Sponsored by BimmerWorld
Old 03-10-2011, 03:21 PM   #1
Sforza209
My Ride: 2004 BMW 330ci w/SMG
Replaced control arm bushings. Shaking steering wheel.
So I replaced my control arm bushings in my garage with A new pair for bavauto. when I finally finished the job I took my sweet ride out for a spin. Everything worked out fine! Until I reached speeds excess of 60mph. My steering wheel has a very very light shake to it. Its sort of visible when I let go of the steering wheel but I just mostly feel it when I'm holding on to the wheel. Very annoying. My car (2005 e46 330i w/ Zhp) should be smooth sailing, not a shakey steering wheel.
I took my car in to get an alignment and balanced the front two wheels. What else could cause a shakey steering wheel? Any help is appreciated! Thanks!
Sent from my iPhone using BimmerApp
Current ride: (purchased 6/6/14)
2004 Japan Red 330CI w/ SMG
Past rides:
2005 Steel Grey 330i ZHP
2003 Silver Grey 325CI (RIP)
2005 Sparkling Graphite Metallic 325CI
2002 Jet Black 325CI
Sforza209 is offline   Reply With Quote
Old 03-17-2011, 06:40 PM   #2
crazyxzer0
My Ride: 2004 330i
Send a message via AIM to crazyxzer0 Send a message via MSN to crazyxzer0
how are is your tire wear?
-Derek
Stoptech Front BBK|M3 LSD|GC Coilovers w/ Swift Springs|UUC TSE3 Exhaust|
My Build Thread
crazyxzer0 is offline   Reply With Quote
Old 03-18-2011, 11:24 AM   #3
Sforza209
Tire wear is fine. Even wear all around. It really is driving me crazy. It started after the new bushings were installed.
Past rides:
Old 02-11-2012, 02:00 AM   #4
itscoo2pyopants
My Ride: E53 4.8is
Send a message via AIM to itscoo2pyopants
did you ever figure out the problem?
itscoo2pyopants is offline   Reply With Quote
Old 06-24-2014, 11:27 PM   #5
wallofgrath
My Ride: 2001 330Ci
This is an old thread, but I'd also like to know if you figured this out? I have same issue.
wallofgrath is offline   Reply With Quote
Old 07-24-2014, 09:25 AM   #6
ArchHibb
My Ride: 2004 330cic
Look at this thread...
http://forum.e46fanatics.com/showthread.php?t=1043465
ArchHibb is offline   Reply With Quote
Old 07-24-2014, 07:22 PM   #7
generalvp
My Ride: 05 330ci
Originally Posted by ArchHibb View Post
Or this thread:
http://forum.e46fanatics.com/showthread.php?t=1045902
generalvp is offline   Reply With Quote
Old 07-26-2014, 08:46 PM   #8
wallofgrath
My Ride: 2001 330Ci
Balance all 4 wheels, not just front 2. I solved my problem by getting all 4 re-balanced even though they were balanced a few hundred miles prior to the wheel shaking.
