Old 04-03-2011, 09:43 AM   #1
mad_polo
My Ride: E46 320
Mayday mayday sos!
BIG BIG poblem with my E46 and I hope im just blowing it out of proportion.
I have a 2004 320d M-sport 150bhp with 73K on the clock.
I was overtaking on the motorway when all of a sudden I lost power and the engine started making this whining/grinding noise.
No white smoke coming from the exhaust at the time, however since then, there has been white smoke. The car revs and there is no warning light that has come up onto the dashboard. I have had the RAC have a look at it, but they cant really put their finger on it.
I was hoping if anyone could bring light onto this and let me know if you've had a similar problem.
mad_polo is offline   Reply With Quote
Old 04-03-2011, 09:46 AM   #2
CylonRed
My Ride: '01 E46 330i sport
White smoke with a sweet smell = head gasket and hopefully not a warped head.
CylonRed is offline   Reply With Quote
Old 04-03-2011, 09:51 AM   #3
JJMolson
My Ride: 2000 328i
being that its a diesel correct? actually before i ask, is it a stick or smg 2?
JJMolson is offline   Reply With Quote
Old 04-03-2011, 09:52 AM   #4
paraklas
My Ride: ESS TS2 320ci
How does the coolant look like when you check it?
Old 04-03-2011, 09:53 AM   #5
mad_polo
My Ride: E46 320
Its a Diesel 6 Speed Manual (stick)
Old 04-03-2011, 09:55 AM   #6
mad_polo
My Ride: E46 320
Coolant seems fine. I topped up the oil yesterday before setting out so that it was between the minimum and maximum limits and after doing only 160miles or so, its gone down to the minimum level
Old 04-03-2011, 09:55 AM   #7
JJMolson
My Ride: 2000 328i
the odds of the head gasket being blow isnt very likely, as long as the coolant system has been serviced properly. make sure its not the turbo making the noise and try to pin point the exact area the sounds coming from. (if it sounds like a police siren its possible that the turbo has gone bad)
Old 04-03-2011, 09:57 AM   #8
mad_polo
My Ride: E46 320
If the head gasket had gone, the engine would be over heating right? My engine is running at optimum temp.
The noise kicks in around 1500rpm and above. After a few seconds. the noise only comes on just above 2000rpm :S
Old 04-03-2011, 09:59 AM   #9
mad_polo
My Ride: E46 320
The noise is coming from the right hand side of the engine (driver side area) and the service history is immaculate - full BMW and no issues have previously been picked up.
Old 04-03-2011, 10:05 AM   #10
JJMolson
My Ride: 2000 328i
you may have a possible vacuum leak check the intake and all the hoses, its possible that while you where boosting one of the hoses came off or apart. look for cracks on the intake as well, even near the throttle body.
Old 04-03-2011, 10:21 AM   #11
pilot_alex
My Ride: 2014 435I Msport
Send a message via MSN to pilot_alex
Is it heavy white smoke and really poor performance? I know from previous experience mind you on SAAB, white smoke + rattling is 99% turbo. Very common signs. Take the down pipe of and put your finger in the turbo (obv when off) if there is oil in the turbo thats your problem. Another way of checking is take off the hose that goes to your throttle body. Check the hose for any oil.
Edit: You posted saying that the oil went down?? If so im leaking even more towards you have a turbo thats gone bad. Like i said check hoses if you have oil then im 100% positive turbo is gone. Do not drive the car any more because you will damage your catalytic converter and flood your entire engine with oil.
pilot_alex is offline   Reply With Quote
Old 04-03-2011, 10:37 AM   #12
mad_polo
My Ride: E46 320
I have uploaded a video onto youtube so that you can hear the noise. (Engine Cold Start)
Old 04-03-2011, 10:42 AM   #13
pilot_alex
Hmm could be the impeller on the turbo. Like i said just take of intake hose easies thing to do and check for oil.
Old 04-03-2011, 10:55 AM   #14
JJMolson
My Ride: 2000 328i
that sounds definite on the turbo, start getting some prices or if your mechanically inclined find a rebuild kit
Old 04-08-2011, 08:12 AM   #15
mad_polo
My Ride: E46 320
*UPDATE*
Guys... I found out yesterday that its the Turbo that has gone. The intercooler is clogged and the full exhaust is flooded with oil (pre-CAT, CAT all the way down to the rear muffler) Been calling around a few garages, not many want to really touch it. BMW quoted me 3970 parts and labour included!
Old 04-08-2011, 09:49 AM   #16
BoogetyBoogety
My Ride: 2010 SL550
3970!?! Now it's a Mayday...
Surely you've checked with others besides BMW... you might find a world of difference between their prices and real-world prices. And have you thought of DIY'ing it?
BoogetyBoogety is offline   Reply With Quote
Old 04-08-2011, 10:13 AM   #17
Drizzles
My Ride: 1999 BMW 318i E46 4D
Goddamn ... maybe try an Indy mechanic ... that'd be a bigass DIY
Drizzles is offline   Reply With Quote
Old 04-08-2011, 12:07 PM   #18
Silver01
My Ride: 2001 330i
Exhaust, turbo and intercooler piping is not that hard. If you have mechanical knowledge it should be something you can accomplish in a weekend.
Best of Luck with everything.
2001 330i Sport Package
BIR Sport compact proving grounds
Silver01 is offline   Reply With Quote
Old 04-09-2011, 06:18 AM   #19
mad_polo
My Ride: E46 320
Yeah, i've asked around, but the problem is not a lot of garages want to do it due to the extent of the work. I dont want to pay stupid money to BMW and I dont have a garage at home to DIY properly.
Old 04-09-2011, 06:55 AM   #20
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
OP, I like Boogety^2's thought. You can buy all the tools you'd need, spend a hard week studying, and make out $$$$ ahead still.
And, not knowing anything at all about the insides of mufflers, I think I'd take it apart soon, turn it on it's end and let it dry out.
I'd read and work on car and if needed, impose on someone for rides or rent a mini!
When you're done, you could, it sounds like, take the family to Texas for a vacation and shake Boogety's hand...and still be ahead $-wise.
Sorry, man...doesn't sound too good, but I suspect you'd feel great when you realized you could do this! Maybe not. What's 17 times 23?
See me in June!
dmax on Facebook
Mangofy your E46!
diesel, grinding, noise, turbo, whining
