#1 |
[SOLVED + pics] Bad rear U Joint?
I recently took my car to my indy for driveline vibrations. Really bad driveline vibrations. I assumed it was a bad center support bearing and/or guibo. I don't have a lift, and don't want to do this on a creeper, so I paid him to do it. When he dropped the exhaust and heat shield, he told me the rear u joint is busted and a part is broken off/missing and could fall apart at any time; not safe to drive.
He just sent me pictures of said bad u joint, and I was wondering if someone can point out what is bad/missing in these pictures or show me what a "good" e46 u joint looks like vs mine. Sorry about picture quality, I cleaned them up as much as I could.
E46 323i Sport/5 speed/TiAg | 231k miles E85 Z4 3.0i Sport/6 speed/Toledo Blue | 74k miles E39 530i M-Sport/5 speed/Topaz Blue | 196k miles Dynavin Android | Laser Interceptor | GRE PSR-800 | STi-R+ | M3 seats | 50W 4300K FX-R Retrofit | Solid black interior | Mtech II front bumper | Koni FSDs Member, Three Pedal Mafia | Long informative article on oil | BITOG German Castrol FAQ ![]() Last edited by jneumann; 04-19-2011 at 08:46 PM. |
#2 |
Mod
No idea but thanks for giving me a tip on something else to look for. I get bad vibration above 60 now and it's not the wheels or alignment at all. I know it's driveline related.
btw, when you let go of the gas does it get worse?
Follow my cross country drive to Bimmerfest West 2013
http://forum.e46fanatics.com/showthread.php?t=987217 ![]() Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide |
#3 |
I thought the U joints are welded on our driveshafts..
#4 |
Its hard to tell from those pictures... Id' ask him what he thinks is wrong there.
I haven't ever looked at the u-joints on our cars before but typically there is a spring clip that is installed right above the caps to keep them from working themselves out of the driveshaft. I dont see one in those pictures. I wouldn't say it makes it undrivable, and doesnt make the u-joint bad, you can replace a lousy spring clip easy enough. Also, if the u-joint IS bad, you can't always tell just by looking at it. The parts that go bad are the little needle bearings under the caps... you could probably tell by grabbing that driveshaft and feeling for play
2003 BMW 330i ZHP BMW Performance Intake and SSK - Headers - Magnaflow - ESS Tuning Turner Motorsports Pullies and Reinforcements - H&R Spacers - StopTech - And more... ![]() |
#5 | |
Check your guibo and center support bearing too. I believe they are. That's why I just bought another driveshaft from Bav Auto Recyclers. $200 + shipping for a used one with a new center support bearing.
E46 323i Sport/5 speed/TiAg | 231k miles E85 Z4 3.0i Sport/6 speed/Toledo Blue | 74k miles E39 530i M-Sport/5 speed/Topaz Blue | 196k miles Dynavin Android | Laser Interceptor | GRE PSR-800 | STi-R+ | M3 seats | 50W 4300K FX-R Retrofit | Solid black interior | Mtech II front bumper | Koni FSDs Member, Three Pedal Mafia | Long informative article on oil | BITOG German Castrol FAQ ![]() |
#6 | |
#7 |
Mod
Alright thanks. I'm going to have them checked out this weekend. I'm going to balance my wheels regardless tomorrow (last balanced with new tires in november)
#8 |
Stay stock my friends!
http://www.realoem.com/bmw/showparts.do?model=AM53&mospid=47723&btnr=26_0129&hg=26&fg=10
I think he's showing you that the joint where the #13 bolt goes is missing the sizable metal pieces together. Seems a surprising failure to me. How many miles? How heavy is the boat you've been towing? It's unserviceable, if what I'm seeing is right. You should get down to shop and get a closer look. You might also want to look really closely to see if there are any tool marks! That's a surprising failure, but maybe one of our experienced mechanics will say he or she sees it all the time! Make sure all the details are followed in reassembling...and there are some little parts you might want to be sure to insist get ordered...like centering pin, and the butyl tape for the csb, and the guibo bolts are technically one time use only. If you study up on the driveshaft install, you'll see this is something you could do if needed and could save yourself a ton, I bet. You have a price on all this...you have someone to hold the exhaust for you while you bolt it up? If you need it quickly, I'll just make sure this shop knows the details they should be following. Ask them about the butyl tape or mention the one-time bolts and see whether you have to stay on them or not!
![]() This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe." The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax |
#9 | |
Guibo and csb first...though I've seen enough posts from you recently to think your car is in a phase, so maybe it is driveshaft. Check wheels/tires carefully, though, before moving on. (I know I've been in your threads, but forget which ones!)
