Old 03-17-2011, 09:51 AM   #1
nikoloza
My Ride: 325i
Any DIY for changing brake lines
I really not wanted to start a new thead but I
Can not find compleate DIY for changing brake lines.
I did brake flush with pressure bleeder earlier with no problem but I have to change rubber lines. I need to know which side to disconnect first and put the new one on, and to do it correct way. Do they have to be twisted or there is a coupler that turns on when you put them?
Please someone who has changed them explain me how to
nikoloza is offline   Reply With Quote
Old 03-17-2011, 09:55 AM   #2
Cazz
My Ride: 2005 BMW M3
http://m3.madrussian.net/diy_front_brake_lines.shtml
http://m3.madrussian.net/diy_rear_brake_lines.shtml
Edit: The DIY is for an M3, but it should be similar enough.
Cazz is offline   Reply With Quote
Old 03-17-2011, 10:40 AM   #3
nikoloza
My Ride: 325i
Great!
Old 03-17-2011, 02:58 PM   #4
ivan300
My Ride: 2002 325i
Originally Posted by nikoloza View Post
Great!
Make sure you buy a set of line wrenches. They make it harder to strip the nut. Also I would spray penetrating lube on the coupler. Dont ask me how I know.......
ivan300 is offline   Reply With Quote
Old 03-17-2011, 03:53 PM   #5
Majorp
My Ride: 2000 328i
Thanks for asking the question and thanks to all that respond. I was looking all around for DIY for this before I asked.
"Its hard to make a man understand something when his salary depends on him not understanding it" --- Upton Sinclair
Majorp is offline   Reply With Quote
Old 11-14-2012, 08:48 AM   #6
GT172I
My Ride: M3 ZCP, 335is, 330ci
Anybody who has done this know which size flare wrenches are needed? I've seen 11mm, 14mm, and 17mm...
APEX ARC-8's | UUC EVO3 SSK | UUC TSE3-L | H&R sways
Stebel Truck Horn | Misc cosmetic stuff
GT172I is offline   Reply With Quote
Old 11-15-2012, 09:31 AM   #7
GT172I
Ok so I did this job last night and can pass on a few words of wisdom for the next who hopefully searches and finds this.
Use PB Blaster, great stuff
The order to remove:
-Remove middle attachment (bracket for rear and rubber grommet for fronts
-Break loose the connection at the caliper but don't unscrew (you can't anyways as the whole hose turns with this fitting)
-Break loose and unscrew the connection at the car side hard line
-Once hose is disconnected at this end you'll get a slow drip of fluid out so have catch pan ready
-Turn whole hose to unscrew connection at caliper
-Install in reverse order
For my 2004 330Ci (a little different from the M3 in the DIYs above):
The caliper side connection required a 14mm flare wrench (felt like a regular crescent might've worked but why risk it )
The hard line from the car was a 11mm flare
The OEM line mating with the hard line was a 17mm square so flare/line wrench wouldn't work but a standard crescent worked fine since it's really just holding it while you unscrew the 11mm flare nut.
My new Bimmerworld V2 lines were 14mm flare on both ends making that easy and fit very well. Front lines were ~3/8" longer than OEM but actually made the routing better with the hoses entering the fitting straight on instead of pulling to the side.
I also used my Motive bleeder (without pressure) on the reservoir to reduce the flow through while the line was off and but still got ~1 drip/sec. Bled it all with the new lines and have a nice firm pedal and fresh fluid. I did this more for the track than anything else and we'll see what the actual improvement is this weekend.
