Thread Tools Search this Thread Rating: Thread Rating: 29 votes, 4.86 average. Display Modes
Old 04-25-2011, 12:33 AM   #81
shm21284
My Ride: 323Ci M54B30 / MS43
Update
More pics, should be done with entire system tomorrow. I must say, this is entirely too much work. I don't know if I ever want to repeat this **worn out**
3-1 Collector. Had to weld on the inside to make a complete seal. This involved dissecting the slip over part of the collector to allow room for my small TIG torch to fit inside, then re-welding the sectioned part of the collector back in. After doing this, I know there's a better way, but it is what it is.
On the car:
Welding the primaries to the engine flange:
Primaries finished!!
Started on the secondary collector. This peace is a 22deg merge style that I fabricated. It also has a 2.25" to 2.5" x 10" length megaphone on it. Here's the megaphone I made out of a normal piece of 2.5" 304 tubing:
And the entire collector:
All done for the night, hope to have it complete tomorrow!
Note that in the shots where it is bolted to the engine, the engine is being supported by a jack stand, so it is not located left to right. There is substantially more room between the primary and the frame than those shots depict.
shm21284 is offline   Reply With Quote
Old 04-25-2011, 12:58 AM   #82
Hornung418
My Ride: '04 MB ZHP
Absolutely incredible. Mad props, Seth! Can't wait for the dyno!
Hornung418 is offline   Reply With Quote
Old 04-25-2011, 09:42 AM   #83
darksideracer69
My Ride: 01 325ci
Hey Hey Hey, if these produce numbers, there has be a way for more people to get there hands on them.
Its been said before, you gots mad skills.
IMAG02051
Old 04-25-2011, 10:20 AM   #84
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Incredible work. I hope you get these coated and keep them in great shape!
Old 04-25-2011, 11:11 AM   #85
shm21284
Nope, since they are 304 they won't corrode, and to me, an aged (yellowed) stainless looks awesome.
Sent from my DROID2 using Bimmer App
Old 04-25-2011, 11:27 AM   #86
Hornung418
My Ride: '04 MB ZHP
You're not even going to wrap them? What about heat transfer? Easy way to destroy your VCG.
Old 04-25-2011, 11:42 AM   #87
shm21284
The factory gasket has a heat shield built into it to protect the valve cover and gasket
Old 04-25-2011, 11:47 AM   #88
Redline
Redline's Avatar
My Ride: ///M3 Vert
wrapping the headers destroys them, i didnt coat my headers and my engine bay isnt any hotter than before when i had the stock headers...the metal turned blue/yellow which looks kind of cool, but you can barely see the headers because of the heat shields...
k.
///M
Old 04-25-2011, 11:49 AM   #89
aggieE46
Keep it clean
aggieE46's Avatar
Are you going to be able to keep the heatshields and bolt those up? I had to remove mine to put on my Techniks.
I had mine Swain Coated. I can touch them within minutes of turning off the car. Your VCG is only a fraction of he expensive plastic/rubber under the hood. Keeping the temps down will help preserve some of it.
Either way, nice fab work.
Old 04-25-2011, 01:53 PM   #90
shm21284
Yep.
Old 04-25-2011, 04:01 PM   #91
Hornung418
My Ride: '04 MB ZHP
Yeah I wasn't sure if you were going to be able to incorporate the OEM Exhaust gaskets with the headers. Glad it's gonna work out for you! I'd still check the VCG periodically.
Old 04-25-2011, 07:21 PM   #92
murph1379
My Ride: 2006 M3
subscribed to hear about the results, it's great to see someone trying something new in the header area! =]
murph1379 is offline   Reply With Quote
Old 04-26-2011, 09:39 PM   #93
darksideracer69
My Ride: 01 325ci
Update
IMAG02051
Old 04-27-2011, 01:21 AM   #94
shm21284
Yeah, once again I over estimated my skills and didn't finish it this weekend. I still got the easy part to finish (exhaust) except I have to make hangers, which will take some time.
Old 04-27-2011, 01:30 AM   #95
Hornung418
My Ride: '04 MB ZHP
Shoot! I was hoping to see it fully mocked up this week Thanks for the update, Seth.
Old 04-27-2011, 01:54 AM   #96
shm21284
Almost forgot. Here are the secondary pipes and collector:
Old 04-27-2011, 02:22 AM   #97
Hornung418
My Ride: '04 MB ZHP
Are those 18 inches as well?
Old 04-27-2011, 07:17 PM   #98
shm21284
Yes.
I had to stop fabricating because I was tired, but also I needed to get some 2" v-bands to connect the secondary pipes up with a flanged connection. I originally got a 2.5" v-band for the outlet of the megaphone, but that v-band will not fit in the area where the megaphone ends without sticking out from under the car (and will inevitably get ripped off if I go off track or go over a speed bump). I have to stick the 2.5" v-band in the spot where the 1st muffler is, which has enough room for it. In this case, I would have a header and collector that is half the length of the vehicle! Also, I am not sure how I would bolt up the headers with the secondary pipes in the way.
On a side note, does anyone know where to find software to calibrate the stock BMW ecu? I'm pondering purchasing that instead of getting an AA tune. I believe this would be the better choice, and I could offer tuning services through Defined Autoworks.
Seth
Old 04-27-2011, 09:17 PM   #99
tropos
My Ride: E46
of course there is a slight difference in diameter of the megaphone but what happens if it was fitted the other way round? meaning bigger end at the collector?
tropos is offline   Reply With Quote
Old 04-27-2011, 10:06 PM   #100
kimodo
My Ride: Sportwagon
I don't know if this fill the bill..you can tune your own DME, but the software is tied to one DME w/ the $299 price tag. Alternatively the guy can also tune it for you..
http://forum.e46fanatics.com/showthread.php?t=740339
Cartune
http://www.mth-powerchip.de/_neu1407/
Yes.
Seth
kimodo is offline   Reply With Quote
