Old 03-20-2011, 10:23 PM   #1
the_del
My Ride: 1999 323i
Yellow oil light only on start
I have a 1999 323i. Most of the time when i start the car the yellow oil light comes on for a few seconds and then goes off. Does not come on when im driving. The oil level is NOT low. i may be be in need of an oil change though. is that the indicator that i need an oil change? i bought the car a few weeks ago and theres no manual. I check the oil level everyday, and its perfect level. Any ideas what it could be? Thanks!
the_del is offline   Reply With Quote
Old 03-20-2011, 10:30 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Oil level sensor. Next time search the forum. These cars have been around for 12 years, so it MUST have been asked already...
Old 03-20-2011, 10:35 PM   #3
the_del
My Ride: 1999 323i
Sorry... Thanks
Old 03-20-2011, 10:47 PM   #4
deebar325i
My Ride: 2004 BMW 325i
yes its the sensor i got to change mine also. does the same thing. ^ and dont appologize for asking a question. so guys here are complete *******s to new guys.
deebar325i is offline   Reply With Quote
Old 03-20-2011, 10:48 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
Originally Posted by the_del View Post
Sorry... Thanks
No need to be sorry, just a reminder
Old 03-21-2011, 02:24 PM   #6
Nicanagua
My Ride: 2000 BMW 323I
I have the same problem on my 00 323i purchased about a month ago , i was told it might be the low oil level sensor .
Nicanagua is offline   Reply With Quote
Old 03-21-2011, 04:52 PM   #7
rjh325
My Ride: 325i
I replaced mine last week. (2) of the (3) nuts were seized and the entire threaded shaft and nut came out in one piece as if it was a bolt. I tried to unseize them, gave up and just screwed them in with no problems.
rjh325 is offline   Reply With Quote
Old 03-21-2011, 07:02 PM   #8
motegi18s
My Ride: BMW 325i
I promise you the oil level sensor is bad. Super easy DIY. Sensor is about $50ish. Do it with your next oil change.
motegi18s is offline   Reply With Quote
Old 03-21-2011, 07:08 PM   #9
bwallace530
My Ride: 325
Oil level sensor mine when out a couple months back
bwallace530 is offline   Reply With Quote
Old 03-21-2011, 07:11 PM   #10
djnekkon
My Ride: MB3ci & z33 HR
I need to do mine. Until next oil change of curz
Old 03-21-2011, 07:51 PM   #11
El Polo
My Ride: 99 black 328i
That is a simple question that has been answered a thousand times... OK we know that now.
OP use search next time... OK you know that now.
BUT! there is actually another point that I would like to make about this sensor: mine is shot too, and has been for a long time. The light always comes on a few seconds and then disappears. Doesn't bother me that much, I check the oil level every now and then. But when I do my oil change, on the first start after refilling, the light actually lights up in RED, meaning the oil level is critically low. We all know that this is normal for the first second or two, the time for fresh oil to make its way around the whole thing.
So, knowing that the sensor is bad, why is the light working in that specific situation? are there multiple sensors that can trigger the oil light?
1-There must be another sensor or another way the ECU knows the level is critically low
or
2-The sensor is half-dead, but can still detect a critically low oil level
Any thoughts guys?
El Polo is offline   Reply With Quote
Old 03-21-2011, 08:45 PM   #12
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
or
Any thoughts guys?
3.
It's not detecting that it's critically low - the oil pressure sensor (different than the oil level sensor) is detecting that there is no pressure in the system which happens momentarily after you drain the system out and replace the filter.
/// MODS
Old 03-22-2011, 08:51 AM   #13
rjh325
My Ride: 325i
I never threw any oil lights and found an oil sender code(27C3 Signal oil level sensor (TOENS) while troubleshooting a check engine light due to a bad secondary check valve. Once I replaced the oil level sender, the code went away.
Old 03-22-2011, 11:26 AM   #14
AJV
My Ride: 164 Quadrifoglio
I have that in my 325 and it scares anyone who gets in the car other than me. It first happened on a business trip, which startled me but after checking the forum I said screw it, it'll be fine. Next oil change I will fix it. I'm assuming the oil pan comes off and it's up there, but haven't researched it. Will do when time comes.
AJV is offline   Reply With Quote
Old 03-22-2011, 11:32 AM   #15
lkchris
My Ride: Friends' BMWs
Hey, the light HAS to come on a little bit when you start the car as a "test" so you know the bulb isn't burned out.
lkchris is offline   Reply With Quote
Old 03-23-2011, 07:14 PM   #16
AJV
The light that comes on when you turn the car on is red. It goes off, as it should, and the motor run for about ten seconds and the yellow light will come on. It will stay on for around ten seconds and then turn off.
And lights don't come on to test the bulbs. The lights all come on because the car is running a diagnostic, and once each system checks out, its respective light goes out.
Old 03-23-2011, 07:37 PM   #17
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I'm going on a few thousand with this light...no big deal really.
I like it coming on after 5 secs. and going off 15 secs. later. For me, I see that as telling me it's working...maybe not correctly, but working.
I'll get it in another 7-8K miles.
3 screws and it's off...it's a temp sensor with some amazing sensitivity, so I'm not surprised after 200K miles that it's a little old. But that amazes me...a sensor that survives all that.
I removed mine to look at it...sprayed it clean and then prayed hoping the new oil would fix it...but it didn't. It's broken. Monitor oil more often if you have one and pay attention if it changes its broken behavior.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 03-24-2011, 07:45 AM   #18
TitaniumCranium
/// Limitless
The oil level sender is dead, D E A D, dead. This is exactly the default behavior of this sensor when it is no longer functioning. There are two holes in the body of the oil level sender that allow oil to bath a fillament. When the sender is working properly the filliment receives a small amount of current to determine the resistance of the circuit which changes depending on how much of the filliment is submerged in oil.
This sender often fails when "quick lube" places turn the car off but leave the ignition on and flush the oil from the system. This exposes the entire fillament with no oil bathing and cooling the fillament. The fillament heats up and burns out.
/// MODS
Old 03-24-2011, 02:34 PM   #19
dmax
dmax's Avatar
It's just pining.
Why didn't you tell me this before I drained my oil?
IDK, I've read here that most of our parts are lifetime, so I think if I keep it in long enough, it'll resurrect itself. Immaculate reconnection. You wait!
In the meanwhile, thanks for your explanation...first time I'd heard that! I thought it was just not feeling well! So you're confident that it would not signal a low oil situation? That makes me view it quite a bit differently, and I appreciate the heads up!
Will drain oil and fix it shortly!
Thanks, TiCran!
See me in June!
dmax on Facebook
Mangofy your E46!
Old 03-24-2011, 02:40 PM   #20
Penguin Koolaid
Banned
My Ride: Inline Six
Bad oil level sensor. You need to replace it. Be sure to check your oil level on a regular basis (every other day if not daily) to ensure that it's not too low. The sensor will not detect low oil levels.
Penguin Koolaid is offline   Reply With Quote
