E46 Convertible
Old 04-06-2011, 02:05 PM   #1
Duke2080
My Ride: 2001 330ci comv.
Replacing Convertible Top Motor
This weekend I am going to replace the convertible top motor, the one in the front edge of the top, right above the rear view mirror. I'm just wondering if anyone has had to pop off the plastic cover under which the motor and top latches reside. If so, how'd you do it. 2001 330ci.
Duke2080 is offline   Reply With Quote
Old 05-20-2011, 04:30 PM   #2
Duke2080
I have now completed replacing the top latch, requiring me to remove the motor cover, the long black cover under which the top motor and left/right latches sit. It was a bit--. If anyone is need to do the same in order to replace the left or right latches, or the motor itself, respond to this and I'll answer any questions about getting it done.
Old 05-21-2011, 12:04 AM   #3
Zyaltr
My Ride: 01-325cic,08-750Li
How do you remove that cover...my latches squeek when closing, need to get in there an grease them up...
Zyaltr is offline   Reply With Quote
Old 05-23-2011, 08:06 AM   #4
Duke2080
You have to have the top open in order to get at all of the screws an bolts and the like. When you have the top open you'll see a number of small screws along the leading edge of the cover. They are "star shaped" headed screws rather than common or phillips head (they're called Torx). You can either buy the bits, or you can actually use an Allen wrench that fits. You have to take out each of those. On both ends of the cover you'll see what looks like small dome-capped nuts. Those are just plastic covers over two small nuts you also have to remove. Then, on each end of the cover you'll find two screws under the rubber molding that have to come off. One of them will be screwed from the cover to the frame. The other one will be screwinbg the headliner to the cover. They are both on the very ends of the cover, one on top and the other on the side.
Once you have all the screws and such removed you should be able to pry it up.
Good luck.
Old 06-26-2011, 10:35 AM   #5
djsilver
My Ride: '01 330Ci Vert
Good luck.
I'm working on this project this weekend myself. The pictures in the TIS don't match the car but the instructions are correct. The tricky part is that there are six screws holding the trailing edge of the trim in place. You have to reach between the fabric top and the headliner and loosen the screws that hold the trailing edge of the headliner in place. The trim piece is slotted and it will slide out.
djsilver is offline   Reply With Quote
Old 08-13-2011, 05:15 PM   #6
Zyaltr
What was the best position of the top to tackle this? Cover up and top resting in flat in compartment? Seems like the best way...thoughts?
Old 09-21-2011, 03:21 PM   #7
Duke2080
A little late on this post . . . I worked on the six screws with the top not quite closed to make it easier to reach in to try and access the screws. There may be an easier alternative I thought about when I was all done. I don't think you have to remove the liner from the motor cover in order to get the motor cover off. One you remove all the screws/bolts holding the motor cover in place you should just be able to leave it connected to the headliner.
Old 10-13-2011, 10:16 AM   #8
molten330ci
My Ride: 2002 330Ci - Red/Tan
How much is the latch motor ?
Can you write a step by step instruction on it?
molten330ci is offline   Reply With Quote
Old 12-18-2011, 10:27 AM   #9
welshie
My Ride: 2000 convertible
I have to replace the lock/latch on the passenger side.
It failed a few months ago..finally found the parts..had to buy as a set.
Did you have to remove any portion of the cloth top?
welshie is offline   Reply With Quote
Old 02-24-2012, 09:22 AM   #10
Duke2080
Sorry molten330ci and welshie about the delay in responding to these. I have to get back in the habit of accessing this site regularly. The latch motor will run you $230 - $250 if you purchase a new one. I suggest searching out used ones from a number of salvage yards out there. I purchased a folding top lock in excellent condition for $125 rather than the almost $400 a new one would cost. Also purchased the Window Frame Cover for $100 instead of a new one for $225.
welshie - if you still need info on replacing your lock, respond here and let me know. Can you open your top, or is it locked closed?
Old 09-19-2012, 09:03 AM   #11
dknightd
My Ride: 2002 330 cic
I'm interested in replacing the front rubber seal on my top. It is torn, cracking, and leaking. I've put in RTV as a stop gap, but I suspect it will need to be replaced at some point. Starting to do the research now - will probably do the job next spring. Looks like that rubber seal is around $350 - if you know of a cheaper source please let me know.
Seems like this might be a relevant thread since the seal probably has to removed and reinstalled to replace the lock motors.
Any tips, on just replacing the front seal? Thanks
dknightd is offline   Reply With Quote
Old 12-10-2012, 07:30 PM   #12
uphguy
My Ride: 2010 535
Send a message via Yahoo to uphguy
E46 replacing convertible top locks or latches
I have replaced many E46 tops, top latches, hydraulic lines, rams other trim parts and I made a repair bracket to fix the top latches and I will post pictures later when parts come back from plating.Dont buy new.I would like to get any broken ones out there. thanks Dan
uphguy is offline   Reply With Quote
Old 12-28-2012, 12:21 AM   #13
Landlorder
My Ride: 330CI Sport
Sorry to go off topic...
How do you replace the soft top wiring loom, i cant solder the wires any more at the bend near the soft top cover.... If you can give any details on how to go about this it would be great. !
Landlorder is offline   Reply With Quote
Old 12-28-2012, 01:06 AM   #14
uphguy
My Ride: 2010 535
Splice a new wire on beyond where the top frame Bends .It is very difficult to change the wire loom
Sent from my MB865 using Bimmer App
Old 05-15-2013, 01:39 PM   #15
nadodude
My Ride: '04 330ciC/ '02 C230
Hmmm I took off all of the screws but the cover just won't come off
nadodude is offline   Reply With Quote
Old 08-14-2013, 01:52 AM   #16
joey622
My Ride: 01 330cic 02 a4 q
hi there.....when I try to lower my top the latch motor just spins and pops out a bit and nothing else happens....im assuming that I need to replace the motor but how can I access it with the top fully closed?
joey622 is offline   Reply With Quote
Old 08-14-2013, 12:45 PM   #17
uphguy
My Ride: 2010 535
uphguy top latches
You need to call me Dan 650 740-5969
Old 09-08-2013, 07:19 PM   #18
CombatWombat
My Ride: 330cic
Is there a way to do this if I can't get the top open at all? Something is broken where it won't manually unlock with the allen key (the allen drive "bolt" just falls out completely when I go to unlock the top).
CombatWombat is offline   Reply With Quote
Old 09-08-2013, 10:32 PM   #19
taylor192
My Ride: 2003.5 M3
Re: Replacing Convertible Top Motor
As I said in your other thread, cut the plastic cover. There is no other way. There is no DIY either other than a brief description of how to remove the cover, yet you need to cut it open. A number of people have posted pics of the motor and latches if that helps.
Old 09-08-2013, 11:30 PM   #20
uphguy
My Ride: 2010 535
Cut the wire back away fromthe bend in both directions,make splice away from bend
Sent from my GT-P3113 using BimmerApp mobile app
convertible motor
