Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 3.00 average. Display Modes
Old 08-24-2012, 03:15 PM   #1
SPDSKTR
My Ride: E46 ZHP TS2+ Coupe
50w HID "upgrade" in OEM Bosch projectors. Explain why it's a bad idea.
Go.
Originally Posted by Brucifer325 View Post
Thread sucks so bad they moved it to the Feedback Forum.
SPDSKTR is offline   Reply With Quote
Old 08-24-2012, 11:13 PM   #2
sunnyjay
My Ride: 01 330i
driving d2s bulbs 35watt bulbs with a 50watt ballast overdrives the bulb. It produces more light at the trade off of shorter lifespan. Much shorter lifespan and the heat the bulb now creates also burns the bowls which now destroys your projectors.
sunnyjay is offline   Reply With Quote
Old 08-25-2012, 02:22 AM   #3
DOT.
My Ride: '04 ZHP Sedan
Isn't the bi-xenon actuator being power by our OEM ballast? If so, upgrading to a 50watt ballast won't be a direct swap. I'm also not to sure how OEM Bosh projectors would hold up with the added juice.
DOT. is offline   Reply With Quote
Old 08-25-2012, 03:10 AM   #4
sillieidiot
My Ride: '06 AW 330ci
this
Old 08-25-2012, 07:28 AM   #5
SPDSKTR
Originally Posted by sillieidiot View Post
this
www.theretrofitsource.com has D2S bulbs that they claim will hold up to 55W systems. Morimoto Five5.
Sent from the Bamavarian Nexus.
Old 08-25-2012, 04:12 PM   #6
sillieidiot
well we were speaking about using a ballast to overdrive the OEM bulbs. if you get an aftermarket 50w bulb, it should hold up fine. like the philips dl50.
but you run into the issue of burning your bowls. if you've ever looked at your stock bowls right now, it's probably already oxidized/lightly burned.
Old 08-25-2012, 04:34 PM   #7
BartenderPlease
My Ride: '03 540i/6 M-Sport
It will ruin the projector with the extra heat.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Fiber Trim |
BartenderPlease is offline   Reply With Quote
Old 08-25-2012, 08:56 PM   #8
SPDSKTR
I replaced my sick bowls with E46 replicas made of metal. If I get two years out of them with a high wattage system, I'd be tickled to death. The projectors were exactly like OEM, so I'm not really worried about them with the 35W system. I have a feeling they'll be okay.
Old 08-25-2012, 09:10 PM   #9
sillieidiot
oh, didn't realize you had a zhp lol well the OEM bosch bowls are made of metal, and they get the symptoms that i was referring to (the zkw bowls basically just melt/crack). it just takes a long ass time with OEM bulbs. it'll happen as a higher rate with aftermarket bulbs. i think it'll last a couple of years though. i would get high quality 50w bulbs since they tend to have a constant temp. crappy aftermarket 35w bulbs (driven with 35w ballasts) can still melt your bowls lol
Old 08-26-2012, 09:56 AM   #10
SPDSKTR
It's not a ZHP.
I plan on using the Morimoto Five5 system with the Morimoto Five5 bulbs.
I'm still waiting on infinite12 to chime in.
Another note: I don't have bi-Xenon.
Old 08-26-2012, 02:04 PM   #11
sillieidiot
It's not a ZHP.
so you had stock single xenons which already have metal bowls and replaced them with replica's that have metal bowls? ok...
anyways, i think it will last as long as you want them to. since the bowls are replica's i'm unsure how it will hold up. i know for sure that with OEM projectors, eventually they will burn up. the rate just depends on the quality of the system used.
Old 08-26-2012, 04:44 PM   #12
SPDSKTR
My old projector bowls got tarnished something awful and wouldn't polish back up. It was pretty bad. The replica projectors actually have a sharper cutoff piece in the assembly than OEM. Looks so much better! Now it needs more oomph.
Old 08-26-2012, 05:08 PM   #13
sillieidiot
yea, that's the heat. it does it on all the OEM projectors, it just takes a long as time with the OEM system.
have you tried getting better bulbs? like the 85122+ or CBI?
Old 08-26-2012, 09:04 PM   #14
SPDSKTR
I've played around with countless bulbs. Light output differences are quite negligible.
Old 08-26-2012, 09:34 PM   #15
sillieidiot
yea i guess just go for it. if you're still on the original ballasts, then those would be the next upgrade aside from bulbs, cleaning projector lens, and new headlight lens. since the ballasts output less power as it gets older. but if you're upgrading them, might as well just do the 50w. unless you want OEM only.
Old 08-26-2012, 10:36 PM   #16
SPDSKTR
I changed the projector lenses, repaved the headlight lenses, and (as you know) replaced the projectors themselves. I'll give the 50W setup a try when I get done extra money laying around. Worst case scenario, I go back to 35W. Best case scenario, my car erupts into flames and I can put the money towards something else.
Old 08-30-2012, 08:45 PM   #17
BartenderPlease
It's not a ZHP.
That's what I have, 5Five bulbs, for my fx-r. We'll be good to go
