800 rpm. I tried giving it gas and it went up, but then would drop back down as if I released my foot off the gas....then stalled.
Taking it to a shop is my last resort. Any other ideas?
Old 03-16-2011, 11:43 PM   #29
M3GAPL3X
My Ride: '02 330 Ci
It still sounds like a failing fuel pump to me. Mines did the exact same thing before it fully failed.
'02 330ci manual
Old 03-21-2011, 10:34 AM   #30
alpine325coupe
I spoke with a mechanic this weekend and he said the possible problems could be the fuel pump, fuel filter, or a dirty throttle body. I cleaned the throttle body. When I went to start the car, it started for 2 seconds and stalled and now will not start.....go figures. So I finally manned up and ordered a fuel pump. It should be here on Wednesday.
Ill keep you posted
Old 03-21-2011, 11:17 AM   #31
mack89
My Ride: '02 TIAG 330i 5spd
When it idles roughly and stalls, IT IS MAF/INTAKE SYSTEM MALFUNCTION
When it stalls when you accelerate at green light, IT IS CAMSHAFT POSITION SENSOR (CPS)
Get the codes first. You may as well replace MAF/intake boots and CPS intake/exhaust both.
mack89 is offline   Reply With Quote
Old 03-21-2011, 11:28 AM   #32
alpine325coupe
My lower intake boot looked fine but my upper was shredded, so I replaced that. I also cleaned my MAF about a half dozen times within the past week. How sure are you? I'd rather not blow another 150 on a new MAF
Old 03-21-2011, 04:59 PM   #33
mack89
Cleaning MAF is a part of maintenance. It won't solve the problem. Scanning with BMW GT1 will give you detailed result, even if SES light is not turned on.
Old 03-30-2011, 10:19 PM   #34
alpine325coupe
Update.....more bad news:
Since my last post I have replaced the fuel pump and fuel filter. The car does not start. It used to start and run weakly for a few seconds. Now, not starting..... I'm running out of ideas. Any last suggestions before I take it to a shop?
Old 03-31-2011, 09:23 PM   #35
alpine325coupe
BUMP any ideas to why it's not starting?
Old 03-31-2011, 10:29 PM   #36
SNAPENEXX
My Ride: BMW
make sure your fuel filter is not on backwards, arrows on filter towards the front of the car
SNAPENEXX is offline   Reply With Quote
Old 04-01-2011, 12:10 PM   #37
hendrich
My Ride: 01' 325ci
Send a message via AIM to hendrich
First thing you had to do was scan the freaking ECU, that would give you a clear idea of what the problem is. I would say you have a bad CPS since my car does the same thing and that's the code I got P0344.
hendrich is offline   Reply With Quote
Old 04-01-2011, 12:13 PM   #38
xavi330i
My Ride: 2004 330i smg
Gotta peake's code reader? Cheap investment
xavi330i is offline   Reply With Quote
Old 04-01-2011, 12:17 PM   #39
alpine325coupe
I guess Ill invest in the code reader. Thanks guys
Old 04-01-2011, 09:31 PM   #40
one thumb juan
My Ride: E30, E36, E46
Originally Posted by Eliott's-BMW View Post
WTF??? get another mechanic and go to autozone and get the codes from the check engine light, now!
Surprised he didn't offer to take the bulb out for you. :-/
one thumb juan is offline   Reply With Quote
