E46 Xi Forum
Old 03-10-2011, 09:42 AM   #1
TX_Bullet
My Ride: 2001 325Xi
Rear diff is toasted!!!
Yep heard a sound while driving last night.....left off the gas and had a nasty vibration followed with a metal winding sound.
Looked under the car to see it leaking out the input flange.
Seems like the pinion bearing went out.
So.....will a non XI different fit my car
Originally Posted by jbeurotech View Post
Sometimes the Cheapest quote is the most expensive in the end
Number of Destroyed Newb Destroyers- 1
The Mods
Power Flex FCAB
Much more coming.....
TX_Bullet is offline   Reply With Quote
Old 03-10-2011, 09:43 AM   #2
Kubica
My Ride: 2003 325xi
Yes.
Do you have an MT or AT?
Old 03-10-2011, 10:00 AM   #3
Kubica
My Ride: 2003 325xi
If it's manual you will need a diff from another xi. If it's auto, a rear diff from any automatic 325 or 323 will work.
Old 03-10-2011, 10:35 AM   #4
FelizPrim3
My Ride: 02 325ci
yeah i experienced that too, but my wheels locked up on the highway and my car spun. i then replaced the diff with a used one. two weeks later when driving i heard a thump in the rear and clanking and vibrations occured. so i replaced it gain with another used one and it vibrates a little when rippin it in second gear
"MIKE"
2002 E46-SOLD
2007 B7 Audi 2.0T slammed -SOLD
2012 Hyundai Genesis 2.0T R-Spec
Follow me on instagram @Michael_Feliz
FelizPrim3 is offline   Reply With Quote
Old 03-10-2011, 10:38 AM   #5
xixixi
Banned User
My Ride: 01 330x-xi
As far as I know any/all diffs will fit as long as you get the proper gear ratio. Shouldn't have to come from an xi the rear diffs are all the same.
Old 03-10-2011, 11:42 AM   #6
TX_Bullet
My Ride: 2001 325Xi
Excellent I found one local for 200 out of a 04 325i and mine is auto tragic
The Mods
Power Flex FCAB
Old 03-10-2011, 01:13 PM   #7
TX_Bullet
My Ride: 2001 325Xi
........and pulled out. Turning that input flange feels all messed up
The Mods
Power Flex FCAB
Old 03-10-2011, 02:24 PM   #8
Kubica
My Ride: 2003 325xi
It was most likely leaking and ran out of fluid. When did you change the fluid last?
Old 03-10-2011, 08:03 PM   #9
TX_Bullet
My Ride: 2001 325Xi
I assure you it wasn't leaking. I changed fluid a month ago and it was very low. Previous didn't seem to keep up with maintenance well.
Fluid I used was Mobil 1 75w90ls
The Mods
Power Flex FCAB
Old 03-10-2011, 08:49 PM   #10
Kubica
My Ride: 2003 325xi
Well if it was low before you changed it there had to be a leak.
See if you can figure out what failed- the rear cover unbolts and the output flanges pop off.
Old 03-10-2011, 10:23 PM   #11
TX_Bullet
My Ride: 2001 325Xi
How hard us it to change the gear sets out with these diffs. I was tempted to swap the gear into a 293 diff I got laying around but never did it before
The Mods
Power Flex FCAB
Old 03-10-2011, 11:52 PM   #12
Kubica
My Ride: 2003 325xi
It's not easy.
Old 03-11-2011, 09:34 AM   #13
xixixi
Banned User
My Ride: 01 330x-xi
I swapped all the flanges on my diff. Input/output. Not hard just take your time. Use a punch/welding marker to mark the input flange with the nut. That way you can re tighten the input flange to spec. I put a brutal 4k on my diff since then. I used a shock proof diff fluid that was recommend (name escapes me atm) Blue something iirc
Old 03-13-2011, 08:04 AM   #14
TX_Bullet
My Ride: 2001 325Xi
This incident has given me no more hope with this car. My next worry was the tranny with the little gear light coming on once a month.
So......I sold it for 5k within 3 hours of posting it on Craigslist
My next bimmer will be a e30 and will be a project
The Mods
Power Flex FCAB
Old 03-13-2011, 11:49 AM   #15
Kubica
My Ride: 2003 325xi
"Hey y'all new xi owner here. I just got a great deal on this car off craigslist. Anyway which sponsor sells the cheapest black grills? I saw a set on eBay. Oh and my transmission light is flashing should I bring it to the dealer?"
I give it two weeks.
Old 03-13-2011, 01:40 PM   #16
TX_Bullet
My Ride: 2001 325Xi
Classic noobs......fortunately it already had black grills. And that tranny should hold up until they decide to swap fluids
The Mods
Power Flex FCAB
