Old 03-31-2011, 06:08 AM   #1
lrballa00
My Ride: 99 328i 06ChargerR/T
Send a message via AIM to lrballa00 Send a message via Yahoo to lrballa00
Exclamation A little help please?
How's it going everyone? I need some assistance troubleshooting an issue that I'm having. I can go to my car & turn the key to the on position... within a couple of minutes, the temperature gauge will go into the red (light & everything)... without even starting the engine. Where do I start to resolve this issue? It seems pretty weird to me, especially since I haven't started the car. I'm home on leave from Germany, and I fly out of here on Tuesday. I need to get this resolved as soon as possible. Thanks in advance for any replies that I may get, it's greatly appreciated.
Curtis
lrballa00 is offline   Reply With Quote
Old 03-31-2011, 06:39 AM   #2
The ReIntegration
My Ride: N/A
So the temp gauge goes straight to "H" after sitting off? Sounds like a bad temp sensor.
The ReIntegration is offline   Reply With Quote
Old 03-31-2011, 06:42 AM   #3
lrballa00
Yep; That's what I sort of thought it could be, but I just decided to ask to be sure. Thanks for your reply, I appreciate it.
Old 03-31-2011, 06:47 AM   #4
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Curtis
Curtis,
Welcome home! Too bad your car didn't!
How long had the car been sitting and had you had any cooling issues in the past?
IIRC there are a few temp sensors but I think it's the lower radiator hose sensor that signals the temp gauge.
But, if car had been idle for any length of time, I'd first check level and condition of all fluids, and try starting it (sounds like you haven't). If it doesn't start, try a jump and then drive for a while to charge battery.
Often electric glitches are just the battery. Try wiggling the connections...though I'm sure if it had been idle while you were away, you would have disconnected it.
Probably not much help. The guys that will mock my attempt at helping you will know what it is!
Upcoming comedy shows: May 20, Greenwich Village Comedy Club. 6 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 03-31-2011, 07:23 AM   #5
Drizzles
My Ride: 1999 BMW 318i E46 4D
Silly question, have you checked your fluid level (You'd be surprised!)
Drizzles is offline   Reply With Quote
Old 03-31-2011, 11:55 PM   #6
lrballa00
Fluids are fine. I'm going to flush & refill the radiator in the next couple of days. This happens even if the car isn't started.
Old 04-01-2011, 06:27 AM   #7
dmax
dmax's Avatar
Op,
Try ping shanneba to link.at this. That might be the way sensor indicates failure...as mentioned. My oil level sender is indicating a failure by coming on for 15 sec after start up. Anyway shanneba seems to be really good finding info!
Curtis
I'm on phone so if I wrote something stupid, it was probably the phone!
Mangofy your E46!
