Go Back   E46Fanatics > New Member Introductions
New members check-in, introduce yourselves, and post a picture of your BMW here!
Old 03-18-2011, 08:43 PM   #1
daz415
My Ride: BMW 330i
Send a message via MSN to daz415
Cool BMW Abbreviations for New Members
I'm still new to the forums and learning about my BMW from other members' posts/threads. One thing confusing me is the abbreviations used for engine parts and such. I figured since I'm learning, I could help others learn as well. I did a search and found some posts with abbreviations that are used here. Below you will see the list along with the OPS of the thread.
Originally Posted by cong13 View Post
I am new to the boards and have been experiencing a learning curve when it comes to BMW/automotive specific acronyms. Using the search function on multiple boards, I came up with this list of acronyms. There are still a few I haven't found yet....
I hope this can help other newbies!
4WD = All Wheel Drive
A/C = Air Conditioning
A/D = Analog/Digital
AB = Airbag
ABS = Anti-lock Braking System
AC = Air Conditioning
ACS = AC Schnitzer
ADB = Automatic Differential Braking
AE = Angel Eyes
AFM = Air Flow Meter
AFR = Air to Fuel Ratio
ALC = Automatic Light Control
ARS = Active Roll Stabilization
ASC = Automatic Stability Control
AT = Automatic Transmission
ATF = Automatic Transmission Fluid
BBK = Big Brake Kit
BLS = Brake Light Switch
BST = Battery Safety Terminal
CAB = Control Arm Bushing
CAI = Cold Air Intake
CAS = Car Access System
CBC = Cornering Brake Control
CCFL = Cold Cathode Fluorescent Lighting
CCM = Check Control Module
CD = Control Display
CDC = Compact Disk Changer
CEL = Check Engine Light
CF = Carbon Fiber
CPS = Crank Position Sensor
CSL = Coupe Sport Lightweight
CVT = Constantly Variable Transmission
CWP = Cold Weather Package
DAE = Daytime Angel Eyes
DBC = Dynamic Brake Control
DBS = Dynamic Braking System
DCS = Dealer Communication System
DD = Daily Driver
DDE = Daytime Demon Eyes
DIS = Direct Ignition System
DIY = Do It Yourself
DME = Digital Motor Electronics
DOHC = Double Over Head Camshafts
DRL = Daytime Running Lamps
DSC = Dynamic Stability Control
DTC = Dynamic Traction Control
DTM = Deutsche Tourenwagen Meisterchaft
EAM = Electrostatic Airflow Meter
ECM = Engine Control Module
ECU = Electronic Control Unit
EDFC = Electronic Dampening Force Controller
EDIS = Electronic Distributorless Ignition System
EPROM = Erasable Programmable Read Only Memory
ETM = Electrical Troubleshooting Manual
FI = Forced induction
FTL = For The Loss
FTW = For The Win
FWD = Front Wheel Drive
H/K = Harmon/Kardon
HFM = Hot Film Meter
HID = High Intensity Discharge
HM = Hotwire Meter
HPS = Head Protection System
Hz = Hertz (Cycle)
I-Bus = Information bus
ICM = Idle Control Module
ICV = Idle Control Valve
IKE = Instrument cluster Electronics
IR = Infrared
IRS = Infrared Locking System
ISC = Idle Speed Control
ISIS = Intelligent Safety Integration System
ITB = Individual Throttle Body
LAM = Laser Airflow Meter
LCAB - Lower Control Arm Bushing
LCM = Lamp Check Module
LDP = Leak Diagnosis Pump
LEO = Law Enforcement Officer
LEV = Low Emissions Vehicle
LHD = Left-Hand Drive
LSD = Limited Slip Differential
MAF = Mass Air Flow sensor
MAM = Mass Air Meter
MBC = Maximum Brake Control
MF = Micro Fiber
MMC = Multi-Media Changer
MRS = Multiple Restraint System
MT = Manual Transmission
MV = Magnetic Valve (solenoid Valve)
MoDiC = Mobile Diagnostic Computer
NAVI = Navigation module
NOS = Nitrous Oxide Systems
NOX = Nitrogen Oxides/ exhaust gas recirculation (from ETK)
O2 = Oxygen (sensor)
OBC = On Board Computer
OBD = On Board Diagnostics
OEM = Original Equipment Manufacturer
P-Bus = Periphery bus
P/N = Park/Neutral position
PCV = Positive Crankcase Ventilation valve
PDC = Park Distance Control
PGS = Passive Go System
PM = Power Module
PO = Previous Owner
PP = Premium Package
PSI = Pounds Per Square Inch
PTC = Positive Temperature Coefficient
PWG = Pedal position sensor/ potentiometer
RAM = Random Access Memory
RDC = tire pressure Control
RDS = Radio Data-broadcast System
