Old 04-12-2011, 09:05 AM   #1
Viper331
My Ride: 330i
Intermittent burning oil smell
Recently I changed VCG because of burning oil smell and also having 90000 miles . Driven car a couple of times since and after warming up and driven about 10 minutes I get the burning oil smell, after about 5 minutes its gone.
Its done this twice already. Don't know whats up with it now.
Any info?
Viper331 is offline   Reply With Quote
Old 04-12-2011, 12:20 PM   #2
shwagon
My Ride: 325it 5-speed
most likely your valve cover gasket, check the area above the exhaust manifold near the rear of the engine.
Originally Posted by Reedo302 View Post
What an unending cavalcade of rampant virgin Mom's-basement-dwelling douchebaggery... Wow.
My Gun Builds: AR-15, GSG-522-SD, Saiga 308
shwagon is offline   Reply With Quote
Old 06-01-2011, 11:45 AM   #3
Bimmerman330
My Ride: 330Ci,
Send a message via AIM to Bimmerman330
Any info?
bump, any resolution to this issue? I have the exact identical issue and I just changed the VCG as well.
Steel Grey 330Ci
Mods: none
Bimmerman330 is offline   Reply With Quote
Old 06-01-2011, 12:39 PM   #4
Viper331
My Ride: 330i
I was told it was just residual oil between the heatshield plates on RH side of valve cover above exhaust manifold. Oil would drop on exhaust and burn off. After several more drives it stoppped doing it.
Old 06-01-2011, 02:16 PM   #5
Bimmerman330
My Ride: 330Ci,
okay thanks. i hope this is the issue for me as well. Will update if other issues are found.
Steel Grey 330Ci
Mods: none
Old 06-01-2011, 03:23 PM   #6
raprazant
My Ride: e46 coupe
Just in case here is a Valve Cover Gasket DIY
raprazant is offline   Reply With Quote
Old 07-19-2011, 01:46 PM   #7
Bimmerman330
My Ride: 330Ci,
Got my VCG fixed, but there is still smell of oil. I still see some faint smoke coming out of the kidney grills, not very noticeable but with my lights on at night I can see it. Is this residual oil burning off?
Steel Grey 330Ci
Mods: none
Old 07-21-2011, 02:27 PM   #8
Cobra
My Ride: '00 328i & '06 R6S
could be. see if the problem persists. i thought i was leaking oil, but i was actually leaking power steering fluid. i replaced both the short hoses and a new gasket on the ps fluid reservoir, and no burning oil smell anymore.
Cobra is offline   Reply With Quote
Old 07-21-2011, 02:48 PM   #9
Bimmerman330
My Ride: 330Ci,
crap, okay I'll check that.
Steel Grey 330Ci
Mods: none
