Sponsored by BAVSOUND
Old 03-31-2011, 10:16 AM   #1
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
E46Fanatics Official DICE iPod integration kit Q/A thread
Use this thread to get help from other members regarding the Dice iPod integration kit for your BMW. Got a problem or question post it here. If you can help another member with their DICE jump in!
A good place to start if you have a question is reviewing the Previous Q/A thread thread here -
http://forum.e46fanatics.com/showthread.php?t=374525
This thread is supported by members only. If you need official support please contact DICE directly.
tim330i is offline   Reply With Quote
Old 04-02-2011, 03:07 AM   #2
e46_323
My Ride: 323
Hey Tom, I just bought a DICE SILVERLINE unit off a fellow member and the model is I-BMW-T/5V.
I was just wondering does this mean that the cable that comes with it is the 5V charging cable and that it should have no problem charging my IPhone 4?
///M3 Bumper // DEPO P46 w/ DDE Angel Eyes (6000k) // 8000k H7 HID // Depo Smoked Corners // Depo Smoked Sidemarkers // Clear Tails // Remus Powersound Exhaust w/ 2nd res delete // Koni Str.T Shocks // Hotchkis Sport Springs // RE RSMs // AEM CAI // Matte Black Grills // CF Roundals // Tints // BBS RS-GT 18x8 // DICE Silverline Pro
"The Ultimate Driving Machine ... E46 Forever"
e46_323 is offline   Reply With Quote
Old 04-03-2011, 12:22 PM   #3
Weralkstterb
My Ride: 2000 328ci
I drive a 2000 328Ci and I was considering buying the cheaper DICE unit but I don't like the idea of keeping my ipod in the glovebox or even the ashtray dock option. I would like to run the ipod cable up my center console to come out underneath my center armrest so I can easily control the ipod. Has anyone done this with what comes in the box? Are the wires long enough or do I need more parts? Can I replace the ipod wire with a standard usb ipod cable?
Thanks in advance
Sent from my T-Mobile myTouch 3G Slide using Bimmer App
Weralkstterb is offline   Reply With Quote
Old 04-04-2011, 11:18 PM   #4
ivan300
My Ride: 2002 325i
My Dice Silverline Duo Review (Radio harness tested with iPhone 4)
I installed the unit this friday. It took me about 2 hours. (I have never taken the e46 dash apart at this point) The dash/radio removal was very easy if you follow the DIYs. The only issue I had was fitting the harness behind the radio. After cutting my hand countless times and trimming the plastic connector I managed to get it fit without cutting the central vent support. Keeping in mind I have installed countless sound systems, I found this a huge pain in the but to do. I would definitely recommend getting the trunk harness. It does take a little bit longer but you will not be as frustrated and cut up.
The Good:
Sounds great, only a small amount of noise. I can only hear it when the phone is not playing any music and the volume is fairly high.
Ability to control the iPhone through the steering wheel. I was surprised that I was able to control third part applications such as Steamtome.
The interface is very good considering what they had to work with.
The Bad:
Esthetically the unit feels VERY cheap. The insides of the unit rattled. I had to open it and stuff in a small peace of foam to prevent it.
I feel that the input connector on the unit will break off if the cable is plugged in more than 10x. It has a good amount of play.
The Ipod cable is overly thick. The connector is monstrous. It will not fit with many cases. I am hoping they did this for durability. Time will tell.
Sometimes gets stuck in a weird mode Ipod is unlocked and doesn't let you control the radio
Initially when connected to a iphone it thinks it is a video out so the steering wheel controls dont work. This is remedied by unplugging the iphone and plugging it back in again.
Update: A few weeks into the install. I placed the unit in the glove box for easy access for firmware updates. A few days ago the device stopped working. I had a look at it and one of the wires broke off the connector. I have contacted Dice about a replacement radio wire. I doubt they will sell me one.
In conclusion. The device barely does what is stated. If your vehicle is able to use the standard aux in I would use that. The construction of the whole device is worse than some eBay knock offs I have purchased. Do not mount the device where the wires will have play such as the glove box.
I would not purchase this device again.
ivan300 is offline   Reply With Quote
Old 04-11-2011, 07:18 PM   #5
kevx
My Ride: 330xi
Hi i just got my dice duo silverline today for my 02 330XI.When I opened the trunk and took out the extra wire, I didn't get the 3PIN and 6 pin next to it as the manual said. Instead, I got a 3 pin and 4 extra connections( one is blue, and one is green both 1pin). Anyone has any idea what I should do with those instead of the 6 PIN? I have business CD radio with HK sound system if that matters, thanks so much
I have the same as this guy's :
http://www.mp3car.com/attachments/ne...rdassplugs.jpg
kevx is offline   Reply With Quote
Old 04-12-2011, 05:39 PM   #6
arfster
My Ride: 325xi esotril? blue
Anyone know where i can get a trunk replacement cable or if it can be fixed? wiring pins have come loose from the 10 hole clip and one of the wirings even frayed off leaving the connecting pin inside the 10 hole clip
arfster is offline   Reply With Quote
Old 04-21-2011, 02:32 PM   #7
ivan300
My Ride: 2002 325i
I contacted dice as my cable also fall apart. they said its 30$
This cable works as a extension cable.
