Old 04-12-2011, 04:24 AM   #1
karl203
My Ride: 2004 320d sport tour
Unhappy Locked out 'Please Help'
Hi all, My battery has gone dead and the one key lock I have opened the door once but is now refusing to do it again. Any idea's how I can get in. Happy I can sort the problem once in. Looking for a better and cheaper option they smashing a window. All tips greatfully recieved.
Car is a 2004 320d sport tourer.
Cheers Karl
karl203 is offline   Reply With Quote
Old 04-12-2011, 04:30 AM   #2
luc
My Ride: '04 325i
your wording is confusing.. are you saying the button wont work? because you can just put the key in the lock and turn it..
2004 325i sedan
3 pedals, ZSP, ZPP | bimmerbrakes headers | shark injector | AFE filter / swiss cheese | 17" TRMotorsports C2 | H&R suspension | CF sunroof delete | custom short shifter | clear lights | CDV delete | DIY aux audio in | lots of random $5 mods
gamertag: babyDriver29
luc is offline   Reply With Quote
Old 04-12-2011, 04:38 AM   #3
Drizzles
My Ride: 1999 BMW 318i E46 4D
Yeah I agree that is shocking English
BTW, whether it's helpful or not I have one thing to say ...
HAHA!!
Drizzles is offline   Reply With Quote
Old 04-12-2011, 05:32 AM   #4
GuitarmanTT
My Ride: 1999, E46 328i
I understand you. Your battery is dead and your lock/key is broken. I have three options for you as i worked at a car auction for a year and ran into lots of dead cars with no physical key just a viper fob and this is how we went about it.
1. Door locked out kit. Kit
Basically consists of a air tight bag with a hand pump on it. ( like the pressure cuff they use to check blood pressure )
A screw driver
A strong steel rod 3 - 4 feet long that is bent to give leverage on a door handle.
place a rag in the top back corner of the driver door, with the rag protecting the paint or plastic use a screw driver to pry the door just enough to insert the air bag at the top of the door. You may only get a corner but its better to let the bag pry the door the holding an unforgiving screw driver on your paint. You might need to fill the bag and re insert the driver to hold the door so you can put the bag in a better position. Pump the bag up until you get a 1" gap near the middle of the door, put the 3 foot rod in the door fishing for between the door and the handle and twist it using the curve and the door as a leverage point to pop the handle open unlocking the door.
You could do this without the air bag but you will ding your car if your not careful and you will need a friends help.
2. Find a way to open the hood ??? Getting to the latch and unbolting it or putting tension on the cord that unlatches it. ( thats hard to do because the sheath thats around the cable) Then you can add power to the jumper points and use the key fob.
The hood pop system works great on big trucks because the doors are to high to fiddle with all that stuff and once you get the grill out there is room the unbolt the latch and lift the hood enough to pop the latch most the time.
3. Call a lock smith he will have the above kit in #1 and a lock pick kit and can make you a working key and fix your lock. Best bet!!!!
Whooooooooop
GuitarmanTT is offline   Reply With Quote
Old 04-12-2011, 05:56 AM   #5
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Doesn't rear door have a key lock you could use? I must be missing something, or there isn't a key slot for it.
Also, OP, you'll be glad to know you're in a large group here and you'll find hundreds of locked out threads.
There's the 'drill a hole behind the rear license plate' idea that I found the link for last week or two for some guy (if you search for me and 'locked out' you might find that. You supposedly can use a hole to then pull on the release for trunk, but that's all I know.
GL...hth
Doug
Facebook.com/DMAXstandup
Mangofy your E46!
dmax is online now   Reply With Quote
Old 04-12-2011, 06:33 AM   #6
GuitarmanTT
One more thing see if your key opens the trunk, pop the seats down and get in.
Old 10-26-2012, 10:59 AM   #7
ataan
My Ride: e46 318
can you explain how exactly can you go inside the car from the trunk?
ataan is offline   Reply With Quote
Old 10-26-2012, 11:02 AM   #8
Cobra
My Ride: '00 328i & '06 R6S
what about getting into the trunk, hooking up some jumper cables to get the juice flowing and then unlocking the car with your remote?
Cobra is offline   Reply With Quote
Old 10-26-2012, 11:05 AM   #9
bratliff
My Ride: 330i
^^^ This was my thought.
And BUY ANOTHER KEY!
'02 330i
'97 318i
'95 325 Vert
'76 280z
bratliff is offline   Reply With Quote
Old 10-26-2012, 12:18 PM   #10
trj
My Ride: 325Ci
Easily do-able if you have folding rear seats.
For OP, if you have the master key, open the trunk and jump from battery directly. Of course, you cant start the car without getting in it, but if you leave the jumper cables connected to the other car(at least 5 mins) there should be enough juice to get the battery to a state where you can unlock with your remote.
After you are able to get in the car/trunk test the battery.
BMWs take a lot more time to get a jump start from another car if your battery is flat.
Once I had to jump my friend's 5 series. It took 20 mins after connecting the jumper cables to the jump points to get his car started. Yes, I did have my car running at the time at varied rpms.
Old 10-26-2012, 12:20 PM   #11
jdstrickland
My Ride: '94 325iC & '00 323i
You guys can correct me, but the OP said he has a sport tourer, isn't that the station wagon? It would be easy to open the back of the car and get to the front.
I'm confused, he said he used the key once but can't use it again. What's that mean?
Old 10-26-2012, 12:44 PM   #12
trj
My Ride: 325Ci
After reading your comment, I re-read the OP.
Hmm now I am confused too. Does he mean the battery on the key fob went dead and the physical lock-key mechanism doesnt work(worked only once)?
In any case, he should be able to get into the trunk with a physical key, unless he has a valet key or the lock mechanism at the trunk isnt broken.
A touring makes it even easier to get in to the car from the trunk.
Old 10-26-2012, 01:13 PM   #13
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
The op was in his car a YEAR AGO. Good threadbump.
not.
"One thing we all adore. Something worth dying for..
Its been nothing but pain, stuck in this game. Searching for fortune and fame"
MachRc is offline   Reply With Quote
