Angel Eyes, DDEs, lighted rings, Clear Turn Signals, LEDs, Xenon, HID, or Bi-Xenon. If it lights up and you want to discuss it, post here! |
#81 |
I have a friend who has the OEM halogen headlights. He wants projector headlights, but mainly for the looks. If he is okay with the sub-par light output of the p46 headlights do you think it would be a reasonable investment to just go with them?
#82 |
I bought my M3 a year and a half ago, and it had Depo P46 projectors in them. I refused to drive the car at night because the output was so terrible, and the pattern was so weak.
I promptly took them out, and had the TFX conversion done by lightwerks. It is well worth the money and time. I could not be happier.
![]() 2002 TiAg M3 OEM 19s/Fiamm triple air horn/Valentine V1/Uniden BCD396T/Uniden XL 520 Pro/Lightwerks TFX with 55 watt kit/Mediabridge 1500/Pro Fit iPhone bracket and holder |
#83 |
Mod
Then tell him to never drive at night, ever.
#84 |
My Ride: 1999 323i 5-SPD
People keep ragging on the P46s. I had them for a year and drove in all kinds of weather without any issues. Yes, the pattern is not ideal but you can still see with them. The mini H1 conversion is quite simple and probably cheaper than the p46 set up so would recommend going that route if you want the cheapest and easiest route. But any HID kit will give more output over a halogen housing. Regardless of what anyone says. I have first hand experience with halogen, P46 and FX-R's.
Halogen < P46 < FX-R
MODS P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter |
#85 |
True, the HID kits will give you more light, but it won't put that light anywhere useful.
Take your first hand experience and shove it. |
#86 |
Just because you wanna be a jack ass doesn't mean I'm wrong. You can aim the projectors just fine. The cut off isn't going to look pretty. But you can definitely aim it. Just a matter of opinion. You didn't like it. And in the end I decided I could do better as far as lighting. But for people who would rather go a cheap route that is already pre-assembled its not the worst you can do.
#87 |
Actually it pretty much is the worst you can do. It might suffice in bigger cities with abundant street lighting, but for those who actually need headlights, the p46s are a terrible solution.
#88 |
I live in fairly rural Washington and I can see without street lights perfectly fine. You are being a jack ass, if it works it works. You don't need the best lights out there and don't need to see completely down the road. People have been driving with less output just fine for decades. The P46 work
#89 |
umnitza has the p46 and they can retrofit the fx-r into them so when u get them everything is already assembled. its a win win !
#90 | |
I really hate that arguments that say something to the effect of "people have been doing just fine without so and so innovation for ages" - Well guess what: People were doing just fine without electricity, automobiles, or modern medicine for centuries. Does that mean we should just give all that up? Last edited by TerraPhantm; 01-21-2012 at 11:15 PM. |
#91 |
Such as? Cause I'm actually in the process of considering Umnitza's all in one P46's with Fx-r upgrade and angel eyes.
Shannon.
#92 | |
I guess angel eyes might add to the cost, but... take it from someone who has them: They look better in photos than they do in person. In person the gaps are very apparent, the LEDs have a slight flicker, and they're excessively bright (washes out the rest of the headlight). I have Orion V2s fwiw. I'm probably going to get rid of mine soon |
#93 |
Thanks for the info.
Shannon.
#94 |
#95 |
Lightwerkz will even trim the shrouds for you to make it even easier. They are a recommended TRS installer. The FX-R you need to do a lot of trimming of your headlight bowls. The Mini H1s don't require any and Lightwerkz says the output is pretty close to the FX-R. If you do the Mini H1 you can easily go back to halogen.
Shoot them an email or call. They patiently answered all my questions. Last edited by Thotfulspot; 01-21-2012 at 11:56 PM. |
#96 | |
"Well guess what: People were doing just fine without electricity, automobiles, or modern medicine for centuries. Does that mean we should just give all that up?" --- That's a fallacy. Completely unrelated and we need those things in a different way then perfect light cut off. I SEE FINE. My argument is it's not necessary or even beneficial to have the best lights. Unless you have down syndrome you'll have ample time to react to something in the middle of the road or where you're going.
#97 |
Honestly, what do you think the outcome of buying P46's are? I can't actually understand why people on this thread think its a big deal. Get you're head out of your ass and quit being snooty
#98 |
I was going to buy P46s with the FX-R upgrade until doing some research. For a lot less money I could put the Mini H1 in my halogens. I can go dual projectors with the H1s for about the same price as the upgraded P46s.
I have nothing against the P46s with the FX-R upgrade. You might not think you need the perfect cutoff, but there are people like me that have to wear sunglasses until it is dark because of an eye injury. Mis-aimed high powered HIDs just about blind me. If you are set on the P46s, then do it. Just think of the other people coming at you just as much as yourself and spend some time aiming them properly. |
#99 | |
Just because you have managed with poor lights doesn't mean that there isn't a situation where they wouldn't help. Let's take antibiotics for example, there have been plenty of people who went through life without getting serious bacterial infections and lived long lives. But there are others who weren't as lucky and either died or had limbs amputated. Likewise, just because you have not been in a situation where better lighting may have been required, does not mean such situations don't exist, and does not mean other people have not benefitted from improved lighting. You are not the only one who lives in a rural area with poor street lighting. Unless you can show me a study that shows there's no safety improvement with better lights, your experiences are meaningless to me. Another big difference is the eye fatigue. I used to drive a 330i with halogens. The lights were adequate, never got into an accident, generally spotted deer from far enough to avoid them. Eventually I retrofitted OEM HIDs. By far the biggest difference was that I no longer had to strain to focus on my path. After a long drive, I didn't feel so exhausted. I was able to travel longer distances and stay alert. So just because I might be able to see with shitty headlights, it does t mean that good headlights carry no benefit And your P46s are not better than halogens. You may subjectively feel they are, but that is most likely an attempt to justify a bad purchase to yourself. And ultimately, P46s are not approved for HID bulbs. By US regulations, HID bulbs may only be D1, D2, D3, or D4 (S or R). P46 projectors are only approved for use with halogen H7 bulbs. As such, the optics are only designed for H7 bulbs. You're simply making a crappy projector perform even worse by using a bulb which emits light from a different focus This retrofit is extremely easy. Still run into a legality issue because the bulbs are H1, but at least the projector actually illuminates the road properly. Cheaper than the P46, better quality, and barely any extra work Last edited by TerraPhantm; 01-22-2012 at 01:01 PM. |
#100 |
For those of you thinking about buying the Umnitza P46 with FX-R retrofit, please reconsider or at least ask them for HEAVY documentation on the process they use to retrofit the projectors into the P46 headlights.
Here are untouched pictures from Umnitza themselves: To the seemingly incompetent person who keeps replying saying that people who care about lighting are jackasses, well, shut up. Why do you contribute to your own self humiliation? Show me an isolux diagram of your P46 headlights with 8000K HID bulbs. Show me with data and scientific measurements that your cheap knockoff parts are illuminating at anywhere near OEM level. Honestly, I can't provide that data, but at least I can take comfort in knowing that Hella, Koito, Bosch, AL, Philips, Osram, etc have done all of that for me when designing their proper HID equipment. Can Depo provide this information? |
