E46 Xi Forum
The E46 XI was produced from 01-05 in sedan and touring body styles. Powered by either a 2.5L inline 6 in the 325xi or a 3.0L inline 6 330xi. Discuss all thing about BMW AWD E46 'Xi' here. |
Rating:
Display Modes |
#41 |
@Kubica: Wow, those are some blown shocks! Thanks for the pictures and notations.
Did those E36 M3 rear shocks come with those bump stops? ![]() They definitely look heavier duty than the regular non-M one. |
#42 |
Yes. Bump stops included. Just drop the lower cup, RSM, and upper cup on, and secure with included nut. I still need to confirm that it's correct not to transfer the tiny washer used below the lower cup on the OEM and HD setups.
#43 |
#44 | |
#45 |
My Ride: 2009 328i xdrive
kubica, any updates on the ride quality of the rear shocks? I got my replacement rear shock and haven't installed yet. Curious if i should just call Keith and get the e36m3 ones instead.
![]() 2009 MBM | ZPP | ZSP | ZCW | CA | 6FL | NAV | XENONS | 18x8.5 VB3s ET30/25 |
#46 |
Just spoke with Bilstein, they are sending me a set of m3 ones in exchange for my old ones. they are aware of the issues with the hd ones, but still keep selling them...oh well, i'll keep you guys posted when i get them
#47 | |
Tough call what to do- the M3 rears are about twice the price as xi rears. |
#48 | |
#49 |
Kubica & Sharkman: Are both of you still running the 15mm upper spring pads in the rear? Also what springs are being used with this E36 M3 setup, factory sport springs?
#50 |
H&R, yes, 15mm pad.
I assume if you want the rear a bit lower, you could swap it for the thin one. In my car, the M3 shocks changed it from unpleasant to drive on bad roads to "normal BMW" feel. It is te feel I have come to expect from my bimmers.
^°^ ><((({º>°° °°° H&R Sport, Bilstein E46 Sport (Front), Bilstein E36 M3 Sport (Rear), Rogue Engineering RSMs |
#51 | |
When you have the car in the air, the length of the fully extended shocks will determine how far the rear wheels drop, but don't figure into the static ride height. Say you have stock shocks and some really, really low springs- if you did some WRC style rallying jumps, the rear springs could literally fall right out of their perches. Same with the front springs- but they'd just rotate around the strut. That's why Bilstein makes the shorter "Sport" model shocks, so the rear wheels don't drop as much when they become unloaded. Prior to speaking with Keith at Bilstein, I had incorrectly assumed the height difference between Sport vs. HD was to better zero in on the dampening sweet spot of the shock. It seems like the Bilstein Sports are the answer to the question none of us had. There's not really going to be a discernible difference between the two models paired with stock, Eibach, or H&R springs. I don't have access to the Bilstein Sports to measure, but Keith mentioned they are 20mm shorter than the HD model. That puts the height of the e36 M3 shocks exactly halfway between the height of the Sports and HDs. |
#52 | |||
#53 |
As I've posted before;
I'm on my third set of blown rear Bilstein shocks in two years... but last night I was feed up with the "clunking" noise from the back, so I installed some used M3 E46 dampers till I get my KW's. Works like a charm! |
#54 |
If you installed E46 M3 shocks and it works as you say, then I would suspect the E36 M3 & the E46 M3 shocks are the same, but they ship us the E36 simply because it is older & less likely they will sell them. Less of a hit on Bilstein financially & inventory wise. Just a guess LOL
#55 |
new rear sport shock installed. No more clunks....for now. the old one lasted 10k, lets see how this one does. The ride is so much better now, no more harshness.
#56 | |
#57 |
#58 |
Looks great, wheel gap looks good, the front looks a tiny bit higher than mine, but not much. Could be that the 18" wheels that give that effect, I have 17".
Sweet looking ride
#59 |
#60 |
So, is the stock M3 rear shock the same length as the e46 xi rear? I got that the additional width was OK; and the length was OK with lowered suspension. I could break my "no mods" rule for M3 parts.
