Old 03-22-2011, 06:27 PM   #1
jgold47
My Ride: 2004 X5 3.0
water in trunk in strange area
I found water in my trunk today in the strangest area. We have had some pretty crazy rain the last couple of days, and will admit to perhaps not noticing it untill now, but there is a puddle in the drivers side (cup/cubby). Whats strange about it is that nothing else is wet. not the carpet, not around the tail lights (which are aftermarket RCR's). Given the way the cubby is shaped, the only way for water to get in there would be to have dripped in from the top, but thats sealed by the weather stripping. I had my emblem off over the weekend, but the trunk liner wasnt wet on top. Anyone have any thoughts, I am at my wits end....
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 03-22-2011, 06:31 PM   #2
MrAdam
My Ride: S.L.O.W.
OEM trunk? my csl rep trunk didn't seal correctly around the key hole. and the spare tire area was a puddle. nothing in the trunk was wet at all. I found the problem by getting in the trunk with a flash light and having someone hose the car down. DO THAT! Good Luck
~Adam
NEED BODY SHOP ADVICE?
135i REPAIR THREAD
911 REPAIR THREAD
MrAdam is offline   Reply With Quote
Old 03-22-2011, 07:46 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I'll guess the taillight housing...and think guys have used silicone of some sort to seal it up...don't know if the gasket around lens is available.
Second guess...pine needles clogging the drain in your trunk lid and you have a crack in the gasket.
Third guess...you have a drain pipe that separated from its fitting in the C pillar and it found its way into that spot...but I think it otherwise drains in front of rear wheel at end of rocker panel.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 03-22-2011, 09:11 PM   #4
Bimmerboi325i
My Ride: needs a wash
I have the same exact problem lemme know if u find a way to fix it
jessica.
Bimmerboi325i is offline   Reply With Quote
Old 03-22-2011, 10:22 PM   #5
325beemer
My Ride: 2001 325ci
same problem. first i thought it was a taillight seal problem. so i sealed the **** out of it with some epoxy sealer or some ****. still water in the same spot. no clue.
325beemer is offline   Reply With Quote
