Old 03-26-2011, 08:10 PM   #1
markv8375
My Ride: 323
Remote key fob
I just bought an e 46 and the seller told me he lost the remote key fob so all i have is a normal key just for locking and unlocking but can the alarm only be activated by the remote key fob or should it be armed by using the key ??
markv8375 is offline   Reply With Quote
Old 03-26-2011, 08:24 PM   #2
scottjoh
My Ride: '99 323i & '02 540i
IF the car has an alarm it can be armed and disarmed via the fob or the key in the driver's door.
scottjoh is offline   Reply With Quote
Old 03-27-2011, 02:02 PM   #3
markv8375
My Ride: 323
it has the red light on the iterior mirror so how do i arm it using the key as i was wondering if i buy a new remote
fob and it doesnt work i have probably waisted 150
Old 03-27-2011, 02:12 PM   #4
The ReIntegration
My Ride: N/A
You have to make sure that it has an factory alarm in the first place. All E46's have the red light under the rear view mirror even if they have an alarm or not.
The ReIntegration is offline   Reply With Quote
Old 03-27-2011, 02:33 PM   #5
Lusticles
My Ride: 325Ci
Remove the box on your headliner near the rear of the car and check and see if there's anything in there.
number one Audi Fan
Lusticles is offline   Reply With Quote
Old 03-27-2011, 02:37 PM   #6
markv8375
My Ride: 323
amd if theres nothing in it then take it theres not a factory fitted alarm system
Old 03-27-2011, 05:45 PM   #7
scottjoh
Correct. No interior sensor then no alarm! You can also look for the siren under the hood (hard to stop because it's under the HVAC intake filter) or the tilt sensor behind the trunk carpeting on the right side above the batter.
Old 03-28-2011, 12:53 PM   #8
markv8375
My Ride: 323
i pulled down the interior sensor and the seems what looks like sensors to front and rear attached by a wire
Old 03-28-2011, 03:04 PM   #9
scottjoh
You seem to have the interior sensor. The alarm can be activated via the key in the door turned to lock or via the key fob. If the clown nose light doesn't blink and the alarm siren doesn't chirp then the car may not be programmed for alarm. The previous owner might have installed the components himself and not gone to get it programmed.
Old 03-28-2011, 03:08 PM   #10
bostonsc4
My Ride: BMW 323i
My e46 has no clown nose. :/
99' 323i
bostonsc4 is offline   Reply With Quote
Old 03-28-2011, 03:21 PM   #11
scottjoh
No red dome on the bottom of your inside rear view mirror, commonly refered to as the clown nose? That's weird. I thought all E46's came with that regardless of the alarm.
Old 03-28-2011, 03:24 PM   #12
bostonsc4
My Ride: BMW 323i
Weird I know. My mirror just has a traditional flip switch to adjust for high beam control. At least that flip switch is red.
