Sponsored by BimmerWorld
Old 03-22-2011, 07:07 PM   #1
stevenluczynski
My Ride: Is Steel Blue
Suspension torque specs
I'm About to install lowering springs on my 04 325i and wanted to know if anyone has a list or diagram of all the torque specs for Front and rear suspension.
-Thanks
stevenluczynski is offline   Reply With Quote
Old 03-22-2011, 07:50 PM   #2
stevenluczynski
anyone with a Bentley?
Old 03-22-2011, 08:24 PM   #3
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
My scanner sucks so here goes:
Front Suspension
M8 self-locking nut (x3 at top of strut housing) - 18ft-lb for nuts with 18mm flange, 25ft-lb for nuts with 21mm flange
M14 upper strut mount to strut shaft, self-locking nut (x1) - 47ft-lbs
steering arm pinch bolt at strut housing - 60ft-lb
Rear Suspension
M10 upper strut mount to strut shaft, self-locking nut (x1) - 10ft-lb
M8 self-locking nut (x2 I think, at top of strut housing) - 17ft-lb
shock absorber to trailing arm, with suspension in normal loaded position - 74ft-lb
Old 03-22-2011, 08:36 PM   #4
stevenluczynski
Thank you! just made my life 10000000x easier!!!
Old 03-22-2011, 09:08 PM   #5
LeMansteve
Note that the Bentley manual recommends you use NEW self-locking nuts and bolts on this job. In other words, don't re-use the old self-locking hardware.
Old 06-24-2015, 07:18 PM   #6
PoloZ4
My Ride: 330XI & Z4
Advice needed: After replacing the rear barrel spring on my 330XI, I mistakenly over torqued the REAR lower strut bolt (the 18mm M12) to 90 ft/lb. Depending on the blog you read, the proper torque is 70-74 ft/lb. What should I do now? Replace the bolt with a new one and properly torque it? Unscrew it and property torque it? Do nothing? other Options? Thank you much in advance.
PoloZ4 is offline   Reply With Quote
