E46 Convertible
Thread Tools Search this Thread Rating: Thread Rating: 115 votes, 4.85 average.
Old 01-25-2011, 10:26 PM   #221
Kripas
My Ride: 04 325ci convertible
Finlly got my LM rims
Kripas is offline   Reply With Quote
Old 01-25-2011, 10:48 PM   #222
Gheybe
Gheybe's Avatar
My Ride: F80 M3
Gheybe is offline   Reply With Quote
Old 01-26-2011, 09:37 AM   #223
Mpsmith1
My Ride: 2002 325ci
Originally Posted by mach.schnell View Post
It's not obvious at first sight that there's no bottom in these, and floor space in the back is llimited at best. I guess you could wedge the metal tab into the rear ashtray somehow.
I like this one, but it's only in white (I think).
http://www.gandermountain.com/modper...p&merchID=4005
Then again: http://forums.bimmerforums.com/forum....php?t=1575843
(ain't "search" wonderful??)
Your Gandermountain link is broken. Can you repost it? I'd like to see which one you liked.
I appreciate the bimmerforums thread you posted, but I am interested in putting cup holders in the back seat, not the center console in the front. And that thread is for an E34, not an E46. It's a great looking cupholder, but won't work in my car. Thanks, though.
Mpsmith1 is offline   Reply With Quote
Old 01-27-2011, 05:19 PM   #224
mach.schnell
My Ride: 08/2000 330Cic x2
Interesting, worked for me. Here it is again, and I included pics. The black flange is supposed to slide down behind the middle seat. Don't know if t will fit in a vert. Sedan i different.
ID:	391226   Click image for larger version
mach.schnell is offline   Reply With Quote
Old 02-03-2011, 03:06 AM   #225
Gheybe
Gheybe's Avatar
My Ride: F80 M3
Hey guys, what's your opinion on dual tone Cinnamon?
I wanna keep my seats black because the front ones got torn up and not worth the fix.
Old 02-03-2011, 03:58 AM   #226
///M3Risto
My Ride: E46 '06 M3 vert, B/B
How the heck did I subscribe to this post with sharing? Anyways, some of you have seen my vert already but here you go anyways ... (BTW, she's getting dropped this weekend ) Sorry for the crappy pics!
ID:	391961   Click image for larger version
ID:	391962   Click image for larger version
ID:	391963   Click image for larger version
______________________________
///06' E46 M3/JB/B/Vert/19" BBS LMs/Hankook Ventus V12 Evos/H&R Sport Springs/Depo Corners/Angel Eyes/CF CSL Style Diffuser/CF Hamman Style Lip/K&N 57///
///M3Risto is offline   Reply With Quote
Old 02-03-2011, 10:27 AM   #227
SMUUUUUV
My Ride: 330CiC X5 4.4-MBS550
Nice...
SMUUUUUV is offline   Reply With Quote
Old 02-03-2011, 02:08 PM   #228
joneperry
My Ride: e46 + S60 + Z
is there a vorsteiner bootlid rep yet? i want it badlyyy
joneperry is offline   Reply With Quote
Old 02-03-2011, 05:32 PM   #229
joneperry
the seats in cinnamon to match the door panels and armrests would look so much better, didnt you say you were going to get another set of seats? imo leave it black until then. how big is the tear?
Old 02-03-2011, 09:23 PM   #230
Gheybe
Gheybe's Avatar
My Ride: F80 M3
I wish.
It's big enough to where I can't fix it.
And the new seats I'm getting are gonna be all black buckets.
Old 02-03-2011, 09:52 PM   #231
joneperry
I wish.
so i take it they arent going to be stock (racing buckets?). if tahts the case i think they should be alright in terms of looks, if it were me i'd reupholster them in some cinnamon suede
Old 02-03-2011, 10:02 PM   #232
Gheybe
Gheybe's Avatar
My Ride: F80 M3
I don't think that would last very long with me.
I'm still weighing my possibilities.
Old 02-06-2011, 08:37 PM   #233
jzwu
My Ride: 2005 BMW 330Cic
Fixing top hydraulic line?
I took a look at my top today. There has been a leak on the left rear side. It seems one of the hydraulic lines got pinched during the top operation and I saw a rupture in the line.
Now how do I fix it? The particular line runs from the solenoid to the left hydraulic cylinder. The cylinder itself is good, no leak at all.
I can access the end at the hydraulic cylinder easily but the other end at the solenoid is a little hidden even though I can see it. There is barely any room to work there.
Thanks for any help.
jzwu is offline   Reply With Quote
Old 02-07-2011, 09:15 AM   #234
///M3Risto
She's lowered
My wife (not mechanically inclined) finally took the car in to the "recommended tire specialist" on Tire Rack's list of "To go to" guys (being that I'm not stateside right now), and the results are exactly what I expected! Can't wait to see my M in person! Of course, I presume the car will be even lower in about 2 weeks. The setup right now are just H&R Sport Springs. Alignment was done as well! Let me know what you think!
