Old 03-28-2011, 02:58 PM   #1
jr81
My Ride: Bought 330Cic
how to change ECU cooling fan
Hi guys. I posted a while ago about a high pitched whine coming from above the foot rest under the drivers side of the dash and it turns out that it is the ECU cooling fan (post #13 in the link) that draws air from the interior into the ECU compartment in the engine compartment. Has anybody changed this fan and if so is their a DIY/ procedure for it.
Ant help would be appreciated.
http://forum.e46fanatics.com/showthr...+pitched+whine
jr81 is offline   Reply With Quote
Old 03-28-2011, 04:04 PM   #2
OrientBlau
My Ride: 2003 330i
Here's the Blower with Cover DIY (Cricket sound from under dash) :
http://forum.e46fanatics.com/showpos...6&postcount=13
All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
OrientBlau is offline   Reply With Quote
Old 03-28-2011, 04:29 PM   #3
jr81
Thank you. I cannot wait to change this part out.
Old 03-28-2011, 04:38 PM   #4
eld4au6
My Ride: 00 323it
Does it sound like some kind of electronic whine?
Near the headlight switch?
eld4au6 is offline   Reply With Quote
Old 03-28-2011, 05:04 PM   #5
OrientBlau
My Ride: 2003 330i
It sounds like crickets or an electronic whine, coming from where your feet are.
Look at the diagram in the link. The fan itself has bearings which get dry or loose and cause the noise.
Old 04-11-2011, 02:53 PM   #6
jr81
Changed the blower yesterday after buying it from Tischer. Has made such a difference thank you.
cricket, sound
