Old 08-17-2014, 02:35 AM   #1
drift325
My Ride: E46 323i
2JZ into E46
Hi everyone
At the moment i am in the middle of putting a 2JZGE that i have turbo'd into my E46, It is going to be a drift car but will be keeping a lot of street trim to keep the police at bay when i'm cruising it on the street.
the setup was in my old e30 but unfortunately at a local come and try day at the raceway near where i live, i let my wife have a go and well the wall won. so i am now building the E46 323i.
i will get as many photos of the conversion with as much info as i can, any questions let me know.
we will be running a haltech ps2000 ecu but using factory dash cluster just to make it that little bit cooler.
I hope you like the progress and possibly get some handy tips
drift325 is offline   Reply With Quote
Old 08-17-2014, 02:44 AM   #2
drift325
My Ride: E46 323i
I have removed the rear subframe, replaced all the diff and subframe mount bushes, replaced camber arms with adjustable ones and fitted coil overs, i have the SLR steering kit on its way also have reinforced the rear subframe mounts on the chassis and strut tops as they are common for cracking
we have mounted fixed back bucket seats to the factory bmw rails so we still have the up and down/ forward and back adjustability.
Fuel sytem wise i am running a walbro 400 lph intank pump we have modified the original fuel pump housing so we can keep the fuel level sender etc,
Old 08-18-2014, 11:41 PM   #4
dreyo27
My Ride: 2001 325ci
Nice... what are you using for the tranny?
dreyo27 is offline   Reply With Quote
Old 08-19-2014, 03:01 AM   #5
drift325
My Ride: E46 323i
I am running an r155 which is the same as a r154 supra box but out if a v6 Toyota hilux just has a shorter 1st gear and 1/3 the price
Old 08-19-2014, 03:05 AM   #6
drift325
My Ride: E46 323i
Old 08-19-2014, 03:06 AM   #7
drift325
My Ride: E46 323i
This is the engine bolted in with intake side now complete,
Old 08-20-2014, 02:30 AM   #8
drift325
My Ride: E46 323i
More engine bay tidy up, all factory pollen filter etc still fits factory radiator and fan to keep it all neat and tidy
Old 08-20-2014, 02:31 AM   #9
drift325
My Ride: E46 323i
How it sits with new wheels and new suspension. SLR steering still to come so front is going to be much wider, what to do about front guards??
Old 08-27-2014, 12:25 AM   #10
happyfelthappy
My Ride: 2001 BMW 330i Sport
subbed :0
Previous Cars:
95 Nissan 240SX Auto -First Car :) / 91 Camaro RS 5.0 Manual / 99 BMW 323i Manual / 1984 Porsche 944 / And others..
Current:
2001 BMW 330i M Tech I Sport / 2001 Jaguar XJ8 L 4.0 V8 (Daily, gas guzzler)
Parts wanted '01 330i
-Electric Fan -Windshield Cowl -Front lower control arm bushings -Air intake manifold (on radiator support) -Oil level sensor
happyfelthappy is offline   Reply With Quote
Old 08-27-2014, 02:12 AM   #11
-lynel-
My Ride: 2000 BMW 323i
I like I like
-lynel- is offline   Reply With Quote
Old 08-27-2014, 03:23 AM   #12
Rob Dublin
My Ride: 2004 E46 320cD
I miss my TT Supra
The GE is allegedly better then the GTE when turbo'd (and pretty bulletproof) so you have an excellent base.
Rob Dublin is offline   Reply With Quote
Old 08-27-2014, 10:16 AM   #13
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: used to be an auto
Why does this not have more attention
Modification Thread
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 08-27-2014, 03:57 PM   #14
Seirith
My Ride: 01 330ci
This is so crazy I am at a loss for what questions to ask first..
Seirith is offline   Reply With Quote
Old 08-27-2014, 05:05 PM   #15
rcsummers
My Ride: M3
Excited to see the progress of this.
Sub'd
"RICH"
My Build Thread
EURO.TECHNIKS
- Status Gruppe Tuning - Broadway Static - Recaro - DTM Fiberwerkz - AutoCouture Motoring -
Instagram: @summers_e46_m3
Twitter: @rcsummers0506
Xbox One: MisterMeisterM3
rcsummers is offline   Reply With Quote
Old 08-28-2014, 02:12 AM   #16
-lynel-
ROB DUBLIN for a low boost setup the higher compression GE engine will make more power and perform much better then a similarly worked GTE. Same as people people putting turbo running gear from SR20de ontot the DET where the DET with exhaust, boost controller and IC were running out of puff at 180rwkw the DE converted engines would make 200rwkw. Obviously longevity and future mods then require the lower comp DET version but if you are ever going to crack the motor open its cheaper to acquire a non turbo engine and build it. There is usually on basic differences
Old 08-28-2014, 05:15 AM   #17
Rob Dublin
Been a while since I've been down the route of looking at anything Supra related, didn't want to upset myself! Such a tuneable powerplant in TT spec, I didn't do a whole lot and still had the guts of 500 brake. Off to sob in a quiet corner.
IIRC the standard airbox was miles better than any of the rubbish aftermarket stuff, "upgrading" this often lost you power. Probably not something you can replicate on the E46 but might be worth looking at.
Old 10-13-2014, 06:21 PM   #18
Sloop
My Ride: 2001 330cic
Sub'd
"I know the voices aren't real, but man, do they come up with some great ideas"
-Jack Nicholson
Sloop is offline   Reply With Quote
Old 10-23-2014, 12:33 PM   #19
zamm333
My Ride: 2001 330ci
oh yeah, sub'd.
zamm333 is offline   Reply With Quote
Old 10-30-2014, 12:51 AM   #20
JDUTHIE
My Ride: 2003 325xi
So good to see this, just replaced the clutch on a e36 with a 2J... speaking of wich what PP are you gonna use? weve broken the straps on 3 now. This newest is the ACT extreme duty (fingers crossed.. atleast the R154 drops in like 45 min XD) Sweet car!
JDUTHIE is offline   Reply With Quote
