Thread Tools Search this Thread Rating: Thread Rating: 29 votes, 4.86 average. Display Modes
Old 03-29-2011, 10:23 PM   #41
Blocked Out
My Ride: Imola 330i M-Sport
Originally Posted by shm21284 View Post
..... there will be a pay off. ...
I doubt that. You will spend countless manhours and will never accomplish what you think you will.
Unless you love to work just for the sake of working, go ahead. If you think that your fancy headers will gain anything more then the other ones out there, you're very mistaken.
Original BMW Teile ///
IMG_1725
Old 03-29-2011, 11:21 PM   #42
shm21284
My Ride: 323Ci M54B30 / MS43
We will see :-) What do you think that I think that I will accomplish?
Do you have dyno sheets you can post of other headers (ebay, active autowerke before discontinuation, supersprint) on the M52tuB25? I saw iceman's dyno thread, but there didn't seem to be much there for that engine.
shm21284 is offline   Reply With Quote
Old 03-30-2011, 12:13 AM   #43
Iceman00
Banned User
My Ride: E90 6MT
Remember that the M52tub25 = M54B25. The M54 is blessed with a better manifold, lighter pistons and a better ems system. I would base my header design on the VE of that motor as apposed to the M52.
Old 03-30-2011, 12:15 AM   #44
Iceman00
Banned User
My Ride: E90 6MT
The equal length Technic headers and ebay/Super Sprint headers seemed to produce about the same peak power, but the Technic headers usually boast a bit more low and mid range power (not always). Of course the sample data of both is rather small (very low for Technic). The limiting factor here may be the head itself.
Old 03-30-2011, 12:37 AM   #45
shm21284
The torque curve of that engine would likely depict its different intake system. I will investigate torque curves and possibly plan for that intake, depending on expense. My intake seems to be really long. What is the approximate length of the M54B25 intake?
Old 03-30-2011, 10:13 AM   #46
shm21284
None of those headers are scavenging properly, even the Technik ones. For proper scavenging on an inline 6, in a 6-2-1 system (which they all are), you want to collect cylinders 1, 3, 5 and 2, 4, 6. Probably the reason for this incorrect header layout is that there is a packaging problem with this, as cylinders 5 and 2 need to be crossed over, and a flange needs to be added to be able to separate these headers from one another for installation and removal.
Seth
Old 03-31-2011, 09:52 PM   #47
Blocked Out
Dont have any dyno sheets as im away from home, but ive yet to see or hear of any headers that are able to produce more noticeable hp then a no name brand given they are tested on the same motor where the only variable are the headers. Regardless if they cost 50 or 1500 bucks like the active auto,theyll make same peak hp,where as some will have a 1-3tq difference in midrange but top out identical. I made my prediction in the beginning and ill stand by it given the head is untouched and no custom tune, like stated in OP. If you plan on swapping intake mani, you might pick up a few horses but theyll be high up top in the rpm range and not very usable,but they still count.
Ill be subscribed for updates,and I would like to be proven wrong.
Sent from my X10a using Bimmer App
IMG_1725
Old 04-03-2011, 01:04 AM   #48
shm21284
Here's a start. That 18.00 means I measured 18 inches. I don't hold that to the hundreth tolerance, it was a compilation of my measurement and where I took the decimal. I'm sure they aren't holding a tolerance of 0.01", although I'd like to think so. Hopefully, the other 3 primaries are able to meet the 18." length requirement.
Old 04-04-2011, 01:28 AM   #49
shm21284
Hard part almost done :-)
The damn tilted engine covers them up.
Old 04-04-2011, 06:32 AM   #50
azshorty
My Ride: Hellrot 323CI
Nice! Do you plan on making a jig for this header, or is this going to be a prototype only?
I myself would like a set like that.
azshorty is offline   Reply With Quote
Old 04-04-2011, 03:31 PM   #51
shm21284
I could reproduce these, but I'm sure they would be cost prohibitive. They would likely cost about the same as the supersprint ones. If the dyno says they make more horsepower, then perhaps it would be worth it, but we will see. Theory says they should, practice (according to the guys above) says they won't.
Seth
Old 04-05-2011, 01:17 PM   #52
Iceman00
Banned User
My Ride: E90 6MT
Best thread in this side of the forums. Period.
Old 04-05-2011, 01:18 PM   #53
secono330ci
My Ride: 04' 330ci/15' A3 TDI
WOW, nice job on the headers
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 04-10-2011, 09:58 PM   #54
shm21284
I got the headers 85% welded this weekend. I was tied up doing some other things around the shop. Here's a pic of one of the welds.
And one of the sets of primaries:
I went ahead and back-purged them since my buddy had a rig already set up. The back-purging helps much more with thinner wall tubing, but it still made the welds shinier on this thicker stuff as it helped cool the tubes slightly faster and kept the welds protected on both sides of the weld.
I still need to weld the primaries to the collectors and then onto the engine flange, but that's about it. Then I have to make the final collector and build the rest of the exhaust. The exhaust will only take a day to do, there's not a whole lot to it. The last collector and the 2 secondary pipes should also take about a day including finishing the header, so I hope to have this done in 1 more weekend of work. Unfortunately, I am still waiting on my Stromung muffler to come. I hope that comes this week.
Old 04-10-2011, 10:41 PM   #55
Iceman00
Banned User
My Ride: E90 6MT
So sick!
Old 04-11-2011, 12:53 AM   #56
brycerichert
My Ride: SC'd e46 & 2011 5.0
Regardless of what side of the fence you are on this... it's pretty cool. Wish I could do it.
Bryce
Track car: 2011 GT 5.0
E46 328i
RIP - VF blown w/meth inj. - ucc sways - TC Kline S/A - staggered
brycerichert is offline   Reply With Quote
Old 04-11-2011, 04:28 AM   #57
///Flash
Banned
My Ride: a donkey
Man....awesome for building your own headers. mad respect for you. can't wait for the results. I have Technik headers on my M52TUb25
///Flash is offline   Reply With Quote
Old 04-11-2011, 04:36 AM   #58
///Flash
Banned
My Ride: a donkey
also..here is an advice for you...make sure the headers clear the engine drain plug. the technik headers doesn't clear the engine drain plug and you can't properly conduct a coolant flush
Old 04-11-2011, 07:33 AM   #59
xdmikey
My Ride: e46 cabrio
you are one talented individual
i'll never be there but last week i changed out the primer bulb on my weed wacker
DINAN CAI, 3.46 DIFF, CDV DELETE,DINAN S2 & EXHAUST,HARDTOP
xdmikey is offline   Reply With Quote
Old 04-11-2011, 03:45 PM   #60
shm21284
Nice, do you have a dyno graph and list of other mods on the car? Those are the ones I'm most interested in comparing against.
