Old 04-01-2011, 03:58 AM   #1
vendetta233
My Ride: 2001 325 ci
Brightest hid
I need a no B.S answer.
What is the brightest HID kit i can get for my 325ci?
I am looking for a kit that's reliable, have endurance, good warranty, and the brightest output. Any one has any idea?
I heard of the phillips HID kit, they are expensive but are they bright and reliable? Does getting a 55W makes it brighter? or a 35 W is good enough?
"A veteran is someone who, at one point in his life, wrote a blank check made payable to 'The United States of America ' for an amount of.... 'up to and including my life."
vendetta233 is offline   Reply With Quote
Old 04-01-2011, 04:23 AM   #2
mkodama
mkodama's Avatar
Best: If you want the brightest, I suggest retrofit your headlamps to use the much talked about Acura TSX projector assembly and lighting system, used by lots of people on lots of different cars, because of the best beam pattern and light output. It's really about the reflectors and lenses more than the bulbs themselves.
Excellent: Next best option would be a set of E46 stock xenons, since they are almost as commonly used as the TSX projectors, and are really quite nice.
Very Good: Third option, I would get the Depo headlight assembly with the projectors and 55watt or 35 watt HID system. The 55 watt system is supposed to be a little brighter than the 35 watt system, but stock HIDs are 35 watt and 35 watts has been bright enough for me. Once again, it's more about the projector setup than the bulbs when you are using HID.
Old 04-01-2011, 05:17 AM   #3
todd92
My Ride: 05 330i ZHP
Please don't confuse bright with color temperature. Do your fellow motorists a favor and get a set of proper projectors and limit the color to 5000K max.
todd92 is offline   Reply With Quote
Old 04-01-2011, 05:20 AM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Best visibility is 3000k which is yellow.
+1 with mkodama, retrofit your lights with a different lense and put in the Philips kit
35w, 55w, brightest, bulb, hid
