Sponsored by BimmerWorld
Old 04-04-2011, 10:58 AM   #1
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Help on settings for my Konis
Hey All,
After running them for quite some time, I finally decided to play with the stiffness on my Koni Yellows. Running with H&R Race. I had them set on about 1 turn up front and 1 turn in the rear. I called Koni about initial settings and was told that that was probably way to stiff for sporty daily driving given that I was running the H&Rs. I agree, which is why I was wanting a good starting point. He told me to turn everything to about 1/8-1/4 turn.
Fronts were easy, top adjustable. Removed the rears and removed the RSMs. Adjusted around 1/4 a turn, maybe a tad more (just to try to match up the rate).
After this adjustment, I'm MUCH happier with the car around town. It feels better connected to the road. It's not as jerky under acceleration and my DSC doesn't come on over small bumps. I actually think it handles a bit better.
My problem now, is high speed. On the highway when it gets bumpy around 70mph the car gets bouncy. It feels like my 91 300zx did with blown shocks. My intuition would tell me that the shocks need to be stiffened up just a tad to keep up with the springs, but suspension tuning isn't my strong-suit. Any suggestions?
Thanks!
Brady
Old 04-05-2011, 09:31 AM   #2
aggieE46
Keep it clean
aggieE46's Avatar
Bump?
Old 04-14-2011, 11:12 AM   #3
aggieE46
Keep it clean
aggieE46's Avatar
Okay, well I feel stupid. I correctly adjusted my fronts to a softer setting. I managed to goof up and put my rears on almost full stiff. No wonder it's bouncy.
Time to adjust again.
Old 05-01-2011, 07:42 PM   #4
hammerheart
My Ride: 02 330XI
How do you know where you are in the setting for the rear shocks? Is there a some kind hard stop for the softest or stiffest setting?
hammerheart is offline   Reply With Quote
Old 05-02-2011, 09:44 AM   #5
aggieE46
Keep it clean
aggieE46's Avatar
Yes. If you have them pushed in all the way when you are twisting, they'll stop.
Old 05-02-2011, 11:59 AM   #6
hammerheart
My Ride: 02 330XI
Thank you. Guess I did not push them all the way in when I played around with them.
Old 05-03-2011, 10:13 AM   #7
DJ Reminisce
My Ride: Knows Dubstep SUCKS
Aggie:
Since this thread is on Koni Yellows, figured I'd ask here
Did you mention that your yellows actually raised the car up a bit? Can't decide between the Bilstein sports or Yellows
Dinan CAI_Stage II_3.46 Dif
OEM CF Strut Bar_Eibach Sportline_GC Konis
OEM Gloss Grills_H&R Spacers_Clubsport Sills_Painted Splitters
Amber LED Corners/6k HID Fogs/LED Interior_Shadow Emblems
500W_RE Audio_Hertz Components
DJ Reminisce is offline   Reply With Quote
Old 05-03-2011, 10:21 AM   #8
aggieE46
Keep it clean
aggieE46's Avatar
Yes. When I ran them with stock sport springs, they raised my car.
Also, I'm not sure if it's the H&Rs or the Konis, but I have a bit of a rake.
Old 05-04-2011, 09:47 AM   #9
DJ Reminisce
Thanks Aggie!
I'm pulling the trigger on suspension at the end of the month, trying to finalize my list.
I definitely attribute the rake ot the H&Rs, I think I'm going with the Sportline springs for that exact reason
Any side shot pics?
Old 05-04-2011, 10:19 AM   #10
aggieE46
Keep it clean
aggieE46's Avatar
Originally Posted by DJ Reminisce View Post
Thanks Aggie!
Any side shot pics?
Old 05-04-2011, 10:30 AM   #11
DJ Reminisce
Can't see it at work
I'll take a look when I get home though
Ever thought of removing the rear spring pad to remove some rake?
Old 05-04-2011, 10:47 AM   #12
aggieE46
Keep it clean
aggieE46's Avatar
Yep, I just haven't had the rear suspension apart since I installed them. I may do it when I do my bushing refresh soon.
Old 05-04-2011, 12:30 PM   #13
DJ Reminisce
Yeah, I did the bushings in the car a while ago, so I think they should still be in good shape
Really hated the Meyle though, especially in the front, went back to OEM and the ride was much nicer
Old 05-04-2011, 01:14 PM   #14
aggieE46
Keep it clean
aggieE46's Avatar
I've been loving the Meyle up front. Going to replace all the rears. They're oooooold.
Old 05-05-2011, 11:36 AM   #15
Steven747
My Ride: 05 330ci
looks good and id say go with bilsteins because thats just what i have and they are great not dissapointed 1 bit but then again ive never rode on konis so ...
Old 05-05-2011, 01:22 PM   #16
TxZHP04
My Ride: ESS TS2+ ZHP
Same here. I think some people end up with a bad impression because the HD bushings won't mask any other front suspension or tire issues.
