Thread Tools Search this Thread Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
Old 03-21-2011, 02:32 PM   #1
ec2785ny
My Ride: 99 323i
Question dme flash after auto to manual switch
I have a 99 323i sedan(e46) and recently changed the tranny from an auto to a manual. Live in the new york area and can not find anywhere that can help me change this dme to recognise the car is manual, even dealers. Right now the check engine light and gear symbol "cog" are lit on the dash and it is time i ask for some suggestions. Any help ppl???
Car runs well but I want to get these lights off on the dash.
ec2785ny is offline   Reply With Quote
Old 03-21-2011, 02:47 PM   #2
Avet4
My Ride: 2004 330i 6spd
Hmm, I always thought that the car wouldn't even start if you didn't have the DME reflashed, I read that people would have to push start their cars after a manual swap until they could get the DME taken care of.
As far as who can do it, I'm guessing Active Autowerks or ESS can reflash it, but other members got it done at the dealer. Hopefully they'll chime in soon.
Avet4 is offline   Reply With Quote
Old 03-21-2011, 02:55 PM   #3
alpine325i
My Ride: Alpine 2001 325i
I asked a couple of indi shops and was told the dealership is the only place that can do it... Still haven't done it to mine yet and its been almost a year now! Planning on dong it soon.
WTB: KOSEI K1'S 17X8.5
alpine325i is offline   Reply With Quote
Old 03-21-2011, 03:02 PM   #4
ec2785ny
My Ride: 99 323i
no they run
Here are the pics of the swap.. after it was done it runs good but I still want it legit.
ID:	397548   Click image for larger version
ID:	397549   Click image for larger version
ID:	397550   Click image for larger version
Old 03-21-2011, 06:29 PM   #5
TerraPhantm
My Ride: M3 & ZHP
If you can get me the numbers printed on top of a stock 323 manual DME, I could probably do this.
Old 03-21-2011, 09:51 PM   #6
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Depending on the CAR ZCS or VO must be changed. then the DME programed number changed to a manuel
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 03-21-2011, 10:45 PM   #7
xavi330i
My Ride: 2004 330i smg
You need a manual cluster and transfer over vin and mileage.
That is how i got my smg to manual to start after swap.
xavi330i is offline   Reply With Quote
Old 03-21-2011, 11:05 PM   #8
jbeurotech
Regional Sponsor
umm no just need to change zcs or vo
Seth Thorson
Old 03-21-2011, 11:51 PM   #9
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
The cars built prior to build date 09/2001 use SA numbers that must be recoded into the instrument cluster (KOMBI) and then auto program the LCM, ASC/DSC, and align the EWS with the DME.
/// MODS
Old 03-22-2011, 01:35 AM   #10
TerraPhantm
My Ride: M3 & ZHP
ZCS/FA editing is the easy part since all the information on what the numbers mean is documented by BMW. Figuring out the proper DME program number without access to a real manual is the hard part - I can't find documentation that tells which car the data files correspond to for the ms42 and ms43 DMEs. MSS54 files on the other the hand are very nicely commented and identify exactly which car the file is intended for (US, euro, or japan; M3, CSL or Z3M; SMG or manual).
Do you know if there's an official BMW document which identifies the DME software versions?
Not necessary. While it's true the manual clusters don't have the LCD, you can easily just recode an auto cluster. Recoding it turns that extra display off.
Old 03-22-2011, 01:42 AM   #11
rising
Banned
My Ride: E46
date 09/2001?? a little old stuff.
rising is offline   Reply With Quote
Old 03-22-2011, 01:48 AM   #12
Elwin
My Ride: 330i ZHP
You need to have:
1. SSS progman
2. NCS Expert
With NCS expert you must change the FA code to remove S205A (automatic transmission). then code all car with NSC Expert.
When done with coding you car will think it is manual, but maps in the engine will be as for automatic.
Hee you will need to use SSS progman and program DME. To be safe I would program cluster, DSC and EWS as well with SSS progman.
Now you will be all manual
Elwin is offline   Reply With Quote
Old 03-22-2011, 01:50 AM   #13
TitaniumCranium
/// Limitless
Yes The OP's original thread stated 99 - 323 so they are using SA codes and 09/2001 is using the VO for programming the various modules.
/// MODS
Old 03-22-2011, 02:09 AM   #14
TerraPhantm
My Ride: M3 & ZHP
Originally Posted by Elwin View Post
You need to have:
1. SSS progman
2. NCS Expert
SSS/Progman won't reprogram the DME with a manual flash unless you manually identify the software number. The DME version isnt determined by the VO; it's determined by what the UIF says the existing software version is.
