E46 Convertible
Old 04-08-2011, 05:16 PM   #1
johnrando
My Ride: '06 330 CIC ZHP
VERT Antenna
All, I've posted this before, but now that we have our own sub-forum someone might have a suggestion. My antenna has never gotten great reception, so I bought a "euro antenna". It's better, but not perfect. Strangely enough, the reception gets better when I touch the antenna, but it's as tight as it can go. Nothing seems loose on the connection inside the trunk. Any other suggestions for getting better reception using the same head unit? (Sorry the pic is sideways).
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 04-08-2011, 07:20 PM   #2
Gheybe
Gheybe's Avatar
My Ride: F80 M3
Okay, from the top of my head and using my common sense, I can only think of one thing.
Assuming the antenna is in proper order and so is the head unit, it's gotta be the wiring somewhere in between. I think?
Gheybe is offline   Reply With Quote
Old 04-08-2011, 08:58 PM   #3
mach.schnell
My Ride: 08/2000 330Cic x2
BMW uses an aluminum thread to screw in the antenna, instead of steel. You will probably find some white-ish powder residue when you remove the antenna. I've been looking into various anti-corrosion agents for aluminum, and when I find one my wife likes (She's a metallurgist) I will let you know. And I will also let you know if that helps the AM squeal when braking.
mach.schnell is offline   Reply With Quote
Old 04-08-2011, 09:22 PM   #4
Gheybe
Gheybe's Avatar
My Ride: F80 M3
^Awesome.
Can't wait to find out. I'm sure my reception could be better. I just figured it was the place I was at.
Old 04-09-2011, 09:38 AM   #5
mach.schnell
In the meanwhile I found this:
http://forum.e46fanatics.com/showthr...6343&highlight=
But as we all know the antenna system for verts are different than the others, and I didn't read the thread too closely. I just had it on file for later.
There are a few ideas here:
http://www.bimmerfest.com/forums/sho...d.php?t=109202
but also a lot of "noise" (i.e. unhelpful blathering) that has to be waded through.
One of the better posts in this thread is:
http://www.bimmerfest.com/forums/sho...2&postcount=19
One poster said, "Isn't it odd that a threaded cable which is screwed in like that could lose connection over time just from typical road bumps? " I'm not sure that's what happened. I doubt the connection came loose. My guess is that fiddling around loosened up some of the corrosion on the aluminum BMW uses, but I just will not have time to do my own fiddling until Monday.
I found that a lot of "dead batteries" on the road (where people couldn't start their car and "needed a jump") had nothing to do with the battery, but the terminal corrosion. I always carried around a very thin long finishing nail and would lightly hammer this into the joint between the battery terminal and the cable. And poof - the car would start. Like magic. Quick. Easy. And didn't waste too much of my time getting them back on the road.
Old 04-09-2011, 10:33 AM   #6
johnrando
These are all good posts but I'm still thinking those don't apply to VERTS because of our antenna location?
Southern California
Old 04-09-2011, 11:34 AM   #7
mach.schnell
I realize that but... there is still some kind of connection from the antenna into the amp, and some of the head units still may use a coax cable.
(See following: http://www.bimmerfest.com/forums/sho...d.php?t=396131 although I have not checked this out yet - still raining.)
But there is corrosion in the threads where the vert antenna screws off.
I will be tracing the wires back from the antenna and let y'all know what I find.
Old 04-12-2011, 12:51 PM   #8
johnrando
Any luck yet?
Southern California
Old 04-12-2011, 02:39 PM   #9
mach.schnell
Well.... it was 83 degrees F out yesterday, so there were a lot of t!tties out. Then it started raining just as I got back from an afternoon of twisties. Still raining, and will still rain tomorrow. So.... I did take some video of the AM radio freaking out, so I have to figure out how to post it. Patience. I move slowly when not driving. ;^)
Old 04-12-2011, 02:53 PM   #10
johnrando
LOL, no worries. Just looking forward to a possible resolution.
Southern California
Old 04-18-2011, 12:17 AM   #11
mach.schnell
Had one nice day of weather Sun. So I had to clean out the drain holes in the top storage compartment. One friggin little maple tree seed (the helicopter kind) plugged that right up... inch of water in the spare tire well, and drips of water on the electronics.
Haven't forgotten y'all yet. But it's supposed to .... wait for it ... yes, rain the next two days.
Old 04-30-2011, 07:50 PM   #12
johnrando
Still holding out hope that you'll find a solution for us. :-)
Southern California
Old 05-01-2011, 03:27 PM   #13
mach.schnell
Haven't forgotten. Just had both parents go into different hospitals (over an hour and a half), and my materials engineer went to a convention in GA. Then I got sidetracked with a low coolant level, and trying to find out if the back rear panels are leather or vinyl covered.. and so it goes. Also only to find out the ball joint in the front driver's is shot and "very dangerous" according to my mechanic - enough play to snap off during a turn (supposedly). Not trying to derail the thread, just having other things get in the way.
