Sponsored by BimmerWorld
Old 03-20-2011, 12:55 PM   #1
Jayfree
My Ride: 328i
19inch on the rear of 330 zhp
Just put on a set of 19teens on my 04..330..19 by 9 half in rear .. Touching fender on dips and some turns what does this mean new shocks or what???
Jayfree is offline   Reply With Quote
Old 03-20-2011, 12:58 PM   #2
euG!
My Ride: ZHP SALOON
Send a message via AIM to euG!
Tire size?
Suspension?
Wheel Offset?
euG! is offline   Reply With Quote
Old 03-20-2011, 01:23 PM   #3
Jayfree
My Ride: 328i
265/30/19.......120...43 or 35.. For the rear....235/35/19 front
Old 03-20-2011, 01:31 PM   #4
SLO Town
SLO Town's Avatar
My Ride: 2003 330Ci
265/30s on the rear will never fit, regardless of the wheel's offset.
Original Owner 2003 330Ci ZSP, 3145 lbs, 5-spd, leather, Alcantara wheel, 19x8.5" BBS, RE-11s, ZHP FCAs/diff cover/weighted knob, M3 eng + trans mounts/outer RCABs/RCABs with Turner limiters, Group N inner RCABs, Bilstein Sports (E36 M3 rears), Eibach P-K, H&R bars, BMW Performance Rotors, Turner caliper bushings, StopTech lines, Borla, RE pullies/RSM, Stewart WP, M-Technic Trunk Spoiler, Mason pedal/strut bar/end links, B&M shifter, UUC DSSR
SLO Town is offline   Reply With Quote
Old 03-20-2011, 01:37 PM   #5
Jayfree
My Ride: 328i
That's what was recommended when I purchased them!!
Old 03-20-2011, 02:19 PM   #6
BusaNoob
My Ride: AW 06 330ci ZHP
I run 265/30/19 with no problems even with passengers. Stock suspension ? Do you have a coupe or sedan ? The coupe has more fender space...
BusaNoob is offline   Reply With Quote
Old 03-20-2011, 02:25 PM   #7
SLO Town
SLO Town's Avatar
My Ride: 2003 330Ci
Who did you buy them from?
I have BBS CH 19x9.5 40mm offset with 245/35s. This is the absolutely maximum wheel/tire size combo that will fit in my stock wheel wells. I've run the suspension through it's travel while on jack stands - minus springs, shocks and anti-roll bar disconnected - I have 1mm MAX of clearance between the outer tire sidewall and the plastic fender liner behind the tire (at the 3 o'clock position as you're looking at the car from the side).
Using a 245/35 with a more square shoulder would hit. I've run both 245/35 PS2s and ContiSportContact 3s, both of which have more rounded shoulders, and they just barely clear.
You were given bad advice on the wheel/tire combo they sold you, unless they expected you to make fender lip/liner modifications.
Old 03-20-2011, 02:52 PM   #8
Jayfree
My Ride: 328i
Nexxen N3000 tires.just not sure do I change shocks or springs or both.. Purchased from element tires!
Old 03-24-2011, 10:27 PM   #9
B6T
My Ride: 330Ci
Those tires suck... I blew through a set in one summer.
B6T is offline   Reply With Quote
Old 03-24-2011, 10:30 PM   #10
Gheybe
Gheybe's Avatar
My Ride: F80 M3
They probably thought you had an M3. That's about stock size for M3.
You're gonna have to roll your fenders, run camber, and other things to make those fit.
Gheybe is offline   Reply With Quote
