E46 Xi Forum
Old 03-09-2011, 11:46 PM   #1
blinkerfluid
My Ride: 2002 325xi
Engine / driveline mout question
I have a few symptoms of engine / transmission mount wear but am having a hard time finding the right parts (they are different from non-xi) also, has anyone else replaced the engine / tranny mounts on an xi? Are they more or less prone to wear than on a 2wd car? Is the transfer case bushing worth replacing?
Here are the parts I found:
xi left engine mount : 11-81-2-283-798 ($50)
xi right engine mount : 11812283798 ($85)
Here are the parts I am not sure about***********:
Transmission left side : http://www.ecstuning.com/BMW-E46-325xi-M54_2.5L/ES2739/ (pelican lists it as a VW/audi part????)
need to find right side transmission mount
Transfer case mount I found but all ready lost the P/N (about $80)
So is that the correct transmission mount? Where do I find the right side mount?
blinkerfluid is offline   Reply With Quote
Old 03-10-2011, 01:57 AM   #2
e36-2.0
My Ride: 330xi
Xi's use an M3 motor mount on the drivers side and a XI specific mount for the passenger side. There are no transmission mounts found on the XI.
'02 330xi
Konigsport/Ground Control/DPE/BMW Motorsport/Eurosport/Turner Motorsport/PowerFlex/RacingDynamics/Hotchkis/UUC/Beisan/Bimmerworld/Dinan/Conforti/RPI/GroupN/Technik/Dynavin
Alberta's BMW enthusiast forum.
-Projecttechnik.com
e36-2.0 is offline   Reply With Quote
Old 03-10-2011, 07:46 AM   #3
lotar_6
My Ride: '01 xi, '94 Rado
Here is your engine mount info... LINK
And here is the trans mount info... LINK
AutohausAZ has your engine mounts. A google search on the trans mount # confirms your find at ECS. It appears it has multiple uses! Note the discontinued part #'s on realOEM... the new mount # could very well be intended for cross platform use.
lotar_6 is offline   Reply With Quote
Old 03-10-2011, 08:46 AM   #4
Kubica
My Ride: 2003 325xi
You can use a E90 M3 mount for the drivers side.
Old 03-12-2011, 12:22 AM   #5
blinkerfluid
My Ride: 2002 325xi
Thanks for the links, the transmission mount listed actually fits in the transfer case, meaning there are no mounts that attach directly to the transmission. I did a google search for the Trans mount # (22316773125) and did not anything that looks like that part on ecs tuning (which is a VW/Audi engine mount). I think they mislabeled that part as going on an XI, looks like they also have it listed as a trany mount for other E46's.
