Old 04-11-2011, 06:16 PM   #1
Table3
My Ride: '01 325xi
2001 325xi exterior advice (pics)
So I'm thinking about buying my friend's mid-year 2001 325xi. I posted this thread to get advice on the state of the interior. Thought I'd do the same for the exterior.
Here are the exterior cosmetic problems I found:
  • a couple very small rust spots on the hood and front right quarter panel
  • a small dent in the left rear quarter panel
  • a small puncture below the rubber strip on the rear bumper
  • the panel beneath the left quarter panel (behind the left rear wheel) is becoming separated from the quarter panel
Here's a close-up of a couple of the rust spots. I should have put a penny next to it for scale. I reckon the larger spot is about 5mm wide.
Dent in the quarter panel; any way to knock that guy out?
Puncture in the bumper. Any DIY way of fixing it?
Finally, the separating panel. I didn't get underneath and have a look. Is this as simple as tightening a nut?
Thanks in advance.
Table3 is offline   Reply With Quote
Old 04-11-2011, 06:59 PM   #2
eld4au6
My Ride: 00 323it
-Looks like normal rock chips, touch it up
-Painless dent removal guy can probably take the ding out, then touch it up.
-Touch up the scratches.
-Probably easier to buy a used bumper in your same color.
eld4au6 is offline   Reply With Quote
Old 04-11-2011, 07:53 PM   #3
Table3
My Ride: '01 325xi
To clarify, are you sugessting this as the solution to the gap between the rear quarter panel and the bumper?
Old 04-11-2011, 07:57 PM   #4
CoupeMagic323ci
My Ride: 00 323ci
i had the same problem with my bumper. its just a clip that snapped that holds it up im pretty sure. i did some body work and the guy at the shop did it for free for me. he told me it was just a plastic clip thingie.
CoupeMagic323ci is offline   Reply With Quote
Old 04-11-2011, 08:05 PM   #5
CoupeMagic323ci
My Ride: 00 323ci
heres some pics. didnt get any after finshed but it looks like new
ID:	399930   Click image for larger version
Old 04-11-2011, 08:23 PM   #6
eld4au6
My Ride: 00 323it
No, I was referring to the gash in the back/side of it.
Edit: sorry I meant for them to be in the order of the pictures you posted
Old 04-11-2011, 08:33 PM   #7
NOVAbimmer
My Ride: E60M
you're not going to want to just touch up that rear bumper, its going to look pretty ugly. It needs to be repaired and painted. Or replaced. As for it being loose on the side (yes, that's still the rear bumper), it could be a broken bracket, or it could just be loose and need to be taken off and adjusted.
NOVAbimmer is offline   Reply With Quote
Old 04-11-2011, 08:49 PM   #8
Table3
My Ride: '01 325xi
Thanks for the responses, everyone.
Hard to tell if it's broken or loose. I'll try to get a picture and post it. Either way, is there a DIY fix?
Old 04-11-2011, 08:54 PM   #9
drumbum624
My Ride: 325xi
Send a message via AIM to drumbum624
bumper clips break easily. a body shop will know what to do then over charge you. talk to them...but then use what they say to do it yourself lolz
drumbum624 is offline   Reply With Quote
Old 04-12-2011, 12:59 PM   #10
Table3
My Ride: '01 325xi
Haha, ok, any further advice? I'd like to avoid the body shop, if possible.
325xi, bmw, exterior
