Old 03-14-2011, 12:39 AM   #1
SoCalTony
My Ride: 02 330i,01 Jetta VR6
Exclamation P1347 CEL on 02 330i
Let me first say that I have been searching this and other forums to see if I could fix my problem. I know that it is a cylinder #3 misfire. I just changed the spark plugs back in December when I had a cylinder #5 cold start misfire (cant remember the code).
This started about a week ago (Saturday 3-5-11) while my wife was driving the car to work. The CEL came one and car ran rough during a 75% throttle pressure. She called me from work and told me what happened, I told her to start the car and it ran fine upon restart. After pulling the code (P1347), I searched for a little bit and decided to swap the coils of cylinders #3 and #4. I took the car out on the freeway and it had no issues until I put the throttle to the floor. I then pulled over and checked the code and again it was P1347. When I restarted the car it ran fine all the way home. I told her to watch the amount of throttle she gave it and to let me know if it happened again.
Everything was running OK until this Friday (3-11-11), she had just pulled off the freeway and it occurred again. This time it there were two codes P1347 and P0128. I had her top off the coolant with distilled water for the P0128. She cleared both codes and the car started and ran fine after that.
I happened again this morning (Sunday 3-13-11) while driving a back road on her way to a soccer game. I don't know what the issue is, so I turn to you guys to see if anyone can help. Tomorrow I am planning on replacing the spark plug in cylinder #3, I'm hoping thats all it is. I guess my next step is the Fuel injector. Is that something that i could just switch with another cylinder to check? Or, am I going to just bite the bullet and buy a new one? And, how complicated is it to change an injector on our engines?
Sorry for the long story.
Thanks in advance,
Tony
SoCalTony is offline   Reply With Quote
fuel, injector, p1347, plug, spark
