Sponsored by BimmerWorld
Old 03-15-2011, 02:49 PM   #1
rbaisa
My Ride: 2004 330i
If I buy this shock spring package what else do I need?
Hello all! My car has about 80k miles on it and I have been gradually replacing parts. It's a 2004 ZHP. I replaced the control arms and front bushings yesterday and I figure it is time to get some new shocks and springs before I invest in some new tires and have the front end aligned. If I get the following package, what else do I need to complete the job in terms of parts? Thanks in advance.
http://www.turnermotorsport.com/p-36...uspension.aspx
rbaisa is offline   Reply With Quote
Old 03-15-2011, 03:51 PM   #2
GA-e46
My Ride: 2001 325i
You won't per se need any other parts to complete that job. But while you are it at you might as well get a set of Rear Shock Mounts with reinforcement plates, while you are installing the rear shocks. Shock Mounts mushrooming is a common problem.
Edit: http://www.ecstuning.com/BMW-E46-330...unt/ES2075240/
This is what I am talking about. If you really want to cover every base then I would also suggest front Tie Rods and Sway Bar Endlinks also.
GA-e46 is offline   Reply With Quote
Old 03-15-2011, 04:08 PM   #3
rbaisa
My Ride: 2004 330i
Thank you, that is the info I was looking for.
Old 03-16-2011, 05:51 PM   #4
FAST_RED_M3
My Ride: 02 BMW M3, 04 SRT-4
Send a message via AIM to FAST_RED_M3 Send a message via MSN to FAST_RED_M3 Send a message via Yahoo to FAST_RED_M3
I'm still a newbie with the M3 and wanted to know if a Rear Upper Shock Mounting Kit can be used if installing coilovers rather than springs and shocks?
Thanks!
02 BMW M3
10 Acura TL SH-AWD
"German Engineering at it's finest"
FAST_RED_M3 is offline   Reply With Quote
Old 03-17-2011, 11:41 AM   #5
GA-e46
My Ride: 2001 325i
Thanks!
I don't have any experience with coil overs but I believe so. I'm sure other members with coil overs will chime in.
Old 03-17-2011, 03:01 PM   #6
ryanwhite74115
My Ride: 2013 Infiniti G37S
What about bump stops and shock boots...all that crap...do they come with the shocks...they didn't with my KYB's (for my Jetta).
ryanwhite74115 is offline   Reply With Quote
Old 03-18-2011, 10:45 AM   #7
GA-e46
My Ride: 2001 325i
You kind of just answered your own question. I know bump stops do not. You have to buy them separately. But as for the boots I'm not sure, but I dont think so.