RHD = Right-Hand Drive
RLS = Rain-Light Sensor
RM = Relay Module
RPS = Rollover Protection System
RSM = Rear Shock Mount
RTAB = Rear Trailing Arm Bushing
RWD = Rear Wheel Drive
S/C = Supercharger
SM = Street Modified
SOHC - Single Overhead Cam
SP = Sport Package
SRS = Supplemental Restraint System
SS = Stainless Steel
SSK = Short Shift Kit
Step = Steptronic transmission
TCS = Traction Control System
TDC = Top Dead Center
TIS = Technische Information System
TME = Transmission Mount Enforcer
TRE = Tie Rod End
VAM = Volumetric Airflow Meter
VANOS = Variable Lift and Timing System
VIN = Vehicle Identification Number
VTEC = Variable Timing and Lift Electronic Control
VVTI = Variable Valve Timing and Lift (With Intelligence)
WOT = Wide Open Throttle
ZCP = BMW Competition Package (M3 Only)
ZCW = BMW Cold Weather Package
ZHP = BMW Performance Package (Available on US-Market 330i/Ci/Cic Only)
ZPP = BMW Premium Package
ZSP = BMW Sport Package
Originally Posted by MarvelPhx View Post
Here, chew on this:
Here are a bunch of BMW abbreviations with German translation (sometimes it explains the abbreviation)
ABS - Anti-Lock Braking System (Antiblockiersystem)
ACC - Active Cruise Control
A/D - Analog to Digital
AFS - Active Front Steering
AHPS - Advanced Head Protection System
AIC - Automatic Interval Control (Automatic Intervall Control/Regensensor)
AITS - Advanced Inflatable Tubular Structure see AHPS
AKS - Active Head Restraint System (Aktive Kopfstutze)
ARS - Active Roll Stabilization (Aktive Rollstabilisierung)
ASE - Advanced Safety Electronics
ASK - Audio System Controller (Audio-System-Kontroller)
AWL - Airbag Warning Lamp
BLS - Brake Light Switch (Bremslichtschalter)
BMW - Bavarian Motor Works (Bayerische Motoren Werke)
BST - Battery Safety Terminal
BZM - Center Console Control Center (Bedienzentrum Mittelkonsole)
CAN - Controller Area Network
CIP - Coding Individualization and Programming
DISA - Differential Intake Air Control (Differenzierte Sauganlage)
DSC - Dynamic Stablity Control (Dynamische Stabilitats Control)
DTC - Diagnostic Trouble Code or Dynamic Traction Control
EBV - Electronic Brake Force Distribution (Elektronische Bremskraftverteilung)
ECO - Electronically Controlled Orifice
EDC - Electronic Damper Control (Elektronische Dampfer Steuerung)
EHC - Electronic Height Control (Elektronische Hohenstands Control)
EKP - Electric Fuel Pump (Elektrische Kraftstoffpumpe)
EML - Electronic Motor Load Regulation (Electronische Motorleistungsregulierung)
EWS - Electronic Driveaway Protection (Elektronische Wegfahsperre)
FA - Vehicle Order (Fahrzeug-Auftrag)
FB - Functional Description (Funktionsbestatigung)
FIRST - Fully Integrated Road Safety Technology
GPS - Global Positioning System
GM - General Module (Grundmodul)
GRAV - Gewichtsreduzierter Aluminiumvorderbau (E60 Aluminum process)
HDC - Hill Descent Control
HFM - Hot Film Air Mass Meter (Heibfilm-Luftmassenmesser)
HLM - Hot Wire Air Mass Meter (Hitzdraht-Luftmassenmesser)
HPS - Head Protection System
HUD - Heads Up Display
IBS - Intelligent Battery Sensor
IKE - Instrument Cluster Electronics (Instrumentenkombination-Elektonik)
ISIS - Intelligent Safety Information System (Intelligentes Sicherheits-und Informations-System)
ISN - Individual Serial Number or Individual Control Unit Number
ITS - Inflatable Tubular Structure
KBM - Body Basic Module (Karosserie-Basis-Modul)
Kombi- Cluster in German
LCM - Lamp Check Module (Lamp Kontrol Modul)
LDP - Leak Diagnosis Pump
LED - Light Emitting Diode
LEV - Low Emissions Vehicle
LIN - Local Interconnect Network
LL - Idle or Closed Throttle Position (Leerlauf)
LRE - Steering Wheel Electronics
LSE - Steering Column Electronics
LSZ - Light Switching Center (Lightschaltzentrum)
M-ASK - Multi-Audio System Controller (Multi-Audio-System-Kontroller)
MBC - Maximum Brake Control
MDK - Motorized Throttle Valve (Motorische Drosselklappe)
MID - Multi Information Display
MOST - Media Oriented System Transport
MRS - Multiple Restraint System (Mehrfach-Ruckhaltesystem)
MRSA - Side Impact Sensor
