Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum. |
#1 |
My Ride: Imola Red ZHP
.22 Conversion in AR15
Does a .22 conversion cause any long term damage as far as accuracy and durability/reliability of the rifle when switching back to .223? The ammo I would be using is 36gr .22 Federal Champion HP's with a copper plating.
Selling Tons of 323/328 E46 Parts! Check recent threads!
#2 |
No for two reasons.
1: you are basically changing the whole upper 2: you are basically changing the whole upper
![]() 2002 TiAg M3 OEM 19s/Fiamm triple air horn/Valentine V1/Uniden BCD396T/Uniden XL 520 Pro/Lightwerks TFX with 55 watt kit/Mediabridge 1500/Pro Fit iPhone bracket and holder |
#3 |
How about the bolt conversion kits?
#4 |
I never could understand doing this.
Is a good quality conversion not close to a regular .22 AR style rifle? (within a few hundred)
![]() Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI cables on a BMW board since 2005. 2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD/JL (works for me) 1968 Ford Mustang with Polk/ADS (my first car and runs strong) 2007 Lexus GS350 with every option (I loved it) 2000 BMW DINAN M5 (will be missed) 2001 BMW 330ci (will be missed) |
#5 |
They are, but some want one gun, multiple calibers to use their trigger and other support pieces.
I agree, converting the upper is quick, but pulling out a different rifle is quicker.
#6 |
I know CMMG sells some .22 bolts that some have reported good results with. You shouldn't be damaging your rifle by swapping between .22lr and 223.
#7 |
I don't foresee any damage issues.
#8 |
Ok thanks reedo. For those asking, the CMMG kit is only 134 shipped, which is much cheaper than a MP 15-22 or a dedicated upper. I would also like to use my optics and practice with my main gun, not a plinker.
#9 |
link to the CMMG deal?
#10 |
http://www.midwestindustriesinc.com/...ategory_id=217
Apparently they are out of stock now? It says "call" but I was able to order online. Never heard of the company but they shipped it quickly and im pleased overall.
#11 |
Let me know how it shoots, I have a 1:7 twist on my DD and Ive heard that it can really mess with a .22.
Ive also heard that you need to shoot some .223 after a day of .22 b/c the .22 is dirty and might start to clog up the gas block and tube...
![]() Last edited by shwagon; 04-12-2011 at 09:36 AM. |
#12 |
Yeah my BCM is 1 in 7 also. Will report back results.
#13 |
i <3 my spike tact .22 bolt for my AR
#14 |
My Ride: HPF Stage 2.5 e46 M3
In for results as I too have a DD 1:7 twist and VERY interested in the CMMG conversion
#15 |
buy my spikes lower... i dont use it anymore...
#16 |
What does that have to do with .22 conversion?
#17 |
I conversion
#18 |
conversion i meant*
#19 |
Results are G2G. Leaves a lot of burnt powder residue in the upper part of the upper, but nothing that a toothbrush and rag cant get out. Accuracy isnt exactly pinpoint, but I'd say I didnt see anything outside of more than 12 MOA at the absolute worst. Most were probably within 6 MOA of where I was aiming. I have been using 525 pack Federal Champions and running a bore snake every 100-200 rounds.
Initially I was getting some 3 round bursts and fail to loads out of the kit, but it definitely does have a break in time, and over the past 400 rounds I have had 1 stovepipe that was easily cleared. Everything else has been 100% even at rapid fire speeds. Fun little kit, definitely worth the $134 from the company I linked to.
#20 |
I have one and its worth it, I just switch back to a 223 bolt at the end and let go a couple to just make sure the gas tube is clean(ish). If your really worried just buy a new upper and dedicate it to .22 only.