Old 02-07-2011, 10:23 AM   #235
BMW-North
// Quandt AG (Retired) //
My Ride: AMv8,e46x3,e90,e83
Are the LED's plug 'n play
Originally Posted by SMUUUUUV View Post
Can anyone please tell me why vert led tails are so much more expensive than any other led tails??... and are oem led tails plug n play with a '02 harness?.. thx in advance...
Hi to answer your questions:
Why do the lights cost more - it is simply supply and demand - there are fewer e46 Cic's therefore there is less opportunity to recover design and tooling costs. Try buying parts for a right hand Cic - they are typically 25% higher since there are fewer right handed cars.
Are the LED's plug and play on an 02. I assume you mean model year which would be an 01 production date. The lights will connect to the harness but you will get errors on your cluster and they will will function erratically.
You need to check to see if your light switch supports LED. I can't recall the production date but I think it was prior to the facelift. You can verify at real oem the part numbers. On my 01 Cic I had to source a new light switch.
Once you have the correct light switch they are still not plug 'n play. You will need to have the LKM (light control module) programmed to support the new lights. Find a friend with GT1 or other OBD tool to activate the module. The Stealer will do it for a price (between $75 and $120) I imagine.
BMW-North is offline   Reply With Quote
Old 02-09-2011, 02:41 PM   #236
QBert330vert
My Ride: e46 330 ci
Convertible top hydo pump is kaput
Hey folks,
I posted this in the general thread but was ushered over here by Smuuuuv and mebbe I'll get more traction?
From the original post:
On the drive home today I heard a wonderful gurgling noise coming from the passenger side rear on my 2002 330 convertible. The cabin and trunk area smell of hydraulic fluid and the convertible top won't operate. I have no idea if its a hydraulic cylinder or just a hose that has failed and no way to fix it .
Now the update:
I took it to the shop and they told me that the main hydo pump is toast and it needs to be replaced before they can do any further troubleshooting.
Since the main pump is on the LEFT side, and the sound was definitely from the RIGHT I am concerned that the main pump is only the first of a couple issues here. I've already sourced a used pump from ebay for $300 (the stealer wants $1,042!) And it has a 3 month warranty.
- Has anyone done this job before (replacing the main pump?) How difficult is it?
- I understand that I have to do this job starting with the top in teh fully stowed (down) position. The buttons still work to unlatch the top from the windshield but can someone tell me what I need to do to get the top stowed from there since the pump won't work? Is it a matter of just muscling it?
Any advice?
Thanks guys and +1 on the thread - I think we should have our own forum!
Q
QBert330vert is offline   Reply With Quote
Old 02-09-2011, 02:44 PM   #237
DropTopKingM3
My Ride: All German
Q, same thing happened on my car 4 years ago. I had purchased a pump on this site via the parting out section of the forum. Check there as you may end up finding it for less than $300. My indy shop charged me $400 for the install, bleed the system, and reprogram the top. Too much of a risk to try to tackle it on my own so Id rather pay the money and have it fixed the correct way. Call up a few indy shops.
..George..
..Is now Alpine White/Cinnamon...
^Don't say my car is topless, say the t!tties is out^
DropTopKingM3 is offline   Reply With Quote
Old 02-13-2011, 08:10 AM   #238
Warhammer
My Ride: 2006 330CiC
I'm in! Post pics later
Warhammer is offline   Reply With Quote
Old 02-13-2011, 12:11 PM   #239
SMUUUUUV
Originally Posted by QBert330vert View Post
Hey folks,
- I understand that I have to do this job starting with the top in the fully stowed (down) position. The buttons still work to unlatch the top from the windshield but can someone tell me what I need to do to get the top stowed from there since the pump won't work? Is it a matter of just muscling it?
Any advice?
Q
theres a section in your owners manual to show you how to put the top down manually... there should be a tool behind/near your middle section of ur rear seat and you use that to crank your top down by the interior lights up front ... but like mentioned in previous post... not something you wanna try if you havent done it before..better just to pay a qualified indy BMW shop to do it for you...doing that yourself is a lesson that you may not wanna learn... .... and its SMUUUUUV.... 5 U's...
Old 02-13-2011, 09:25 PM   #240
dan_1337
My Ride: 330CiC
Do you guys know whether verts corner flatter than our coupe counterparts due to the thicker sways or are the thicker sways in place because our cars are slightly heavier than the coupe and hence our car still rolls the same amount?
I ask because the vert sways are quite a common upgrade to the standard coupe sway/roll bars.
dan_1337 is offline   Reply With Quote
Rate This Thread