MSR - Deceleration Slip Regulation or Engine Drag Torque Reduction (Motorschleppmomentregelung)
NVRAM - Non-Volatile Random Access Memory
OBC - On Board Computer
OBD - On Board Diagnostics
OC-3 - Occupant Classifier-3
OPPS - Optic Testing and Programming Systems (Optisches Pruf-und Programmiersystem)
OPS - Optic Programming System
ORVR - On Board Refueling and Vapor Recovery
PDC - Park Distance Control
PTC - Positive Temperature Coefficient
PuMA - (Problem-und Mebnahmenmanagement Aftersales)
PWG - Pedal Position Sensor (Pedalwertgeber)
PWM - Pulse Width Modulation (Pulseweitenmodulation)
RAM - Random Access Memory
RDC - Tire Pressure Control (Reifen Druck Control)
RDW - Tire Pressure Warning System (Reifendruckwarnung)
RLS - Rain and Light Sensor
RPS - Rollover Protection System
RXD - Wake-up Diagnosis Line
RZV - Direct Stationary Ignition (Rehende Zundspannungsverteilung)
SAC - Self Adjusting Clutch (Selbstnachstellende Kupplung)
SAE - Society of Automotive Engineers
SASL - Satellite A-Pillar, Left (Satellit A-Saule Links)
SASR - Satellite A-Pillar, Right (Satellie A-Saule Rechts)
SBE - Passenger Seat Occupancy Detection System (Sitzbelegungserkennung)
SBK - see BST (Safety Batterie Klemme)
SBSL - B-Pillar Satellite, Left (Satellit B-Saule Links)
SBSR - B-Pillar Satellite, Right (Satellit B-Saule Recht)
S/E - Send and Receive
SFZ - Center Vehicle Satellite (Satellit Fahrzueg Zentrum)
SG - Control Unit (Steuergerat)
SGM - Safety and Gateway Module (Safety Gateway Modul)
SGS - Seat Integrated Belt System (Sitzintegriertes Gurtsystem)
SIA - Service Interval Indicator (Service-Intervall-Anzeige)
SIM - Safety and Information Module (sicherheits-Informationsmodul)
SLP - Secondary Air Pump (Sekundar-Luft-Pumpe)
SMBF - Seat Module, Passenger (Sitzmodul Beifahrer)
SMFA - Seat Module, Driver (Sitzmodul Fahrer)
SMG - Sequential Manual Gearbox (Sequenzielles M Getriebe or Sequenzielles Manualles Schalt-Getriebe)
SRS - Supplemental Restraint System
SSBF - Seat Satellite, Passenger (Satellit Beifahrersitz)
SSFA - Seat Satellite, Driver (Satellite Fahrersitz)
SSH - Seat Satellite, Rear
STVL - Door Satellite, Front Left (Satellit Tur Vorne Links)
STVR - Door Satellite, Front Right (Satellite Tur Vorne Recht)
SULEV - Super Ultra-Low Emissions Vehicle
SZL - Steering Column Switch Center (Schaltzentrum Lenksaule)
SZM - Switching Center Console (Schaltzentrum Mittelkonsole)
TCU - Telematics Control Unit
TMBF - Door Satellite, Passenger Door (Tur Modul Beifahrer)
TMFA - Door Satellite, Driver (Tur Modul Fahrer)
URSS - see RPS (Uberroll Shultz System)
VANOS - Variable Camshaft Control (Variable Nocken-Steuerung or Variable Nockenwellen-Steuerung)
VVT - Variable Valve Timing (Variable Ventiltrieb)
ZAE - Central Activation Electronics (Zentrale Auslose Elektronik)
ZCS - Central Coding Key
ZGM - Central Gateway Module (Zentral Gateway Modul)
ZKE - Central Body Electronics (Zentrale Karosserieelektronik)
ZWD - Idle Control Valve (Zweiwicklungs Leerlauf-Drehsteller)
These are the car itself, not option codes used when ordering...
R/C/R or RCR= Red Clear Red, referring to color scheme of taillights.
Hopefully, the Mods/Owners will sticky this and help out other new members! There may be others so feel free to add to thread. Peace Fanatics!
daz415 is offline   Reply With Quote
Old 05-04-2011, 09:26 PM   #2
rg1bmw
My Ride: 2002 Infiniti Q45
Welcome
2002 BMW 530i
Black Leather/5 Speed/Sport Package
rg1bmw is offline   Reply With Quote
Old 12-13-2012, 01:23 AM   #3
xcar360
Past Site Sponsor
My Ride: BMW 318i
Great Job, thanks
xcar360 is offline   Reply With Quote
Old 12-13-2012, 03:07 AM   #4
JTripper
My Ride: 3dirtyci
Irie thread!
@BMWorNADA
BMWCCA
///MPIREBOYZ#239
1st Gen. AC Schnitzer Strut Bar, M3 Face, Gunmetal VMR V710FF 18x8.5/9.5 , AEM Logger & longtube CAI, H&R Sport Cup Springs and Front Struts, Koni Rears, Reinforced Towers, Int. Trim Wrapped, Custom FX-R Retrofit , 3k Fogs, Frosted WeissLichts, 8 Track Player with Dolby.
JTripper is offline   Reply With Quote
Old 12-15-2012, 11:53 AM   #5
illestminimike
My Ride: Project Drama
Welcome. Thanks
Display Modes
