E46 Xi Forum
Old 03-15-2011, 11:32 PM   #1
nukeboy
My Ride: BMW 325 xi
Unhappy Severe vibration Rt side of XI only going uphill.
Hello E46'rs,
My 2005 325 XI is vibrating and shaking only when I travel at highway speeds and only uphill (those 2 parameters must be met in order to notice it). Feels like it is coming from the Right side. There is also some increased outer wear on the Right tire as opposed to the left. Also, the alignment of the vehicle is clearly off as it pulls to the left. Any ideas?
nukeboy is offline   Reply With Quote
Old 03-16-2011, 05:21 AM   #2
My white xi
My Ride: 2004 330xi
Grease your 2 front axel and you will delite your problem...the 2 boot close to front difff are out of grease...but chek all 4 of them..
My white xi is offline   Reply With Quote
Old 03-16-2011, 07:25 AM   #3
Kubica
My Ride: 2003 325xi
Sounds like an FCAB or ball joint issue.
Jack up the front right and shake the hell out of it to see if there's any play.
Old 03-16-2011, 12:12 PM   #4
nukeboy
My Ride: BMW 325 xi
Thanks Kubica and My white xi, I will check that out.
Old 03-17-2011, 09:25 AM   #5
pjo33us
My Ride: 03 330xi
In addition to the above...you might take a look at your right side motor mount.
pjo33us is offline   Reply With Quote