You're also better off using winkfp if you're not using the real Progman. Winkfp is both faster and safer since it doesn't have to go through a VM and virtual network... Nor does it need any "hacky" modifications to work.
Old 03-22-2011, 07:57 AM   #15
jbeurotech
Regional Sponsor
The programed number can be gotten via real OEM or numerous service SIB's. The info is there. I have programed 7-8 of these cars after swaps I do know a little about it....
And also those numbers for SA/fa used to not be that well documented it was through work of certain people that they became know. Do some searching on early threads about this. There was not much info out there for a long time.
Seth Thorson
Old 03-24-2011, 08:57 PM   #16
TerraPhantm
My Ride: M3 & ZHP
They're all very well documented in the data folders right on the Progman DVD. Admittedly it's mostly in German, but the info is all there and has been for years. This stuff was written by BMW. Check the links below E46AT.000 for all the VO information, and E46ZST.000 for all the ZCS information. There are similar files available for every chasis. The ZCS ones are particularly useful since it tells you how to calculate the new checksum and everything. FA isn't as necessary since the numbers are the same as the option codes themselves. It is useful for figuring out the proper H-words/E-words/K-words for various retrofits though
E46AT.000
E46ZST.000
Where on RealOEM are the programmed numbers btw? I can only find the hardware numbers, which are kinda useless since tons of cars use the same DME hardware.
Old 03-24-2011, 10:53 PM   #17
iansanderson
My Ride: 2001 330CiC
OP, there are only a few people you should be listening to in this particular thread. me, JBeurotech, terraphantm and TitaniumCranium.
terra, the program numbers are the last 7 of the programmed DME part numbers in the catalogs such as ETK and bmwfans.info. For my car (MT Cabrio, MS43 built before july 2002), the latest software is 7571613 as can be seen in the parts catalog:
http://bmwfans.info/parts/catalog/E4...me_programmed/
OP's car can be found here:
for whatever reason, some models do not show a different program number for auto and manual. But MS45.1's built after July 2004 do:
http://bmwfans.info/parts/catalog/E4..._programmed-2/
Properly, what the OP needs to do is first remove the 3 blue wires connecting the EGS to the DME. then, he needs to update his ZCS to reflect a manual transmission in his instrument cluster and EWS using an old MoDiC system, Progman (selecting an E34 chassis) or NCS Expert. The manual conversion involves changing the last 2 digits of the ZCS string. Then, perform a whole car encoding followed by a DME software update, and his car will be a manual.
Neil1138 detailed the entire process with coding in "Step 12" of his 5MT conversion which can be seen here:
http://forum.e46fanatics.com/showthread.php?t=659314
OP will need to post his ZCS string so it can be converted, then follow the instructions above and the cog and SES lights should turn off.
Cheat Sheet:
GT1/ISIS/MoDiC = Factory authorized diagnostic system used by BMW dealerships across the world.
NCS Expert = BMW Factory R&D programming tool available on the internet (not intended for the public and not available to the dealership network)
OEM = Genuine BMW part only available from a franchised BMW dealership.
DME = Engine Management Computer
iansanderson is offline   Reply With Quote
Old 03-24-2011, 11:00 PM   #18
genuity
My Ride: 2001 330iS
Originally Posted by iansanderson View Post
Neil1138 detailed the entire process in "Step 12" of his 5MT conversion which can be seen here:
Neil's process forgets to mention LSZ recoding
genuity is offline   Reply With Quote
Old 03-24-2011, 11:26 PM   #19
TerraPhantm
My Ride: M3 & ZHP
for whatever reason, some models do not have a different program numbers for auto and manual. But MS45.1's built after July 2004 do:
OP will need to post his ZCS key so it can be converted, then follow the instructions above and the cog and SES lights should turn off.
Thanks for the info! I was getting stuck w/ realOEM since they seem to omit the "DME Unit - programmed" entries. That makes things a lot easier!
Edit: Do you know when the last time BMWfans.info was updated? My current DME version (which is the latest) doesn't agree with what that site. I know the E46 M3 was recently updated (Summer 09) because of the emissions recall though, so maybe that's the issue
Edit 2: My old ZHPs DME software does match that site, so I guess it's okay. It's just the database is from a release before Summer 09.
Neils car wouldn't need any LSZ recoding...
Old 03-24-2011, 11:29 PM   #20
jmay87
jmay87's Avatar
My Ride: e36,e46,e90
Subscribing to this thread so I can find it later
Sent from my Thunderbolt using Bimmer App
--1995 E36 M3--2001 E46 325i--2008 E90 335i--
jmay87 is offline   Reply With Quote
auto to manual, dme, e46, flash dme, tranny
