Thread Tools Search this Thread Rating: Thread Rating: 29 votes, 4.86 average. Display Modes
Old 12-07-2012, 10:38 AM   #381
Hornung418
My Ride: '04 MB ZHP
Originally Posted by shm21284 View Post
I don't have that option being throttle by cable and all. I would like to have that though!
You can shortly! My conversion is almost done I have all the necessary parts, just waiting on free time to install!
Sent from my SCH-I535 using Bimmer App
Hornung418 is offline   Reply With Quote
Old 12-08-2012, 02:36 PM   #382
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
Could this help with that problem?
http://www.turnermotorsport.com/p-42...ter-plate.aspx
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is offline   Reply With Quote
Old 12-08-2012, 04:10 PM   #383
shm21284
My Ride: 323Ci M54B30 / MS43
Originally Posted by ThatGuy_JZ View Post
I made my own to fit my tuB25 throttle body onto the B30 intake. Worked perfectly, no grinding of the throttle body needed.
shm21284 is offline   Reply With Quote
Old 12-09-2012, 02:04 PM   #384
darksideracer69
My Ride: 01 325ci
The problem was most likely the o2 Sensors.
Sent from my PC36100 using Bimmer App
IMAG02051
Old 12-09-2012, 02:07 PM   #385
shm21284
The lean burn problem was definitely the o2 sensors.
Old 12-09-2012, 02:40 PM   #386
darksideracer69
My Ride: 01 325ci
And the throttle response.
IMAG02051
Old 12-10-2012, 10:14 PM   #387
serdar255
My Ride: '01 325ci / '90 325i
Where did you buy your top header flange??? I need one for my turbo build? It has to be mild steel.
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 12-12-2012, 06:35 PM   #388
shm21284
Ebay.
Old 12-12-2012, 08:28 PM   #389
serdar255
Ebay.
What did you look up? I've been looking for 30 min with no luck.
Old 12-12-2012, 10:06 PM   #390
shm21284
I think the e30, e36, and e46 have the same exhaust bolt pattern.
Old 12-12-2012, 10:13 PM   #391
serdar255
ty
Old 03-20-2013, 11:08 PM   #392
shm21284
Did you ever get this going?
Old 03-21-2013, 07:00 AM   #393
Hornung418
My Ride: '04 MB ZHP
Heres where it sits now.
Harness is halfway off and my manifold is out for vacuum line removal since I deleted the SAP almost two years ago. No need for the check valve and actuator.
CCV change Had peanut butter in my lines. Whomp whomp.
Upgraded from the return line to the M54 line and filter with built it FPR. Deleted the external junk around the filter and replaced and relocated the vac line and added the F-connector.
Scored an M54B30 TB for $40. Included a new gasket.
Ended up with an M54 harness, MS43 DME and synced EWS, 330 MAF, E-Pedal and a new lock set for $300.
Old 03-21-2013, 01:13 PM   #394
HakenTT
My Ride: 323i with S54
Update. Went to install the headers last night, turned into a disaster. .
I use this thread as a answer to all the newbs who want to make more power out of their 2.5L. Don't waste time and money like original poster did. He spent a lot of time and money just to see loss in power.
Best upgrade for 323 model E46 is putting in 2.8L rotating assembly, this way you get more power and you don't spend more than $500, and don't touch anything else.
HakenTT is offline   Reply With Quote
Old 03-21-2013, 01:23 PM   #395
shm21284
Who said I made less power? I never dynod it.
Sent from my Galaxy Nexus using Bimmer App
Old 03-21-2013, 01:24 PM   #396
shm21284
Also, who says it was a waste? I had fun doing it and am proud of the work. Let's see some of your Fab work before you call mine a waste.
Old 03-21-2013, 03:12 PM   #397
serdar255
Agreed, I like that you take pride in your work!
Old 03-21-2013, 03:45 PM   #398
HakenTT
Sent
You probably did dyno it but too embarrased to post the results.
Fact is stock air intake is not restrictive at all for 2.5L, same filter size is used on 333hp S54.
Stock cat. converter headers are restrictive but not so much on 2.5L to justify dumping so much money on custom header that weighs much more than stock. You could just use stock 96-99 E36 headers and save money that way.
Upgraded camshafts and intake manifold is another waste on 2.5L because stock just flows fine.
The 2.5L just does not flow that much to make those parts beneficial.
Software upgrade is another waste of money, it is dyno proven time and time again, that tune does not bring any power to the table. Stock euro software is as the agressive as you can get for this engine.
Stock exhaust after the cat. c. is not restrictive at all, it is huge for 2.5L flow, so another waste of money there.
All you can do to 2.5L is install catless headers, drop in K&N filter in stock air box. Get euro stock flash. Thats it, don't do anything else.
Old 03-21-2013, 04:31 PM   #399
shm21284
You're cool. Can we be friends?
Old 03-21-2013, 04:53 PM   #400
shm21284
Attachment 496487
Attachment 496491
Attachment 496488
Attachment 496489
Attachment 496490
This is pretty awesome. I'd like to see how this works out. From my scan tool, it appears the engine's flow rate becomes "choked" after 6000 RPM (If I recall correctly, the flow rate only increases by 2 kg/s from 6000-6500, a much smaller rate than from 5500-6000). I suspect that it is throttle body size. Just a suspicion.
With the MS43 DME, I believe one can improve the throttle response with a tune. Talking to an engine calibration engineer at Active Autowerke, he said that there isn't control of the throttle response (delay to shutting the throttle valve when your foot is released from the throttle pedal) on the MS42 ECU. Not sure if this applies to all tunes, but it definitely didn't change on mine after tuned (even with aluminum flywheel), while others with an MS43 ECU claim it does help throttle response.
