Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 03-24-2011, 07:35 PM   #1
stevenluczynski
My Ride: Is Steel Blue<3
I have a problem and i have been scammed
So today i decided to install my Eibach Pro-Kit Springs
finished the install and wtf
The front of the car sits higher than it did before!!!
Can anyone help me?
And now the scam part
I thought an alignment would help my problem so i went to the shop, left my car there for two hours came back, When i entered i confronted two men fighting, One was the owner of the shop and the second was the alignment technician.
The owner basicly told the technician not to come back or he will call the police The owner tells me he couldn't align the car completely because of the lowering springs. But the front is still higher than normal But than the other technician tells me it was because its a bmw and their machine cant do it and thats what their fight was about. now my car pulls to the right, front sits higher and i was dumn enough to pay for the allingment before i drove the car.
Help?
I'm am thinking of going back to the shop and getting my money back for the so called alignment.
pictures will soon follow
I code cars-p'm me
stevenluczynski is offline   Reply With Quote
Old 03-24-2011, 07:43 PM   #2
stevenluczynski
i Am satisfied with the rear drop
After "aliment"
I code cars-p'm me
Old 03-24-2011, 08:15 PM   #3
franz
My Ride: 03 330i
You likely didn't install the struts properly.
franz is offline   Reply With Quote
Old 03-24-2011, 08:21 PM   #4
stevenluczynski
Any tips on doing it properly?
I code cars-p'm me
Old 03-24-2011, 08:29 PM   #5
Minnoe07
My Ride: 2004 BMW 330Ci
What he said.
Pull your passenger wheel off. Unbolt the 16 or 17 mm bolt that holds the brake assembly/knuckle to the strut. Once you do this, remove the knuckle off the strut by pushing down on it. It will come down fast so be careful. Now, once you get the knuckle off, inspect the bottom of the strut. There is a small metal nub maybe 2 mm in diameter and 4 mm long. This nub must go down into the knuckle so that you can't see it. Hard to explain in words. If you could see the nub before, then it was not installed correctly.
The housing that holds the knuckle to the strut has a slit towards the engine bay. Your goal is to get the nub into the slit all the way down, and then tighten the 16 or 17 mm bolt. Good luck.
And you didn't get scammed. They couldn't do the alignment because you installed the struts incorrectly.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
Old 03-24-2011, 08:32 PM   #6
stevenluczynski
Originally Posted by Minnoe07 View Post
What he said.
Thanks a lot! And maybe not i was just on a rant
I code cars-p'm me
Old 03-24-2011, 09:14 PM   #7
w0w
My Ride: 00 323i
ya sounds like you installed them wrong, either the shock isnt sitting properly and/or the spring. once you fix that go back to the alignment place and tell them your steering is off and you need it fixed
daron
w0w is offline   Reply With Quote
Old 03-24-2011, 09:24 PM   #8
stevenluczynski
Well lucky i paid for 6 months unlimited alignments
I code cars-p'm me
Old 03-25-2011, 10:57 AM   #9
stevenluczynski
Thanks for all the help! i resolved all the issues today and finally my car is sitting LOW
I code cars-p'm me
Old 03-25-2011, 12:33 PM   #10
joshzhp
My Ride: ZHP--Stock
So what was the problem?
joshzhp is offline   Reply With Quote
Old 03-25-2011, 12:56 PM   #11
stevenluczynski
The struts weren't installed properly
I code cars-p'm me
Old 03-25-2011, 01:10 PM   #12
BMW_SSG
BMW_SSG's Avatar
My Ride: '02 325i|'11 GT500
Send a message via Yahoo to BMW_SSG
I love E46 Fanatics for reasons of threads like this! OP, I hope you get your car aligned and I hope that Alignment tech can get his job back too! LOL
BMW_SSG is offline   Reply With Quote
Old 03-25-2011, 06:07 PM   #13
xi_ter
My Ride: 2003 325xi
Use this DIY to install the springs:
http://www.e46fanatics.com/howto/how...hp?howto_id=12
The shop will probably do the alignment once the install is right. I've installed ProKit springs twice and always get the specified drop.
The shop should not start work on your car if it can't do the alignment.
Old 03-26-2011, 02:26 PM   #14
BMW_Matt
My Ride: Has AWD
Someone needs spacers!
BMW_Matt is offline   Reply With Quote
Old 03-26-2011, 02:48 PM   #15
stevenluczynski
the're in the mail
I code cars-p'm me