http://www.dealextreme.com/p/dock-ex...ack-80cm-30394
Old 04-24-2011, 10:27 PM   #8
mticar1
My Ride: 330ci Convertible
Nano 6g
I got a silverline duo for my 05 330, with a business cd and installed it about 2 weeks ago. Everything was working great with my old Ipod, so I decided to upgrade to a new nano, now I'm having problems. Is the 6th generation supported by the duo? If not any chance that it will be in the near future? Any insite would be appreciatted
mticar1 is offline   Reply With Quote
Old 05-11-2011, 02:32 PM   #9
MrBearcat
My Ride: 2001 325cic
2001 e46 325 Ci DICE Silverline Message - NO CORE DE
Just installed my silverline into a 2001 e46 325 CiC
Right after I installed the Dice, my iPad worked perfectly fine with the radio and the wheel controls. After I hooked up the aux cable and set that up, when I went back to my iPad it no longer worked. I have also tried my Nano 2G and iPhone 1G and neither work.
I get the following message: "CORE NOT DE" followed by "DETACHED"
When I plug in either the iPad or the iPods it shows that they are "ATTACHED" but there is no control or audio.
When I hit CD5 and switch to AUX, I can use the aux cable fine, but under iPod mode - nothing.
I went through the steps recommended in the previous thread, both disconnected the fuses, and unplugged my battery. But each time I do it, I get the same message "CORE NOT DE"
What should I do?
Thanks in advance.
MrBearcat is offline   Reply With Quote
Old 05-14-2011, 10:19 AM   #10
MrBearcat
Well after a few trials and errors and a few battery resets - I got it to work!
Old 05-24-2011, 07:07 PM   #11
CHutchins
My Ride: 2003 325xi
So when I look at the Dice Silverline Duo on EAS/eBay, it's about $170. However, on Amazon you can get a DUO-100-BMW for like $125. I know that the Amazon one only comes with the Trunk connection, but it appears to be the same thing... Am I missing something?
CHutchins is offline   Reply With Quote
Old 05-24-2011, 07:46 PM   #12
Beau-Beau
My Ride: '99 328i
Do universal kits display text? Or only vehicle specific?
Beau-Beau is offline   Reply With Quote
Old 05-24-2011, 09:09 PM   #13
mticar1
I bought mine on Amazon for $120, it was the same as any other Dice Duo as far as I can tell, and I've seen someone post that Dice won't help you if you buy it from Amazon, but they helped me, even sent me a new unit when my new nano wouldn't work(both my 5th generation ipod and 3gs iphone work great, just not the new Nano)
Old 05-24-2011, 09:12 PM   #14
Born Again
Born Again's Avatar
Location: Tis quite a statement. Where do you live - where do we all live? in our minds? our souls? our bodies?
My Ride: She aint much 330ci
Eas charged me $40 for a replacement iPod cabe
Plus shipping lol
best mod to date : OEM grocery bag holder
Originally Posted by Zell View Post
E46Fanatics - the Honda community of gun owners. Keep staying classy, I'm sure you all are going to be excellent examples of how to keep gun rights from being infringed. :facepalm:
Born Again is offline   Reply With Quote
Old 05-24-2011, 09:17 PM   #15
mticar1
Plus shipping lol
I went directly to Dice
Old 05-25-2011, 11:49 AM   #16
Beau-Beau
My Ride: '99 328i
Also, is it true that i won't be able to use my 6 disc change if the DICE ipod integration is installed??
Old 05-25-2011, 03:48 PM   #17
CHutchins
My Ride: 2003 325xi
Well then that makes it easy. I'll just get one there (or any of the dozens of retailers that sell it for <$125). I still feel like I'm missing something...
Old 05-29-2011, 02:22 PM   #18
astonmartini03
My Ride: 2005 330Ci ZHP
I'm thinking about getting the DICE Mediabridge but I'm having a lot of reservations. I think it would be awesome to have ipod and bluetooth capabilities, but it didn't take much reading at the forum that's linked to this one to see all the problems. The problems seem to be with new and old installations. Are these devices just really finicky? Are people not following the instructions well or not qualified to make the installations? (I kind of doubt this given the other repairs that people on this site.) Or, is this just a very small fraction of the total number of users?
astonmartini03 is offline   Reply With Quote
Old 05-29-2011, 11:35 PM   #19
Hark
My Ride: 2005 330i ZHP
Text display noise issue
I just installed the no-bluetooth version of Mediabridge (latest firmware) in my 2005 330i, non-nav using the trunk CD harness. Works and sounds great except for a faint buzzing noise whenever the text in the HU display changes. Every time the Mediabridge updates the text in the display when I'm listening to my iPhone 4, a short buzz can be heard. If the text is not updated (like if I'm using Pandora or something), there's no buzz noise.
Anyone else had this problem, or any ideas for how to solve? I'm going to contact Dice directly about it, but I thought I'd also poll the other experts around here.
Hark is offline   Reply With Quote
Old 05-30-2011, 04:08 PM   #20
steve.325i
My Ride: 2003 325i
For noise associcated with changing text, these posts may help:
http://forum.e46fanatics.com/showthr...3#post13003163
http://forum.e46fanatics.com/showthr...8#post13056238
steve.325i is offline   Reply With Quote
