Sponsored by The Tire Rack
Old 03-18-2011, 03:55 AM   #1
alexke46
My Ride: 316ci
Help with offset
Hi to all.If someone knows,i will appreciate this.Ihave just purchased 4 replica style 193m wheels for my E46 coupe offset both +37mm(front wheel 8x18,back8.5x18).Iwant to ask you guys what dimension of tires i could put,and particularly i am thinking of 225-40-18 front and 255-35-18 back.Will i have a problem of rubbing mainly at the back?If 255 is too much what should i put?Thanks in advance.
alexke46 is offline   Reply With Quote
Old 03-18-2011, 04:25 AM   #2
jassi uk
My Ride: 330d sport
You will be fine, it's like the stock setup but with the wheels sitting 13mm closer to the arches.
jassi uk is offline   Reply With Quote
Old 03-18-2011, 04:30 AM   #3
alexke46
My Ride: 316ci
I am wondering if ihave a problem when i will have people at the back,and some luggage with rubbing because i have heard alot with offsets and rubbing.
Old 03-18-2011, 10:50 AM   #4
2003 325i
My Ride: '03 Orient Blue 325i
should be fine, especially since you're a coupe.
Old 03-18-2011, 11:20 AM   #5
Penguin Koolaid
Banned
My Ride: Inline Six
You'll be fine. I run 18x8.5 et35 in the rear with a 225/40. There is certainly room for the 255. Worst case scenario, a mild fender roll will clear up any rubbing issues.
Penguin Koolaid is offline   Reply With Quote
Old 03-18-2011, 02:24 PM   #6
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
With those sizes you should be fine. If anything minor fender work will solve any rubbing.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 03-18-2011, 03:05 PM   #7
alexke46
My Ride: 316ci
I dont want to mess with frame issues.Except from 255-35-18,what other tyre could i use?
Old 03-18-2011, 04:36 PM   #8
2003 325i
In the rear 235/40 on an 8.5 wheel would keep really close to the 225/40 up front... and it's significantly cheaper.
Old 03-19-2011, 03:13 AM   #9
alexke46
My Ride: 316ci
Can i put back 245-35-18?in that case i would have wider tyres instead of 235-40-18.Someone with ET+37 8.5x18 back?
Old 03-20-2011, 05:31 PM   #10
2003 325i
245/35 18s would be fine too, but I'd go with the 235/40s as they're closer in diameter to your fronts, offer more sidewall protection, and as I said, cheaper.
Old 03-24-2011, 10:47 AM   #11
alexke46
My Ride: 316ci
Any other suggestions?
Old 03-24-2011, 01:13 PM   #12
Penguin Koolaid
Banned
My Ride: Inline Six
225/40R18 Front
235/40R18 Rear
225/40R18 Front
245/35R18 Rear
225/40R18 Front
255/35R18 Rear
You can also run 225/40R18 front and rear or 235/40R18 front and rear.
Old 03-24-2011, 10:15 PM   #13
lab rat
My Ride: '02 330iT
If you are at stock ride height. 235/40 and 255/35
If you are lowered or if you like really big girls in the back 225/40 and 245/35
Old 03-25-2011, 06:28 AM   #14
alexke46
My Ride: 316ci
I am thinking of getting lowered ,but not now.So i believe that 225-40-18 front,245-35-18 back would be the one.
Old 03-26-2011, 04:19 AM   #15
alexke46
My Ride: 316ci
By putting 225-40-18 front ,245-35-18 back will i have any false readings in my speedmeter?
Old 03-26-2011, 04:18 PM   #16
Penguin Koolaid
Banned
My Ride: Inline Six
no
Old 05-03-2013, 05:22 AM   #17
alexke46
My Ride: 316ci
anyone with 255-35-18 +37 offset back on coupe?(rubbing?)
Old 05-03-2013, 11:31 AM   #18
VMRWheels
VMRWheels's Avatar
You probably will need a fender roll for that setup.
Old 05-04-2013, 02:05 AM   #19
alexke46
My Ride: 316ci
Thanks.you suggest 245-35-18 or 235-40-18 at the back?
Old 05-08-2013, 01:24 PM   #20
alexke46
My Ride: 316ci
help?
