Old 04-02-2011, 07:17 PM   #1
Bad00ss
My Ride: 02 330ci
help! rolling my fender lip....
I'm about to roll the lip on my rear fender with the eastwood fender rolling tool. I noticed there is some sort of sealant or body seam sealer inside the lip. it seems too hard to pick out with a screw driver. any tips? would heating it up help? I need to get this stuff out ASAP so i can roll the lip as flat as possible. unless when its hot it will be mushy and bend with the metal?
-2000 Camaro SS
-2002 330ci
Bad00ss is offline   Reply With Quote
Old 04-02-2011, 08:04 PM   #2
John in VA
My Ride: 328i/325xi
A heat gun or powerful hair dryer will soften the sealer and paint to help avoid cracking. Good luck!
John in VA
'13 328i xDrive
'06 330ci ZHP
'03 530i
'02 325xi
'00 328i
'86 535i
'85 535i
'85 325e - RIP
'74 2002tii
John in VA is offline   Reply With Quote
Old 04-02-2011, 08:41 PM   #3
Bad00ss
My Ride: 02 330ci
so your saying the sealer will get soft enough to roll the lip without removing it?
-2000 Camaro SS
-2002 330ci
Old 04-03-2011, 02:01 AM   #4
w0w
My Ride: '02 M3 Vert
u need to pick it out with a screwdriver and/or pliers of some sort. be ready to spend a few hours getting all that out
daron
w0w is offline   Reply With Quote
Old 04-03-2011, 03:45 AM   #5
Evap
My Ride: rubs tires
Yeah, the first time I rolled my fenders, I didn't get it all out, so I didn't roll them flat. Now I have to go back and try to get it out of the slightly flatter lip.
Take my advice: get it ALL out the first time.
Evap is offline   Reply With Quote
Old 04-05-2011, 04:02 PM   #6
genes330ci
My Ride: 330ci
Hey pal... I recently took my 330ci to get my fenders rolled at a shop in phx and instead of rolling, he just cut the inside of the fender lip off to give me maximum clearance. I asked him why that rather then rolling and he simply put it this way, would you rather roll and possible damage your fender/paint by rolling or would you rather cut it without any risk of harming your fender/paint. It was easy and it took care of that issue with the sealer. He did an awesome job and it was $80 bucks! Just another option!
genes330ci is offline   Reply With Quote
Old 04-23-2011, 08:40 PM   #7
Brandyn.
My Ride: Slow, but Low
Is it ok to take it all out? Will it rust if I do? And also not out of the lip I'm talking about the wheel well
Brandyn. is offline   Reply With Quote
Old 04-23-2011, 11:31 PM   #8
Bigjake
My Ride: 2000 BMW 323ci
I used a wirewheel to get mIne out.
Bigjake is offline   Reply With Quote
