Old 03-09-2011, 10:41 PM   #1
MaverickM3
My Ride: gets badge
Talking :Build Thread: E46 325ci Technique Tuning Stage1 Turbo .::NEW PICS INSIDE::.
As the title states this is a build thread for a E46 325ci with the Technique Tuning Stage 1 Turbo Kit. The stock dyno numbers are 174whp and 160wtq. The preliminary results thus far at 6psi are 247whp and 227wtq. This is just 6psi with a basic tune. Nick will be taking it up to 8.5 psi the max for stage1. More on that later. The dyno graph below is a comparison between the stock Dyno and the dyno at 6psi. As you will see in the dyno graph the mid range dips. Most likely need some new spark plugs. Will keep updating as I get new info for you. Here are some pics of the car and what you really want to see the Dyno graph. Comments welcome
Photobucket Pictures, Images and Photos
MaverickM3 is offline   Reply With Quote
Old 03-09-2011, 10:42 PM   #2
SalM
My Ride: Shhh
1st Sickk!! Haha everyones got a build thread going now! I think I started and epidemic.
SalMPhotography
SalM is offline   Reply With Quote
Old 03-09-2011, 10:46 PM   #3
MaverickM3
My Ride: gets badge
^^^ well if your gonna copy someone. It should be great member of E46Fanatics. Lol
Old 03-09-2011, 11:06 PM   #4
SPDu4ea
My Ride: .
Awesome, looks good
SPDu4ea is offline   Reply With Quote
Old 03-09-2011, 11:39 PM   #5
95blkmax
My Ride: 00 BMW 328i
Send a message via AIM to 95blkmax
congrats on this!!!! Solid numbers! Keep us updated on this! When done, any chance u could dyno it on a dynojet? it's easier to compare to others' dynos on SAE corrected dynojet graphs :-).
Keep it up!!!
Hi, my name is 95BlkMax, and I am a Boostaholic
"DANGER TO MANIFOLD!!!!" O_o!
95blkmax is offline   Reply With Quote
Old 03-09-2011, 11:48 PM   #6
MaverickM3
My Ride: gets badge
Yep I I'll use dynojet when it's finnished.
Old 03-10-2011, 08:45 AM   #7
McSpeed
My Ride: 2005 ZHP TT Stg 1
Cool!
Ahhh those familiar undercar images...
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 03-10-2011, 12:28 PM   #8
lab rat
My Ride: '02 330iT
Not bad for the first crack at 6psi. What ECU are you tuning MS43 or 45?
Old 03-10-2011, 12:33 PM   #9
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
My DD's a turbo as well.
... but its not a BMW.
Old 03-10-2011, 12:48 PM   #10
NickG@TechniqueTuning
Past Site Sponsor
My Ride: E46 330ci Turbo
This is an MS43 car. The car has been super consistent, with great power. I'm very happy with the results thus far
NickG@TechniqueTuning is offline   Reply With Quote
Old 03-10-2011, 12:50 PM   #11
MaverickM3
My Ride: gets badge
What's your DD?
Old 03-10-2011, 01:38 PM   #12
MarcusLSB
Originally Posted by MaverickM3 View Post
What's your DD?
06 Jetta GLI
Old 03-10-2011, 05:13 PM   #13
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
06 Jetta GLI
09 Rabbit 2.5
Old 03-10-2011, 05:18 PM   #14
SalM
My Ride: Shhh
Thanks so much man it really means alot!
SalMPhotography
Old 03-10-2011, 05:39 PM   #15
bluejeansonfire
ninja editor
My Ride: m5xual
Send a message via AIM to bluejeansonfire
very cool project, Nick and MaverickM3
what size turbo?
01 330cit-92 s13c-99 328i/5-04 x5/6
bluejeansonfire is offline   Reply With Quote
Old 03-10-2011, 09:00 PM   #16
Past Site Sponsor
what size turbo?
T4-60 trim compressor with a T3 Stage3 turbine wheel and .63 turbine housing.
Old 03-10-2011, 09:14 PM   #17
KENT
My Ride: Leased Astra 2008
Your numbers are sick.
But I don't like how the kit looks like.Especially the oil return line.But im no torbo specialist.
Anyways very clean BMW and sick numbersfor 6 psi.
Enjoy
Kent
KENT is offline   Reply With Quote
Old 03-10-2011, 09:49 PM   #18
bluejeansonfire
ninja editor
My Ride: m5xual
So all of the hardware is completely interchangeable between the e46nonM kits?
Enjoy
Kent
I used to have that kit, and it's sick. The build quality is amazing. The oil drain, iirc is an aeroquip pushlock hose on brass fittings with the npt pipe threaded in. I don't remember exactly what hose Nick used, but it felt quality like aeroquip hose. I use aeroquip hose on the same type of fitting, on the same type of setup. I kept it as I never has any issue with it.
Old 03-10-2011, 10:09 PM   #19
Past Site Sponsor
Pretty much. The 325 kits will use different fuel injectors than the 330 kits, as well as a different MAF and MAF adapter harness. All of the plumbing will be the same though.
You are right. We do use Aeroquip hose for the drain line that is rated for petroleum use and of an appropriate temperature range.
These 325 turbo kits are going to surprise many people with their performance
Old 03-10-2011, 10:17 PM   #20
MaverickM3
My Ride: gets badge
325, turbo kit