#10 | ||
#11 | |
#12 |
#2, centering 'sleeve'
I thought nuts and bolts, but they're bmw things anyway...you could probably use them three times without issue! See what price you get from him and then decide if $100 in jack/stands is worth it or not. Removing exhaust is just awkward. I haven't done it, but you just remove from bottom of manifold and unscrew some fasteners type of thing. Heat shield also comes right off. The key is the details in the install. Did you tell him to go ahead with stuff? If not, think about whether you want to have fun for a day under your car. I'm guessing it'd be $60 guibo/$100 csb/$400 driveshaft and 4 hour install..so just under $1000 at a shop...just poorly estimating. You'll get parts for $300, take 8 hours (not including studying time), spend $100 on tools you need...have $600 you wouldn't otherwise have. Doublecheck my arithmetic, I didn't know there was going to be math! And then, maybe it's too soon for you to be doing driveshaft and the $600 saves you the worry about whether you did it right. I'm at the point where I'd consider this, but I know many don't have a choice but to diy, and they do a lot and they get it done. Don't let me influence you, OP. Pretend I wasn't here!
![]() This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe." The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax Last edited by dmax; 04-13-2011 at 07:18 PM. |
#13 | |
A new CSB comes with the reconditioned driveshaft, ~$300 shipped, the guibo was ~$40. New seals comes to ~$50, new diff oil is ~$30. No labor charge for seals and changing diff oil. Edit: Since the new driveshaft comes with a new CSB, I have an extra. Anyone who needs one, PM me.
E46 323i Sport/5 speed/TiAg | 231k miles E85 Z4 3.0i Sport/6 speed/Toledo Blue | 74k miles E39 530i M-Sport/5 speed/Topaz Blue | 196k miles Dynavin Android | Laser Interceptor | GRE PSR-800 | STi-R+ | M3 seats | 50W 4300K FX-R Retrofit | Solid black interior | Mtech II front bumper | Koni FSDs Member, Three Pedal Mafia | Long informative article on oil | BITOG German Castrol FAQ ![]() Last edited by jneumann; 04-13-2011 at 07:57 PM. |
#14 | |
Get better photos of your driveshaft if you can. Probably goes back for core. Doug
#15 | |
![]() I will probably bring some butyl tape with me when I take in the driveshaft since I have heard w/o it, the CSB will fail faster. As for the old driveshaft, I will take pics and post them here. (Promise this time!) No core since I bought used from Bavarian Auto Recyclers.
#16 |
Update - Everything is finished, new (used) driveshaft is in place and holy crap is there a difference. All the weird vibrations I have had ever since I bought the car around 40-45mph and 75mph are completely gone. Tons quieter, shifts nicer, everything just feels tighter (new control arms and FCABs too). It's like a whole new car.
I highly recommend anyone with driveline harshness to check their u joints, guibo, and CSB for play. I've had the car for 40k miles, so my rear u joint was likely going out for a really long time before it got bad enough for me to suspect something was really wrong. (I did check the guibo about 20k miles ago, and it looked fine.) I will post pics of the old parts on Tuesday.
E46 323i Sport/5 speed/TiAg | 231k miles E85 Z4 3.0i Sport/6 speed/Toledo Blue | 74k miles E39 530i M-Sport/5 speed/Topaz Blue | 196k miles Dynavin Android | Laser Interceptor | GRE PSR-800 | STi-R+ | M3 seats | 50W 4300K FX-R Retrofit | Solid black interior | Mtech II front bumper | Koni FSDs Member, Three Pedal Mafia | Long informative article on oil | BITOG German Castrol FAQ ![]() Last edited by jneumann; 04-17-2011 at 10:15 AM. |
#17 |
Mod
Total cost?
#18 |
$320 for reconditioned driveshaft w/ new CSB overnighted from Bavarian Auto Recyclers
~$40 for new guibo $16 for trans seal and diff seal $20 for diff oil Control arms and bushings were Meyle HD from ECS. (w/ replaceable ball joints) $350 Left tie rod was OEM from Pelican Parts. ~$85 Total labor was ~$400. Ended up taking him like 3+ hours just to remove the old control arms... Only issue currently is severe need for an alignment after replacing that tie rod. In hindsight, I should have done the control arms and bushings last summer when I had free time to work on my car...
E46 323i Sport/5 speed/TiAg | 231k miles E85 Z4 3.0i Sport/6 speed/Toledo Blue | 74k miles E39 530i M-Sport/5 speed/Topaz Blue | 196k miles Dynavin Android | Laser Interceptor | GRE PSR-800 | STi-R+ | M3 seats | 50W 4300K FX-R Retrofit | Solid black interior | Mtech II front bumper | Koni FSDs Member, Three Pedal Mafia | Long informative article on oil | BITOG German Castrol FAQ ![]() Last edited by jneumann; 04-17-2011 at 11:44 AM. |
#19 | |
#20 | |
![]() My girlfriend thinks I'm completely nuts every time I try to figure out the source of every little noise I hear from the car. ![]() The latest annoyance is the plastic ring around the ignition key hole rattles like crazy every now and then. I'm thinking a small dab of hot glue will fix that until I tear apart the steering column to put in an OBC stalk.
