Old 04-09-2011, 01:30 PM   #1
Dunbar
My Ride: '04 330i ZHP 6MT
Folding Rear Seats Won't Release - How to Fix
Didn't find much when I searched so I thought I'd post a DIY on fixing the folding rear seats. If you pull the seat release in the trunk and nothing happens (feels like no tension on the cable) here's how to fix it. My example is the drivers side but it should be the same on both sides. This is super easy, takes less than 10 minutes.
1) You need to get the seat folded first. To manually release it get your head all the way against the seat back and look up. Take a flathead screwdriver and push forward (towards the front of the car) to release the latch. My picture is taken with the seat already folded so there's enough light. Obviously the seat won't be folded when you start.
2) With the seat folded remove these two bolts.
3) Slide the latch out making sure the metal notch in the middle isn't snagging on anything. Insert the cable end back in the white bushing and you're done! Reverse the process to reinstall the latch.
Dunbar is offline   Reply With Quote
Old 05-19-2011, 01:38 PM   #2
Mhnd
My Ride: 2004, 330XI
My seat problem is it won't latch no matter how hard I push back! It looks as if the latch stuck open, is this a similar problem solution?!
Thanks!
Mhnd is offline   Reply With Quote
Old 05-20-2011, 03:19 PM   #3
Mhnd
Any suggestions?
Old 05-27-2011, 09:55 PM   #4
Dunbar
Try loosening the two bolts pictured, slide the latch as far forward as it will go (towards the front of the car) and re-tighten the bolts.
Old 06-11-2011, 11:58 AM   #5
Mhnd
Thanks! I'll give it a try and will post.
Old 06-03-2015, 08:00 PM   #6
Falkor
My Ride: 83 323+88m3+02 325ci
images are broken.
this just happened to me, as i tried to fold down the seats, i over-exerted the lever.
wish i could see the pix.
Falkor is offline   Reply With Quote
