Old 04-06-2011, 07:35 PM   #1
zhenkaaaM3
My Ride: Fst'r then your e46
reprogram key fob
i been having problems with unlocking my e46 with the stock built in alarm ever since I bought the car.
I press unlock once, driver side door opens, i press twice, the passenger side should open( 5/6 attempts and it does). it starting to piss me off.
anyways to reprogram the key fob manually? or any things to look out for?
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 04-07-2011, 03:37 AM   #2
Arty
My Ride: 1999 328i
Your problem lies in the passenger door, not the key.
EDIT: Unless the key battery is dying.
Arty is offline   Reply With Quote
Old 04-07-2011, 11:21 PM   #3
zhenkaaaM3
Well sometimes, the car would go, beep beep, and neither door would open. If I replace battery, would I need to reprogram key as well?
Eugene
Old 04-08-2011, 04:26 AM   #4
Arty
My Ride: 1999 328i
No. Just don't leave the key without a battery for more than 60s or it will lose it's rolling code position and you will have a little more trouble getting it to unlock the first time you use it.
Sounds to me like your lock motors are getting weary and may need cleaning and replacing. Do the battery first, since it is the cheapest fix.
Old 04-16-2011, 01:01 PM   #5
zhenkaaaM3
Sounds like a pain in the ass if you ask me. Cutting a key open and glueing it together
Old 04-16-2011, 09:28 PM   #6
josephmech
My Ride: 2001 325i sedan 5m
not too hard actually pretty easy I just need to order a battery replacement
josephmech is offline   Reply With Quote
Old 04-23-2011, 12:11 AM   #7
blarf
My Ride: 323i, 325iT, 540iT
Also: what type of key do you have? Replacing the battery on the earlier style (rectangle not diamond) is easy.
Originally Posted by howie View Post
do you park near poodles?
blarf is offline   Reply With Quote
Old 04-23-2011, 07:21 AM   #8
rizwan1377
My Ride: 04 M56,LC 100,RX300
Send a message via AIM to rizwan1377 Send a message via MSN to rizwan1377 Send a message via Yahoo to rizwan1377
OP, what year is your car?
rizwan1377 is offline   Reply With Quote
Old 04-23-2011, 01:14 PM   #9
Arty
My Ride: 1999 328i
Also it could be a dying relay in the GM5.
http://www.bmwgm5.com/
Old 04-23-2011, 02:08 PM   #10
zhenkaaaM3
I have an 00'. It looks like an oval shaped triangle.
Eugene
