Old 04-11-2011, 12:52 AM   #1
Danielgore330ci
My Ride: Silver 2003 330ci
Car says it's 122 degrees outside constantly
Has anyone ever had this problem before?
What did you do to fix it?
And is it bad to still drive like this?
Danielgore330ci is offline   Reply With Quote
Old 04-11-2011, 10:08 AM   #2
patdown
My Ride: 2005 BMW 330Ci
It's probably your outside air temp sensor. Make sure the connector is firmly on. If you have a buddy with a BMW, see if you can use his to swap out. That's what I did. When mine was malfunctioning, it did not seem to cause any trouble.
Pat
2005 330Ci ZHP 6MT
AA Tune, domestically engineered CAI w/aFe Pro S, UUC TSE3,
Cooling Sys ovhl with Stewart WP, BMW M3 Front Strut Brace,
Koni FSD struts/shocks with original springs,
Cryo-Stop Rotors, Akebono Euro Ceramic pads, SS Brake/Clutch lines, CDV Delete,
Mason Engineering clutch pedal, Umnitza Predator Orion AE's, smoked corners and sides,
VMR V710 18" Staggered w/Hankook Ventus V12 235's/FR and 265's/RR
patdown is offline   Reply With Quote
Old 04-12-2011, 02:17 PM   #3
Steven747
My Ride: 05 330ci
It's your ambient temp sensor go near the front of your passenger side wheel well and there should be a indent that will hold the sensor .. It's probobly torn off
Old 04-15-2011, 02:07 PM   #4
shanneba
My Ride: 2003 330Ci
The ambient temp sensor is on the drivers side. It will affect your heating and cooling, the IHKA uses the temp as an input.
This thread has a great DIY on page 5-
http://forum.e46fanatics.com/showthr...erature+sensor
Join BMWCCA
Old 04-15-2011, 02:48 PM   #5
///Orient3
My Ride: can't be defined
Best reply to this as a malfunctioning or missing ambient temp sensor will wreak havoc on your climate control functionality. I spent a 4th of July road trip without AC because of a malfunctioning (not missing) ambient temp sensor a few years back.
[url=http://photos.e46fanatics.com/showphoto.php/photo/90077]
///Orient3 is offline   Reply With Quote
