Old 03-27-2011, 01:29 PM   #1
vendetta233
My Ride: 2001 325 ci
Engine Light on, loosing power
My engine light keep coming on and off. When the light is off car run smooth no cold starts. But when the light comes on the car looses acceleration and when i try to turn the car on, it doesnt start on the first tried, it will start on the 2nd try. Any ideas what this could be.... The car runs perfectly fine until the engine light come on, i mean it runs well it just doesnt accelerate fast like it normally does. it will gradually gain speed, but when the light is off the car accelerate at fast pace. I dont know what more details to give..thats all i know
"A veteran is someone who, at one point in his life, wrote a blank check made payable to 'The United States of America ' for an amount of.... 'up to and including my life."
vendetta233 is offline   Reply With Quote
Old 03-27-2011, 02:05 PM   #2
Drizzles
My Ride: 1999 BMW 318i E46 4D
really REALLY gonna need more details than that
Drizzles is offline   Reply With Quote
Old 03-27-2011, 02:59 PM   #3
Eliott's-BMW
Eliott's-BMW's Avatar
My Ride: E46 3-Pedal Mafia
Go get the codes from the ECU, Autozone will do it free
Who has the skills?
e30 project
"May GOD grant you DOUBLE the amount you wish upon me!"
Eliott's-BMW is offline   Reply With Quote
Old 03-27-2011, 06:16 PM   #4
Pimpwerx
My Ride: 2002 BMW 325Ci
I'm interested to know what your problem ends up being. I have something similar that gives me o2 sensor adaptation and control limit errors on both banks. I'm pretty sure both o2 sensors aren't bad, so the problem must be on the intake side.
I don't know if it's too much air or fuel, but I assume it's too much air since there's a control limit code. I changed the intake boots, MAF and have a throttle body gasket to put on. The CEL went from constant to intermittent when I upgraded to the performance intake recently. That increases airflow, so I don't know anymore if the issue is an air leak. But I'm still operating under that assumption. PEACE.
Pimpwerx is offline   Reply With Quote
Old 03-27-2011, 06:34 PM   #5
jdstrickland
My Ride: '94 325iC & '00 323i
There are hundreds of things that can make the light turn on, and the car run poorly. Have you given any thought to pulling codes to see what makes the light come on?
Old 03-27-2011, 06:40 PM   #6
kosnosferatu
My Ride: 2000 323ci
This. Pointless to discuss until you know the codes.
Correlation does not imply Causality
kosnosferatu is offline   Reply With Quote
acceleration, engine light, transmission
